55
Everything posted by pontoontodd
I have a 2002 OB with EZ30 with over 240k on it. I've had it for about a year and 15k miles. The whole time it's been consuming coolant at the rate of roughly a quart per 500 miles. Basically every couple tanks of gas top it off, doesn't overheat if it stays mostly full. Doesn't use much coolant at all when my wife is driving it around town. I have a 1999 OB we swapped an EZ30 into, also about a year ago, and I've put about 20k miles on that. The first engine from the original donor car was leaking like a sieve from about a dozen places. The next one seemed to have the normal slow coolant losing head gasket leak and supposedly under 100k miles from a junkyard. Got them to replace that one with one with supposedly 80k miles on it. Same deal with that one, and it leaks oil. The oil leak is not really while the car is running, most times if you let it sit overnight there'll be a couple little puddles of oil under it. We have plumbed the coolant system to purge itself of air and I haven't had to add coolant in a long time, but not really a long term or universal solution. I just purchased a 2001 OB with EZ30 with 156k on it. Has the same oil leaking issue described above, seller estimated a quart per month of normal driving. He says the mechanic he took it to said it was the head gaskets. So eventually I may wind up doing the head gaskets on all three of these. Thought about just replacing them with lower mileage used engines but didn't have any luck with that for my 99. I've heard the timing chains last forever in these things, what would be worth replacing while the engine is apart? Water pump, head and valve cover gaskets, spark plugs, radiator hoses, timing chains/guides? I've read elsewhere on this forum that the heads and/or blocks are basically always warped on these by the time the head gaskets leak. Is that true? That changes this from a weekend project to an engine build and waiting for a machine shop to flatten things.
Make sure both cam pulley marks are lined up with the covers. That's the easy part. Since it's not interference you shouldn't have to worry about bending valves by turning various shafts independent of each other, but if you suddenly get a lot of resistance, stop. The trickiest part is to line the mark on the crank pulley up. It's not the super obvious arrow. There is a small hash mark on the flange that needs to point up at a non obvious hash mark.
A couple weeks ago, when the engine was cutting out, I heard a bad noise during very hard cornering and acceleration in a rough turn or two in the 99 Outback. Looks like the u-joint at the back of the trans hits the driveshaft strap under extreme loads. It's probably an inch away at rest but that trans mount is soft. Need to bend that strap down. You can sort of see it in this picture. Replaced the head gaskets in the Impreza last weekend. One thing I've been impressed with in every Subaru engine I've done head gaskets on is that you can still see the cross hatching in the bores and the ring gaps are tiny with a quarter million miles on them. There were a lot of little dings on the quench area of the heads. Those must have been caused by something the previous owner did. Head gaskets definitely looked a lot different than the new ones but I'm used to the MLS gaskets so I don't really know what bad looks like with these. While the engine was apart I replaced the timing belt and clutch release bearing. I put everything back together and as I started filling up the radiator it started leaking out the middle of the core. If you saw this radiator you would be surprised this is the only leak, but the strange thing is that it wasn't leaking when the car was running. Some piece of debris must have been clogging the hole and fell out when I drained it. Also the battery isn't quite enough in sub freezing temps. So I got a new radiator and battery. If I'd known all that I don't know if I would have done the head gaskets, it's a great car but probably not worth spending a few hundred bucks in parts and a few days fixing it. On the plus side it seems to run fine now. Drove it for a few hours today and no overheating or coolant loss/overflow. Really need to find another rust free H6 car.
Thanks for this tip, if it acts up more I will check VSS wiring. Saw another thread with I think an EZ30 that would cut out at 4000RPM tied to a VSS issue. Thanks for the tips and links. Drove the 99 Outback down to southeastern Illinois over the weekend. Cruise worked pretty well, shut off at most once an hour on the highway. Engine ran fine and never cut out all weekend. Mainly 100s of miles of interstate driving but at least 100 miles off pavement. I'd tried something different with the front struts but it didn't seem to work as well as before, so I'm going to put it back. We did see some cool ice though. Indian Kitchen: Secret Canyon: arch along entrance road to Garden of the Gods: Pounds Hollow:
Battery in my 96 Impreza died, looking for a replacement, even the cheap ones aren't cheap. I have an Odyssey in my Outback and it's great but I don't want to buy another $300 battery. Local Subaru dealer wants $124. Rockauto sells a Deka Intimidator for $175. Considering a junkyard battery, don't plan on keeping this car for more than a year. Any other deals out there? Sooberoo - did you make sure the battery light comes on when you turn on the key? My friend had problems with one alternator that wouldn't charge since he had LED bulbs for some of the idiot lights and that was enough of a change to keep the alternator from charging. Check voltage at the battery, not the alternator, with the car running and making sure it's at least 14. Also, your brake lights shouldn't be a high current load.
- 17 replies
- old
- AGM battery
(and 3 more)
Tagged with:
The expansion valve has just two connections and some kind of metal diaphram looking thing with a copper tube that ends in a bigger copper tube clamped to one of the lines. Presumably some kind of temperature compensating orifice. I have no idea if or where there is an inline filter. I did not flush out the evaporator or condenser. I would think any added restriction from a clogged filter, evaporator, or condenser or collapsed tube would give me more pressure drop than normal, not less, but I guess that's why I'm asking.
Cruise is still shutting off on me occasionally. The light on the button turns off, it's not just cancelling. Is there a relay for that aside from the one in the cruise computer? I tried a different cruise computer from a junkyard and it does the same thing. I replaced the expansion valve in the AC system and there is still no pressure difference between high and low side with the compressor running. Could this be caused by insufficient oil? Or should I get a different compressor? For a few days the engine was cutting out at about 4000RPM in first gear at full throttle, like you turned off the ignition. Never at part throttle or any other gear. Cleared trouble codes and hasn't done it since. Been messing with some other minor things and waiting for some shock parts to try something different. Also getting serious about finding another rust free H6 Outback with under 150k miles, preferably 2001-2004 non VDC.
How much longer do you think it will be until you drive it? Looking good, love your paint booth!
'01 outback 2.5AT, VDC offroad/ overlanding build
pontoontodd replied to scalman's topic in Off Road
It looks like you should make your skidplate wider to cover the exhaust if you're worried about it. You could probably just add a piece on each side to cover each exhaust pipe. Attach the outer ends to the old swaybar mount brackets. I have heard the European market Outbacks have the exhaust going over the passenger side of the engine crossmember like the turbo cars. If you can get one of those manifolds or something from a WRX (a lot of people upgrade their exhaust, you might be able to get a stock one cheap) it would help. The part of the exhaust that runs along the trans and driveshaft is probably going to be one of the lowest parts of your car no matter what you do. I wound up replacing the section of mine from the cat to the rear diff with 2.5" .095" 4130. Kind of overkill, but more practical than trying to make some kind of skidplate for it. Only one dent so far. -
You probably know this but I think the BRZ trans is completely different than the 6MT in the STI. Stock BRZ trans is good to about 400hp. If you've got a t case after it, it will probably last a long time. Anyone ever mess with alternator wiring? Mine works but can't keep up with a half dozen 55W HID lights and the AC/radiator fans. It's supposed to be 90A stock. The wire plug has three wires. One is 12V just fused to battery +. Another is switched 12V with ignition. The third one is an open circuit last I checked. My friend tells me that is some kind of load circuit and he's read depending on whether you ground it or give it power, it changes the output of the alternator. Cruise is only staying on for short periods of time while driving now. Couldn't find any relay that powers it aside from the one in the cruise control computer, so I've got one of those coming in to try. It will stay on indefinitely with the car parked and ignition on, engine not running. Doesn't turn off when you shake/tap the cruise computers, so maybe it's not that. Still haven't decided what to do about AC, same pressure on high and low side with compressor running. I've tried both H6 compressors I have. Any thoughts on that? Could the orifice be blown out? Where is that, mounted to the evaporator?
2002 EZ30 H6 into 1999 Outback swap
pontoontodd replied to pontoontodd's topic in Subaru Transplants
Went through this and my notes and I think all the information is here now, added a few things to the first post. -
I really think you want some kind of square tube lifting part that goes on the hi lift, square tube receivers in the frame, and maybe even a locking pin that goes through them. Like a trailer hitch. I would just use those, you could always mount a winch or something to them later. The square tubing will keep the jack from tipping over and the pin will keep it from sliding out. If you put one near each bumper frame mount that would probably suffice. You could put them on the sides of the car too, if you do I'd get them as close to the suspension mounts as you can and notch the pinch welds so they don't hang down. -
Thanks. I think you're right about the Subaru being the jack of all trades and master of none. Several of my friends have commented they don't know of anything else that can cruise comfortably on the highway, drive off pavement all day fairly well, and drive back home with (usually) no major problems. It is definitely a compromise between road comfort, high speed off road capability, and low speed rock crawling. Even deciding how wide a rig you want is a compromise between being able to do narrow trails or go in between big rocks and having more suspension travel and being more stable. At the moment I've decided to stick with what I have. Where we live we have to drive 300-2000 miles to get where we want to ride off road, so it has to be good on the highway. I'm not excited by rock crawling or mud bogging so I don't need giant tires and a lot of clearance. It would be cool to go faster over rough terrain but the current suspension is good enough to be fun, and I think we can improve it more. One of the biggest improvements we could make to the cars would be the 6MT/R180 with a lower first and second. You really can't beat on the 5MT and R160 with the H6 and big aggressive tires or they will break.
Makes sense on the T100. Yes, better dampers and better tuning make a huge difference. Ours are built around Fox shocks with reservoirs, which are considered some of the best in off road. I think they're tuned pretty well right now, no comparison to stock in terms of ride quality and durability. I didn't notice much difference in ride between the a-arm setup we made and the struts we have now. There is probably still room for improvement in tuning. And I have some ideas we're going to try soon to improve them further. If you haven't seen what the top Dakar racers can do with 12" or less of suspension travel, you should, they are amazing, but the 2WDs at least have larger tires than we do, which helps. All that said, something with well tuned shocks and 12" of travel will never be able to keep up with something with 18-24" of well tuned travel over rough terrain.
So I charged the Impreza battery this morning but it still wouldn't crank. Put in the battery out of the donor Outback and it fired right up. Drove it for at least an hour around town, with a half dozen stops but none of them long. Never overheated or puked out coolant. When I first got home it was bubbling into the overflow, maybe a bubble every five seconds. Used the magical test fluid and that never changed color, but after it sat and idled for a bit it stopped bubbling too. So I'm guessing the head gasket(s) are starting to go but aren't too bad at the moment. Might do the head gaskets this weekend. While I was driving around some guy pulled up and asked if I was looking for another Subaru. His daughter was driving a 99 Outback and rear ended someone. They had supposedly just done the head gaskets, exhaust, timing belt, rotors, tires, and heater core, it has 118k on it, 4 cylinder auto. I checked it out, it would need the lower radiator support pulled forward and a new radiator, but I have a couple of those in my basement. It has a good set of snow tires and alloy wheels. Clean cloth interior, smells like they smoked in it. It's about as rusty as most Subarus that age around here, body doesn't look too bad but probably half the bolts would break off the first time you tried to turn them. All the CV boots look good. He wants $600. I'm tempted to buy that and scrap/sell the Impreza. I really need to get another rust free H6 Outback. Still would like feedback on cruise control and AC issues with the 99 Outback.
Hahhahahaha. You're obviously not American or you'd know more and bigger is always better! Seriously though, there are times when we have to slow down because the trail is too rough for our current suspension. Not anywhere near as bad as the stock suspension. In something with say 20" of travel and 33-37" tires you could go much faster over rough ground than we do. As an extreme example the winner of the Vegas to Reno runs it at twice our average speed. There are street legal prerunners that are basically a trophy truck with air conditioning, so that's not just race cars. The bigger reason would probably be to get a real low range/lockers, bigger tires, and more interior room. It would be nice to have a large enough area behind the front seats to sleep comfortably.
The cruise control is mostly not working now. For months it has shut off every hour or so. Now it's every minute or so, sometimes the light doesn't even come on when you push the main cruise button. I have the button from the 2002 donor, going to try that first. Then try to find the relay. Hoping it's not a wiring or signal issue. Anybody have this problem before? Also still wondering what would cause the AC pressure to be same on high and low side other than compressor not compressing, any advice on that would be good too.
The STI axles aren't much longer, less than an inch if I remember right. Just making longer axle bars isn't too expensive, the real problem is to fit longer axles in most IFS trucks or FWD cars you have to widen the suspension too, so the thing winds up seven feet wide to get a decent amount of travel. Probably not a big deal out west, maybe even desirable, but a lot of the trails east of the Mississippi are tight. I've thought about those Toyotas. They are generally reliable, and as you say you could get the sort of transfer case and lockers you'd want. You can obviously fit bigger tires. And you're right about the shocks being much cheaper/simpler than struts. We are already making 12" of wheel travel though. The Toyotas don't have much power stock, even with the six cylinder, and according to Wikipedia the 4Runner is a foot shorter than the Outback. Overall it would probably be cheaper than what we've done with better crawling ability but a worse power/weight ratio. I would like to get a ride in one of those. What 4.3 do you have in yours, GM?
Front and rear it would be easy to have receivers that wouldn't hang down. On the sides you could put them right where you're lifting the car in the pictures, the stamped "frame rail" hangs down a few inches there. You would have to notch the pinch weld. -
I assume you will make a larger platform to attach to the bottom. One thought I had if I got one was to put specific lifting points for it on both sides and front/rear of the car. Since I already have 1.25" square receivers in front and rear, I would attach a 1.25" tube to the lifting arm of the jack. That way the jack is less likely to tip over.
