pontoontodd
    56
Everything posted by pontoontodd
  1. We asked J for a good place to camp north of town and he recommended some sand dunes just off 95 so we drove up there and camped overnight. Those are the dunes just to the right of the sign beyond the power lines. Tuesday morning we ate breakfast, packed up, and drove the last few miles to the big dune. It was certainly described accurately, the center dune was hundreds of feet high with no tire tracks going to the top of it. I was driving over one dune when we suddenly got to a sharp drop off the other side so I turned to avoid it and got stuck shortly afterwards because I was going too slow. We aired down the tires and got it out with the sand ramps and pushing. Aired down the other cars, and took turns driving each others' cars around the dunes. T's suspension was bottoming out easily so we unpacked his cargo while we drove around the dunes. I found one good little jump, the last time I hit it the driver's side got up much higher than the passenger side. Since it was soft sand the landing was fine.
  2. If the water pump seal is leaking, coolant will come from the weep hole. It's just to the driver's side (left side of the car looking forward) of the crank behind the timing covers, same as the EJ. The water pump replacement isn't much easier than head gaskets on the EZ though, you have to remove the timing chain cover, chains, tensioners, etc. It's about sixty allen bolts, some of which will strip out, so it's really a lot easier to do with the engine out of the car.
  3. We met with J and he took us to some whoops outside of town that were a little too big to run fast over with the Subarus. He was fairly impressed with what they could do and took us to some smaller ones along a dirt/gravel road. They were similar to the super whoops in the UP but narrow and on top of a crowned trail so we couldn't comfortably go much over 30mph. Unfortunately there was a ditch I didn't see until the last second and didn't slow down enough to prevent from plowing into the opposite side of it. It cracked one of the coolant fittings for the oil cooler. B and Z went into town to get some fittings and we took off the skidplate and cleaned things up and talked with J. After we got it back together we ran the cars over the whoops again (including T's for reference). J recommended valving changes at both ends. He had a small bottle that was good for charging maybe eight shocks but wasn't fully pressurized. I asked him if he had a vice and he asked if we had a receiver. I told him we have 1.25” receivers and he says with a look of disgust “that's not a receiver.” We were able to C clamp it to the rear bumper of the Outback. He also had a little toolkit that had an allen wrench and spanner wrench we needed. He left to pick up some steel as we figured it would take about four hours to go through all the shocks in the desert. It didn't feel a lot better in the car, mainly we noticed the car stayed almost perfectly level but bounced up and down. It definitely looked better from outside on video. He also took us to a deeply whooped out recent racecourse leading to some embedded rocks, B and I both thought the Outback rode better over them than with the old shock tuning in Texas. J had mentioned earlier in the day he'd never owned a car, only pickup trucks, but was looking up Subarus on Craigslist by the end of the day.
  4. R and I each drove our cars to Jean, NV Sunday night. Filled up at the largest Chevron station in the world - 96 pumps and 60 bathroom stalls. We met B and Z at the check in counter in the Terrible casino. Monday morning I got up early as usual to check over the suspension on my Outback and met T in the parking lot. He had driven his Outback XT 5MT there from San Diego to join us in some trail riding in NV. T is crazy about weight reduction on his car, says it's down to 3000#. For instance, the rear doors are gutted and the glass has been replaced with carbon fiber that's fixed in place. The five of us had breakfast and checked out the off road hall of fame. One interesting combination was a Jeep and a Rokon that had driven the Darien gap (first two wheeled vehicle to do so).
  5. I went on a 13 day trip of just over 5000 miles a few weeks ago. This trip report will be multiple posts and it will take me a couple days to put them up. Tuesday night I camped in Nebraska. Wednesday afternoon I decided to take a break from driving on the interstate and check out Sager's Canyon trail in UT just off 70. It was fun. Fairly smooth so probably recently graded, many turns and a few jumps. Part of it went through a narrow canyon and had a fairly steep climb out but nothing too difficult. At the top I got out of the car to try to hike to the top of the bluff but it eventually just became a vertical wall. Tried to get to a couple campgrounds in southwest UT just off the highway but they were closed due to a past fire. Took longer than expected to find another campground but I eventually did. I spent the next few days with my brother and a couple friends in southern CA. Meanwhile Z and B were driving B's blue long travel Forester to meet us near Vegas. On the way they stopped at Black Dragon Canyon for a lunch break on the UT/CO border.
  6. The later EZ engines with variable valve timing should have better low end torque, the little I've read about them confirms that. I haven't driven turbo cars much, and the ones I have driven/ridden in have been stock suspension. So I haven't really been able to drive them as hard as mine. From my limited experience I'd say a WRX/XT is similar to an EZ30 with a 5MT. A modified WRX/STI would certainly be faster, the only one I've ridden in certainly was but it only really started pulling hard over 3000RPM. So I would lean towards an EZ36, add a supercharger if that's not enough. Unfortunately none of the EZ cars came with a manual trans in the US and the auto seems to really sap a lot of power.
  7. That's an interesting comparison. It would be a lot less work to lift an Outback an inch or two than to start with a Legacy and replace all the struts and add subframe spacers. But if you can get a Legacy a lot cheaper maybe it would be worth it. I personally prefer wagons, from a quick internet search Subaru stopped selling Legacy wagons in 2006 in the US.
  8. Lifting a Legacy wouldn't be too bad if you can get them cheaper or less rusty than an Outback and get the EZ30 that way. I personally prefer Outbacks too but the Foresters do have advantages. My experience with an automatic Subaru is that it robs a lot of power but other people love them. I agree the 1.2 dual range would help but not much. The 1.6 often leaves you wanting more. I don't know why you wouldn't want a turbo Subaru, the increased power helps a lot in sand and other unpaved driving situations. Although the lag is annoying, they will build boost even at low RPMs if you're under load for a while. You're tired of me saying this, but I think a lot of the problems you describe are due to driving style. If you're driving slow, yes the VDC helps in two wheels up diagonal situations. You'll be slipping the clutch a lot in a manual transmission car too. If you just drive faster, momentum solves all those problems. I'm not talking 50mph, just enough to get over obstacles without stalling out. It looks like a lot of what you drive on is sandy; low weight, horsepower, and momentum is really the key in sand. If you're not willing to drive a Subaru that way and want to crawl, you really should get a Jeep or Toyota. I think you'd be happy with a Cherokee.
  9. I don't know much about the dual range transmissions, we've only had one. As far as I know they have an open front diff, viscous center and rear, so yeah, effectively 1WD in the wrong situation. I still think my Outback has too much traction more often than too little though. I've never driven an EZ with the variable valve timing, I assume it's a significant improvement. The first gen EZ30 is pretty quick with a manual trans but the auto slows it down quite a bit. Calling any stock Subaru a beast is an exaggeration though. The average street vehicle sold in the US now has 300hp.
  10. B's Forester didn't require any CV axle swaps on our long trip out west (more on that soon). Should measure angle at ride height again but it definitely rides and handles better with the softer springs. You were right about the strut tower. I've only dented/cracked those alloys in desert races. It's just a whole different level of abuse than trail riding. Thanks for posting your AR video.
  11. How much oil and coolant do you have to add how often? Liters/1000km? The oil leak might be valve cover gaskets, can't remember if you said you'd done those recently. Does your steering rack leak? It seems like they usually do. If it's a liter every few thousand kilometers I would just make sure you keep the oil and coolant topped off. I'm sure you're tired of me saying this but just keep it full of oil and coolant and keep saving money for a rust free car.
  12. I noticed both the front wheels on the Outback were cracked/dented. Let's blame that Texas desert race. This was the worst, I think this is one I hammered/chiseled in Texas to make it round enough to hold air. They still held air but I had them swapped out with some non cracked wheels. While we had the struts out of my black Outback one of my friends pointed out the RR wheel well / strut tower was starting to crack more. You should know the drill by now. If I keep this car for much longer I should really rebuild those more thoroughly and/or add some tubing. On our last trip a couple guys were driving my car in soft sand and before I could stop them there was clutch smoke coming out of the car (stuck in soft sand). So I figured I'd replace the clutch disc. Only one I could get in a few days was an ACT that's 228mm (stock is 225mm). Measured pressure plate, looked like there was plenty of room. Old one (Exedy, I think stage 1) actually measured within about .005" of new thickness but I put the new one in. Went to test drive it today and it would shift in all the gears with engine off but not with engine running (clutch pedal up or down). Clutch was moving the slave cylinder about 1/2" which I think is normal. Thought about it for a bit and then started it in gear with clutch and brake pedals pushed down. Started fine, made some noise, pumped clutch pedal a few times which made decreasing amounts of noise. After a couple cycles it seemed to work fine. Drove it for about 45 minutes in town with lots of stops and starts and seemed to work perfect. Couple times I applied some brake pressure and full throttle and clutch never slipped. Have driven it for hours now and seems to be working great. With some bushings and ball joints replaced, the car was much quieter so it became very clear that the RR CV axle was making noise under load. It's been making noise all summer I think, definitely on the last trip, so I replaced that and now the car is pretty quiet (compared to usual). Drives straight and vibration free on the highway which is a good thing since we plan on going on a long trip soon. Figured out the problem with the one radiator fan not working was a fuse inside the car in the small fuse block so that was a relief. Wired in a DPDT momentary toggle switch to manually operate the HVAC actuator. Have it wired in parallel with the stock control that seems to not work at all anymore. Pin 8 (red/black) is 12V ignition on, pin 12 (black) is ground, wired those to the center terminals of the switch. Pin 4 (blue/black) and pin 13 (yellow) go to the actuator, wired those to the other terminals of the switch so it can reverse polarity. Wanted to put it just below the cupholders but didn't quite fit. Seems to work but I plan on using it as little as possible to not burn out the actuator. Should have done this years ago. Ultimately I think if you had a strong enough HVAC fan you could just have it come out everywhere all the time and adjust the fan speed and aim the vents. Maybe even have the center vents spring loaded so they only open when the fan is on high. I also wonder if some new cars and/or any standalones have an option to cycle the AC compressor based on throttle position. Like with the AC on low it would only run the compressor at or near idle, with the AC on high it would only shut off at full throttle (yes I know most cars do that), some middle position it would turn on and off at half throttle, etc. B worked on his hatch and trim some more. I welded a tube to a bolt and a big washer to support the middle of his floor panel that goes over the spare tire well so he can put things in there aside from a spare tire that's smaller than the other ones on his car. Also drilled and tapped a hole in his bumper for a clamp bolt for a flag. He says the softer springs might ride a little better but definitely make the car more stable when cornering. CV axle angles didn't change much from the stiff springs which is weird, haven't check to see if or how much the springs we pulled out had sagged but it wasn't too much.
  13. Yeah, we all thought you'd like that one. Will have to take you there when you go to the UP with us next year. It's a long distance from the nearest pavement or campground host. While I had the suspension apart I replaced the rear bushings in the front lower control arms. I tried the Whiteline bushings again, I think they lastest longer than OEM and are cheaper. We went through all the struts on my black Outback and B's Forester. The main goal with mine was replacing some sloppy bushings, I also went through them and replaced some other seals and things. The main goal with B's was to put on softer springs to get it to sit lower and ride softer, they're about 2/3 the spring rate of what was on the car. C stopped by and replaced our windshields too. I bent the radiator support/skidplate down somewhere between 1/2" and 2" depending on how you measure it. Seems to have more engine to skidplate clearance which was my main goal. Welded those big rectangular tubes to the skidplate. One thing I added this time we didn't do last time are those square tubes to pull down on top of the radiator support tube. Without those you're just pulling down on the skidplate tabs. Both times we've done this we've stopped when the tabs start to rip that tube. I welded the cracks and stopped there.
  14. A few things with sand driving that became more clear after our last trip were: Power to weight ratio and keeping your momentum is most important. There was at least one loop we were able to do in the turbo Forester and the H6 Outback that the NA Forester just didn't have the power to drive around. Low range doesn't help much. On moderately soft sandy roads it was an advantage starting and stopping but on climbs it was no substitute for momentum and power. Lowering tire pressures seemed to help but we didn't do it enough to see how much. Over the weekend we did some work on the cars. My friend replaced the rear wheel bearing in his Forester that was getting loose. We pulled the exhaust, driveshaft, front axles, and transmission out of my black Outback. I was worried about the clutch so I'd ordered a new disc. The old one was almost as thick as the new one so I guess I have a good spare now. The hanger bearing on the driveshaft had a little slop so I put on a different used one that didn't have any slop. I replaced the other two u-joints also. One wasn't bad, the other one was notchy and one leg was badly brinnelled. I didn't get a good picture but you can see where the needles had dug into the leg of the cross: Put the driveshaft and transmission back in. Adjusted the parking brake. I still plan on going through all the struts before our next trip. Going to replace some bushings and tie rods that are sloppy. Exhaust is cracked so I tack welded it while it was in place, need to fully weld that now that it's out of the car. Messed with the fan wiring a bit. Both fuses blew when I drove it in the mudhole and I replaced them and they were both working. Later on that weekend I noticed the passenger side (sub) fan is not working. The fuse is getting 12V and the power terminals at the relays are getting 12V but the coils aren't getting 12V. So that might be difficult to track down. I'm also going to try to get the HVAC controls working, my current plan is to wire in a switch to control the actuator directly.
  15. Can you cut more out of the door and wheelwell without affecting the door seal? Might have to weld the door stampings together before you do that. That's always something I'm looking at on my car in case I want to go wider.
  16. Monday morning we took the highway south to the stunt area south of Seney. When we got to town we filled up in the gas station where we'd flushed out B's clutch on a previous trip. Got to the stunt area and M&B realized it was a lot bigger than the little section we'd looped around you can see from the dirt road. Drove back in it and through some big sand bowls and kept going to a big banked turn and hill climb. Climb wasn't as bad as it looked at first, B and I got up it on the first try but Z took it too easy on the first try and had to get a bigger run at it and made it to the top. From there it kept going, there was a little loop/bowl around a tree that I made but B got stuck in. Z pulled him out, ran the loop a couple times, and we kept going until we got to a different gravel road. Went back through the stunt area a different way to the dirt road. I decided to hit a small uphill jump. Got decent air at about 30mph but it was difficult to get a good run at it through the soft sand to hit it faster than that so we continued south, mostly off pavement down to 2. When we got back to pavement we cleaned out our wheels at an abandoned gas station (otherwise they shake from imbalance). There is an axleshaft poured into the concrete. M thought it was a cheap substitute for rebar. Maybe the person who put it there is trying to confuse the next species of intelligent life on earth in a few million years with this strange fossil. Got down to the test hill I wanted to hit but the path we normally take to get to it was blocked off and it would have taken a long time to “drive around the block”. At this point B was getting a shuddering in the rear of his car occasionally and noticed his RR wheel bearing is a little loose. We stopped at a gas station to make a decision, at this point we would be heading west to the super whoops so Z would probably have to backtrack to get home. He made up his mind with a coin flip that determined he'd follow us to the super whoops. We got some video driving alongside the Outback going through the little whooped out trail along the pavement leading to the ORV parking lot but it wasn't ideal since the grass in between the cars was pretty tall. We ran the super whoops a little and measured the larger ones. The rear end of the Outback was kicking up a bit on a few of them. We made PB&Js and at this point Z decided to follow us down through Wisconsin as it was probably faster than going back over the Mackinac bridge. Mike had left the burger patties for the trip in his apartment so we'd already decided to cook those in his parking lot before we all split up for home. Not far from Milwaukee we saw an Outback XT with some mud on the sides towing a teardrop trailer. We kept seeing it when we were stuck in a slow moving traffic jam. When we pulled off the exit to go to M's apartment they followed us. We were wondering how long they were going to follow us so I rolled down my window and waved for them to follow us around one of the last turns. We introduced each other and we invited them to join us cooking out. The husband had built the trailer about five years ago and it was still very nice. He'd also done some modifications to the engine of his XT running E85 and 22psi of boost. They had some brats and veggies that were added to the menu and they stayed for hours as we all eventually left for home. Overall a good trip, cars all held up pretty well. The guys learned one of the reasons we made better struts. Outback went through 1.5 quarts of oil. Have seen a few clouds of oil smoke at startup in the last month including one when I parked the car with one side jacked up overnight on the trip. On the plus side the last couple times I checked there is no noticeable blowby now and it ran fine all weekend so I'll probably leave the engine in at least for the next trip. Plan to replace the other u-joints in Outback driveshaft. While that was off I noticed there's quite a bit of backlash in the rear end so I want to check that out. RF CV axle made noise all weekend and LF was leaking grease by the end so those both need to come out. Clutch got used hard so while the driveshaft and axles are out it's not much more effort to pull the trans. Need to adjust parking brake. One radiator fan is rubbing on housing and the other one wasn't working despite having a good fuse so need to check those over. HVAC controls still not working so I should sort that out. Need to replace at least the RR wheel bearing on B's car. Really needs softer springs to lower it before our next big trip so we don't have to take a dozen spare CV axles with us. We now know that the ball spline axles are junk. Still need to get the center blockoff plate mounted to Z's bumper, he ran out of time with the sanding and painting on it and putting the bolt on wheel bearing front spindles, smaller front brakes, and 15” wheels with mud tires on his car.
  17. View from our campsite Sunday morning: In the morning we packed up and headed west. Took a washed out road down to this river. The climb back up was challenging but not quite as bad as it looked. A got the Outback stuck on a stump near here and Z decided it was a good place to get a picture. Again the Foresters were starting to run low on gas so after some trail riding we went to Grand Marais on the highway. There was a triathlon and possibly some other things going on in town so it was pretty crowded. This guy was directing traffic with a stop sign he'd pulled out of the ground. We got gas, ground beef, beer, etc at the gas station. This guy was selling dreamcatchers and other things out of his Cherokee. Don't worry, the interior was also spray painted gold and decorated with drift wood. Then we decided to just run the highway down to the bar and unload some of our stuff there. It was early afternoon and I'd seen some trails and lakes just east of the bar so we wandered in that direction for a few hours. We decided to hit the wheelie jump and C's pond and see if we could get through on some roads that were flooded in June before we went back to the bar to cook dinner and settle in. We were able to easily drive through C's pond and continued west. Neither road that was flooded in June was flooded at all and I decided to head north to go back to the bar on a smoother gravel road than the whooped out snowmobile trails we'd been on. When we turned around D got the Outback stuck in the soft sandy road temporarily and I was able to barely drive it out on my first try. Z also had difficulty but B had an easier time due to the low range. When we got back to the bar we raised the passenger side of the black Outback with the jack again and M took the nut and washer off the end of the control arm and I ratchet strapped the wheel forward and he packed the remains of the bushing with RTV to try to minimize the slop and noise. Put the washer, nut, and cotter pin back on and left it to cure overnight.
  18. Soldier lake Saturday morning: In the morning we paid at the honor box and trail rode up to the giant hill climb we'd found a couple years ago. Pictures really don't do it justice but this is the top. We stopped at a park just west of there, walked down to the beach, went to the bathroom, and then drove across the highway to ride trails west. In the distance in this picture you can see the bluff that the hillclimb goes up. After a while we started hearing a bad clunking noise from the rear of the Outback so I got out and watched M drive a bit, sounded like it was coming from just in front of the rear suspension. Figured out it was a bad u-joint so we got off the trail, jacked up the car, and M pulled the rear half of the driveshaft. The cross had actually broken and at first I was nervous but then remembered I had spare u-joints so I swapped it out and we put it back together. These have been in the car for about five years. The downside is since the cups are thicker walled than stock and the cross is hollow it's weaker than stock. The upside is that it's easy to replace on the trail. The u-joint at the trans seemed loose too but we decided to leave it and it lasted the rest of the trip. Later on D was driving my Outback with M navigating and they hesitated to make a turn and got stuck in a soft sandy intersection. I told him to stop trying to get out when smoke was coming out from the clutch and the car wasn't moving much. We aired down the tires to about 15psi and I drove out on the first try. I think it was in this section I got the Outback stuck in a big mud hole that B bypassed in his Forester and pulled me out. It was halfway up the door on the driver's side, not quite as deep on the passenger side. There was another even deeper mudhole ahead and I think due to this blockage we had to make a big detour around to get to our campsite. After a while I noticed the temps were creeping up a bit and the fans weren't running, both fuses were blown. There were only a few spares under the fuse box cover so I put in a 20 and a 30 and the 20 immediately flashed out. Later in the day someone noticed there were occasional rubbing noises in Z's Forester. Both rear spring perches were shiny and the tires were extremely close to the strut tubes and spring perches so the rear struts had probably bent a little. We jacked up the car, removed the wheels and tires, and Z hammered the spring perches. I think about this time I aired up. We eventually headed back north up another highway towards the campsite on the bluff I wanted to stay at on Saturday night. When we were within about 20 miles we rode various trails for an hour or so on the way to the campsite. I was relieved to see it was unoccupied on Labor day weekend and the guys who hadn't seen it before thought it was awesome and worth the drive. After we'd been there at least an hour, someone drove there with an FJ cruiser and turned around, they may have planned on camping there and fortunately we'd gotten there first. A cooked dogs, we set up tents, I started to replace a control arm bushing that was blown out on the Outback but then stopped when I realized my spares were pretty rough too. I left the car jacked up on the side to help drain mud/water out of it and left the doors and hatch open overnight. I dug out a few more 30 amp fuses in camp to put one in to power the fan and put a couple more in the fuse box cover for easy spare access. After we'd set everything up and eaten dinner and were hanging out around the campfire I saw a few people down on the beach a half mile away. Eventually one guy with a purple/UV flashlight was slowly heading towards us along the beach. A few of us walked down to the beach to see what he was doing. He was concentrating so much on looking at rocks with the flashlight he didn't notice us until we were about twenty feet away. He was a typical old yooper guy and explained that someone was trying to find an easy way to find agates (a semi valuable stone found along Superior that's often sold in gift stores, etc) and tried using a UV flashlight at night about a month ago. Didn't find agates but started finding rocks with portions that glowed under a UV light. They sell them as yooper rocks in the gift stores and on ebay and he was saying a rough one about an inch across goes for about $25 on ebay. Sounds like they get cut, polished, and made into jewelry (earrings). After talking with him for about five minutes he asked if we had any pot. Must be a side effect of UV light. We all laid down on the beach, looked at the stars and milky way and small northern lights since it was a clear night and talked for about a half hour.
  19. Drove up to the UP over labor day weekend for some trail riding and camping. Most of us met up north of Milwaukee at M's apartment Friday morning. As we and Z were all getting to the UP, B said that we should replace one of his CV axles that was making a ton of noise. It was the front ball spline axle, we replaced it in a gas station parking lot east of Escanaba. The inner CV housing was blue but the boot was intact. Met Z in Naubinway around 1 or 2PM EST. This is how his bumper turned out: Used PDF of Mackinac county on Avenza, sort of useful. One issue was that your location on the map is just indicated by a small gray circle. There is a small arrow next to it to indicate direction but it seemed to point the opposite way of where we were going. I did use both tablets for navigation using mytrails most of the weekend with two different maps at different zoom levels, that was more useful than just one. We hit a lot of overgrown trails or trails with trees fallen across them that we cleared out and eventually connected to other trails, where they normally seem to dead end. Also found a bunch of stunt areas, at least four. At one of them a pair of women we'd seen hiking along the road walked by and one of them commented on how she had a Subaru and shouldn't have to worry about getting stuck in the snow after seeing us driving in soft sand. B tried the low range but it just got bogged down. Not many jumps or whoops this weekend but lots of fun sandy trails. Camped at Soldier lake Friday night, came in off some narrow trail to find out the campground has a paved loop and running water. Nearby are east soldier lake and a small lake called toy soldier lake. Fortunately we found a site that wasn't reserved for Friday night fairly close to the pit toilets so we camped there. A cooked burgers while we set up the tents.
  20. While the engine was out of the white Outback I tested out whether the H6 engine mounts can simply be switched side to side to provide some engine setback. This is how they look in the stock orientation: The bolt holes don't quite line up on the engine if you put them on the opposite side but a little slotting would solve that. I think the pads that bolt to the engine are not parallel to the pad that sits on the crossmember so it would put some stress on the rubber when the nuts are tightened. The pads don't sit flush on the crossmember when switched side to side either (or I would have taken a picture) but that could probably be fixed with some hammering. Swapped some other parts over to the engine and trans from the parts car. J stopped by Saturday morning and helped me get the engine and trans in the car and mostly hooked up. He left just before B got to town. B called saying that he'd blown up the ball spline rear axle just as he got to town. Balls and pieces of cage fell out when he reached under to feel how badly it was shot. I loaded up the towbar, lights, and chains and drove the black Outback out there to tow him back. Just before I got to him the engine started running rough again. I let it idle and tried plugging the coil packs back in, one of them seemed to smooth it out a little and it's been running fine since but had no unusual trouble codes (always has torque converter and evap codes now). First we finished hooking things up on the white car, started it up on stands. I'd forgotten to connect the trans cooler lines at the trans so that puked some ATF out before we noticed and shut it off. It took almost twelve quarts of trans fluid to get it full while running. While we had the front suspension halfway apart and CV axles out, we decided to put on bolt on front wheel bearing knuckles (thanks Slammo). I had one new wheel bearing and one with about 12k miles on it from the black Outback with no slop. Antiseized bearings and new ball joints in them, had to turn up a couple sleeves for the top eccentric bolt (I have long travel struts set up a little different than stock with two modified eccentric bolts). The front dust shields were rubbing badly, bent those in as best we could with everything assembled, but the driveshaft was rubbing on the exhaust under engine or wheel braking. I vee cut the exhaust where it was closest to the driveshaft and welded it back together so it has at least an inch of clearance now. Over the winter I'll probably replace that center section of the exhaust with something stronger and replace the engine and trans mounts. Other than that it seems to run better than the old engine. Haven't driven it fast yet to see if it downshifts smoothly. Thinking about putting a JDM engine in the black Outback before a week long off road trip (or two) we're planning this year. The blowby worries me a little and I'm not positive I've solved the intermittent rough running when warmed up symptom. Tempted to put in an EZ36 but probably won't. Anyone know how worried I should be by the blowby and if there's something else I should check that would cause it to run rough sometimes when warmed up but not throw a code?
  21. Some tips on replacing an EZ30 and 4EAT in a 2002 Outback (all stock): Move the large AC line along the firewall out of the way. Managed to pinch that a bit between the pitch stopper brackets when removing engine and trans and it started leaking where the hose is crimped to the line. Fortunately I have one from a parts car. Drain the trans. I had a drain pan under the tailshaft when I pulled the driveshaft out and at first nothing came out. Unfortunately to remove the engine and transmission I had to tip them at about a 45 degree angle which caused a few quarts of fluid to drain out. Some of this of course happened as I was moving it forwards and I didn't realize it wasn't all draining into the pan. Also, what I'd recommend replacing while it's out: spark plugs valve cover gaskets - these always seem to leak oil cooler gasket (orange o ring between cooler and block) - this leaks even more consistently 21370KA001 coolant hard lines and hoses on the bottom of the engine for oil cooler and heater hose - in the midwest these tend to get rusty, not too expensive from the dealer 807611060 99078AA110 807611071 21328AA053 14165AA014 807615030 thermostat and gasket 21200AA072 21236AA010 heater hoses - I've had one of these spring a leak on my 99 OB, the protective sleeve they put around them is a good idea but seems to make them dry rot underneath 72411AC020 72421EA02A I also replaced the trans filter inside the oil pan. There was some metallic debris in the pan but the screen filter was pretty clean. The radiator upper water necks are turning white too, not sure if that is a problem or not, but since it's probably the original radiator I'm replacing it and the radiator hoses. EDIT: I would also recommend getting new engine and trans mounts, especially if you are using the car off road. Both trans mounts were split but they have a stud with a rubber faced washer and a nut holding it from moving too far. All the engine mounts for these early EZ30s I've had off are either already split or cracked, some of them you could pull in half by hand. The engine mounts on my 2002 white Outback weren't too bad but I should replace the engine and trans mounts over the winter. At the same time I'll probably make a heavier duty replacement for the middle section of exhaust.
  22. Trimming the stock bumper cover is a good idea, especially if he doesn't add lights between the bumper and headlights. Good point that if the bumper was body color it would really show the gap between the trim/fenders and bumper. Everything is 1/8" thick. Mild steel tubing 4"x4" and 2"x4", 4130 plate.
  23. It would be more sano but we figured when the bumper shifts around it would break the grill and trim. Also the grill probably hangs within an inch of the top of the bumper. He's also thinking about adding some lights or small light bars between the bumper and headlights. He's trying to decide what color to paint it. The rear bumper and all the trim is body color so that's my vote. He's got some gold wheels he's going to put on and thought about painting the bumper gold. We talked about painting it black too and/or using a bedliner (rough) paint. Thoughts on that?
  24. Thanks. It's not as heavy as I thought it would be, I took it off by myself pretty easily after welding. Obviously much heavier than the stock aluminum extrusions and plastic cover though.
