Everything posted by ennbenn72
3rd cracked windshield in 2 years..
ennbenn72 replied to Subasaurus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah I didn't really think about scratches. Guess you could use tearoffs! Haha -Nathan -
Anybody ever looked into Plexiglas? I know there are a couple of companies that do custom Plexiglas windshields for autocross and stuff. It may be a bit more spendy (or not) but at least you wouldn't ever have to worry about cracks! --Nathan -
Haha why?
So I'm in the process of giving my 89 coupe a shiny new paint job and a few extra accessories (I'll post pics when it's done) and I was thinkin I'm gonna get a windshield sticker that says "Rally-Bred" anybody have any cool font ideas? Thanks! --Nathan
Slow revs and hesitation: 90 Loyale EA82T
ennbenn72 replied to Jabbott126's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your timing info should be on the bottom side of your hood. Approximately right above the battery -
1993 Loyale Crank No Start Issues
ennbenn72 replied to BirdLoyale93's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check all of your fuses. My 89 is very touchy, if even 1 fuse blows it won't run. Even if it's a stupid one that isn't required to run. Also check to see if you have continuity through the ignition coil wire that leads to the dizzy. Good luck! --Nathan -
Having high idle, I'd say check the PCV valve vacuum hose first. It's a start.
86 Brat sputters when I shut if off..
ennbenn72 replied to ragingbull's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Touché haha that probably does work better. -
It's called dieseling here in Idaho haha. All ya gotta do is either, like they already said, up the octane for a bit, OR you can hold the throttle open to rev it up and pour a LITTLE bit of water down the intake. Not too much cause it'll hydrolock, but a little tiny bit at a time will clean it out -
I'm going 2.25 with a Thrush Welded. Kinda interested to see how the dual in dual out sounds.
Show off your roos Mileage!
ennbenn72 replied to beataru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Since I can't post pictures from my phone... My 89 GL Coupe just rolled past 177,777.7 -
Any from other vehicles that would be fairly easy to fit in? I'm okay with a little bit of fab work...
Okay so after a fairly thorough search, I haven't found a definite answer about air struts. Is there an aftermarket set that I can buy for my 89 coupe? I want to lower my car a little bit, but I don't want to sacrifice the fact that I can get it airborne without destroying the underbody haha. Any suggestions? Thanks! --Nathan
I've been kicking around the idea of air suspension for my coupe.. Any suggestions?
- 12 replies
- ride height
- springs
(and 7 more)
Tagged with:
So wait doesn't the xt have air suspension?
- 12 replies
- ride height
- springs
(and 7 more)
Tagged with:
http://www.ultimatesubaru.org/forum/topic/151734-please-help-to-decode-my-vin/?do=findComment&comment=1271686
The Subaru Search and Rescue Thread
ennbenn72 replied to Rust's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'll trade you cars! Haha I have an 89 GL hatch like that that I got for $300. I'll post pics of it when I get to a computer. -
PLEASE HELP TO DECODE MY VIN!
ennbenn72 replied to paquirl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://en.m.wikibooks.org/wiki/Vehicle_Identification_Numbers_(VIN_codes)/Subaru/VIN_Codes -
I hate to add to the mix, but I have some Nissan 16" 6 spoke rims that you might be interested in. They have the 4x114.3 pattern. I can show you a picture if you want. --Nathan
82 Brat; No spark, No start?
ennbenn72 replied to SueBee2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Any kind of relays going to the ignition system? Maybe one is stuck open or closed? I don't know a whole lot about the older brats, but its a suggestion. -
opinions please; intermittent running problem
ennbenn72 replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'd start with fuel pump. If the dizzy was having issues it would be more consistent. As far as it sputtering and dying when its cold, that's not a huge surprise with the Weber. My suby doesn't have one, but my LUV does and it hates running cold.. I always have to be pumping the gas, I can't just hold it in one place. -
So I have an 89 GL hatch. I have a few plans for it as far as restoring interior and performance. I want to give it a nice paint job too. All things will come with time, but I have also been considering the possibility of converting the steering and suspension components from a WRX. I have looked at many pictures, and obviously its going to take some fabbing and a lot of work, but I was just curious if it would even work? Do you guys think it would take a whole lot of chopping to fit things like struts and steering knuckles? The parts all look very similar and I really want to try it! --Nathan
