pontoontodd
Everything posted by pontoontodd
  1. This is judging by wire colors, you might want to unplug the relay and use a probe to verify. There is a row of four relays and a pair of relays. It is the last one in the row of four closest to the pair. It is labeled AC #4 on the fuse box cover.
  2. Thanks for this info, makes sense now that I look at the fans, wiring, and wiring diagram. So it seems from testing them and looking at the diagram that both hot leads need power for high speed, the black one is ground as you say. I've had issues with at least one pin on the fan connector failing and overheating when running hard. When it ran hot it looked like the fans may have just been running at low speed once I got them both working. Can I just wire both + leads for both fans to a switch on the dash as an override? I'm thinking straight from the battery to a 30 or 40A fuse, to the switch, back to all four fan wires. Or is there a good fused lead I should splice into? This would run both fans on high regardless of some sort of sensor/ECU malfunction, relay failure, or another fan connector gone bad. But they will still come on and off normally with the switch off.
  3. The easiest way to get a 2" lift is just to add strut spacers. They're easy to make or you can buy them. The car right now isn't lifted much more than that. We've made completely new struts and front control arms. The focus was more on increased wheel travel, strength, and ride quality than lift. That all starts here: http://www.ultimatesubaru.org/forum/topic/144953-99-outback-build-advice-wanted/page-4?do=findComment&comment=1268549 The race in Texas was at a private ranch. They only allow race cars and trucks on the course during that weekend. I know there are some off road parks in Texas, there is a soft roader club that goes to them occasionally, a bunch of them have Subarus. Otherwise check out http://www.riderplanet-usa.com/atv/trails/texas_list.htm They list which parks allow 4x4 / street legal trucks, how big they are, what kinds of trails, etc.
  4. We talked about that, not sure how much it would help. Yes, just the stock fans right now. They seem to be working but their speed isn't very impressive. Are there any fan upgrades I should look into?
  5. Our friend who knows a lot about rally cars thinks our overheating problem is airflow related. He says when the front bumper cover gets ripped off the car will usually overheat. Here is what the front end looked like before: We decided the stock bumper support and the HIDs were blocking a lot of airflow so we should move them. The bumper support was really just a place to screw the plastic bumper cover to when I'm driving around town. We drilled out the spotwelds to remove that. We can just weld some posts on the square bumper to remount the plastic bumper later. There was just enough room under the stock headlights for the HIDs. Pattern is still good. The next step was making an air dam to keep the air from spilling under and around the sides of the radiator. This is before we peeled the covering off so you can see what it looks like. There is a strip of black rubber molding around the edge so it doesn't cut into the condenser. Here's what it looks like now.
  6. Here is a short video I put together of parts of the fifty mile course in Texas.
  7. 100% apparently. I thought since it's rated for 2.5 tons and the front of the car is about 1 ton I'd be safe, but no.
  8. I looked into long distance towing and I could get the Subaru towed back from just about anywhere in the US to my door for about $600. We spent more than that in fuel in our truck getting to Texas and back. It would be inconvenient but far cheaper to get it towed back from somewhere than buy, fuel, maintain, license, and insure a tow rig and trailer. Finally took a picture of the knuckle that the interstate did some grinding on. This is after our repair in Texas, which held up for a couple thousand highway miles and about fifty miles offroad. Swapped it out with a different knuckle when we got home. Also, that HF scissor jack folded while jacking up the car the other day:
  9. How does it compare to some of the videos I've posted, like in Kentucky? Any pictures or videos of particular rough sections in Nevada? Just trying to see what we're up against. Like I said, one guy we talked to in Texas said the V2R is much smoother than the course we were on down there. I've talked to other people who thought parts of it would be rough in our car but that we could make it.
  10. Yes, it would make more sense to me to cover the flywheel and clutch. They want it covering the part of the trans with gears. I have never heard of the gears in a Subaru trans exploding but those are the rules. Also, it's hard to tell from those pictures but it does go forward to the firewall.
  11. Working on replacing the RR knuckle we had to repair in TX. I had another one from a parts car that to my knowledge was not abused at all. It had a small crack in it at the base of the strut mount just like all of mine did. Ground it out and welded it up. Got the old one off the car which was a PITA since the long bolt had rusted into the front bushing. I know I've had it out before and anti seized it but I still wound up wrecking the bolt getting it out. So I'm waiting for one of those. Anyone know of a stainless and/or high strength replacement for those? Or some other solution, such as RTVing that central pocket so it won't rust as quickly? Got this scissor jack from Harbor. It's 2.5 ton and meant for leveling trailers. Relatively light, fast and low effort and lifts about 24", more than enough even with the long travel. Can use a cordless impact for more speed, it's even 19mm hex like the lug nuts. Just have to find a good place to put it in the car and do something with the top and bottom pads. I got a dust cover for the bottom of the bellhousing from the dealer for $7. Unfortunately there is a giant window in the bottom of it??? So I cut, bent, riveted, and RTVed a piece of aluminum sheet metal on the bottom of it. Not pretty but it should keep the grass out. It also doesn't cover the notches in the engine block on either side of the flywheel. So I RTVed those too after I bolted it in. Here is a bad picture of it installed. While we had the trans out we made a scattershield for the trans from 1/8" 4130. They don't care in TX but we'll need it for BITD (Vegas to Reno).
  12. My 2c, next time you decide to do a project of this magnitude, it would probably be easier and stronger to just start from scratch. Ideally you would build a full tube frame/cage, but you could just have a basic ladder frame connecting the suspension and drivetrain mounts at the ends and then mount a shell on top so you can make it street legal. It usually only takes a couple guys a few weeks to build a tube frame. I think the frame would be stronger and it would probably take you less time overall. Easy for me to say that now.
  13. We've never had to tow any of our Subarus home after years of beating on them offroad. Again, not saying it won't happen, just doesn't seem to happen often to us. I will see if I can borrow the tester that goes on the radiator from a parts store. I have compression and leakdown testers but they would be a PITA with this engine. I do keep thinking about the H6 swap but I think if the engine came out I'd just do rings, bearings, head gaskets, and get a low end profile ground on the cams. At this point I'm just waiting and saving for a third gen OB so I could get the H6 and bolt on wheel bearings. Each lap is about 47 miles long. The race is five laps, so almost 250 miles.
  14. The outside of the brake disc was starting to get ground but wasn't too bad. We've talked about trailering it a lot. Normally it's just one to three Subarus. So we'd need some kind of tow vehicle and a trailer, which I don't have the room for, and then we'd have to buy and maintain those too. Our philosophy at the moment is that in the long run it will be much cheaper to get the Subaru towed back home once a year or two, even if it's a $500 tow bill, than to invest in a truck and trailer. We don't often use the box truck to tow the Subaru. It wouldn't notice the extra weight of a trailer and it would be a little safer. I already ordered a bellhousing dust shield from the dealer, but you are right about having some sort of skidplate below that. The overheating could be a head gasket issue. In the last six months I have had to add coolant to the radiator a couple of times and the overflow seems to occasionally puke a little coolant out. So I'm not sure if I'm overfilling it or what. I think the radiator cap was bad, replaced that recently. How would I know the headgasket(s) are bad? PO claimed they'd been replaced. The course was a lot of fun. Really about perfect for what we're doing, challenging but not too difficult that we didn't think we'd make it. I'll put up video eventually. I didn't hear about anyone running out of gas. The loop was about 47 miles and at the 17 mile mark you went back by the pits. I think almost everyone there besides us had raced there before and knew what they were doing. Most of them had 20++ gallon gas tanks. We burned about 5 gallons of fuel in one lap in the OB and about 8 in the buggy.
  15. Sounds like a simple solution, might even just be able to use one of the three bolts already holding it in. Wasn't a problem last weekend.
  16. We need to see pictures and videos of this thing off road. Should be awesome.
  17. Found out a couple days before we left that the course in Texas would be five laps on a 50 mile loop (instead of a 20 mile loop). Still decided to go. We left town Wednesday morning flat towing the Outback with our truck. Somewhere north of Joplin MO we saw a giant shower of sparks and smoke in the mirrors. We pulled over and the Outback was missing the RR wheel. Three of the wheel studs were broken and one of the other two was bent. I assume the lug nuts all came loose somehow, at least two fell off, and the rest were loose enough to eventually snap. The pavement had ground at least a half inch off the bottom of the knuckle. It was cold and dark and we clearly couldn’t move the car until we did something about this problem. At that point I thought we’d have to get the OB towed somewhere and either go home or continue without it. Fortunately I had brought a new rear hub so we knocked the studs out of that and got them in the old hub after taking the brake disc off. We strapped the trailing arm to the knuckle so the bushing wouldn’t fall out the bottom, put a wheel and tire on and continued our trip. For the rest of the trip every time we torqued the lug nuts on that corner they turned some before being tight. We were torquing to 80 ft-lbs and later one of our friends said we should be going to 95 ft-lbs. The next morning we picked up more lug nuts and wheel studs at two parts stores. When we got to the pits at the top of the hill, we could look out and see flat desert for miles. It was clear why the closest town is called Notrees. Fired up the generator and cut a few pieces of steel to weld to the bottom of the knuckle on the OB, pressed the bushing back in, and put a different trailing arm on it. Everyone crapped their pants when they realized we were planning on racing the OB. They thought it was great. They also had no idea what class it would be in. I had figured class 10 (four cylinder water cooled) or heavy metal (stock frame rail truck) but they thought air cooled might be more appropriate speed wise. Before 2PM people started pre running so we got suited up and went out on course. I drove and one of the guys we've raced with navigated for me. With his help I was able to follow the course. About ten miles in the coolant temp started creeping up and eventually got to about halfway between the middle and the top. We pulled over and found out one of the cooling fans wasn’t working. We stuck the windshield washer pump hose in front of the radiator. Then every time it started climbing I would hit the washer pump and it would go back down. They had the course laid out so you went by the pits at mile 17 so we stopped. We figured out one of the pins on the connector for the fan was bad so I spliced a wire around it and then they both seemed to stay on. We went back out and continued the course. The temperature was much more stable but would occasionally rise a bit above the middle of the gauge. Our friend who works on rally cars says when they lose the front bumper cover they will overheat, so he thinks that's our main problem. Around mile 40 something was slipping in the OB drivetrain but we didn’t see or smell any clutch smoke. I pulled over for about five minutes to let it cool but the problem persisted. Had to limp the rest of the course at about ¼ throttle to keep the clutch from slipping. It took us about 2.5 hours in the OB with all the stops and taking it easy at the end. I think it was about 1hr 40 minutes of driving time. The fastest trophy trucks and buggies run about an hour, the slower baja bugs and 1600 cars run about 1 hour thirty minutes. With a non slipping clutch and a little practice we should be able to run 1 hour 30 minute laps. We had no good way to fix the clutch or trans so we just checked over the suspension and focused on our buggy the rest of the weekend. Everything on the suspension looked good, knuckles aren't cracked, no loose bolts, etc, so I was happy with that. We burned about five gallons of gas running 50 miles. The guy who rode with me told me it was similar to his 1600 buggy. He was surprised a few times with how well it soaked up the rough terrain. The course was a lot of fun. There were a lot of rough sections and tight sections but also many straight sections that were miles long. Some of those were super smooth, others rough enough that we only went 30 or 40mph in the OB. On the first wide, smooth, long straight there were berms roughly perpendicular to the direction of the road but they were about the size of speed humps, fairly short and rounded. We were hitting those at 40-50mph in the OB and getting a little air off some. We were coming up on another one and realized at the last second it was a ditch, maybe two feet deep and twenty feet wide. I think I mostly cleared it but it sent the OB flying and we were both amazed it didn’t seem to do any damage. There was one section, I think along a powerline, with ruts that must have been at least 18” deep. We were able to straddle them in the OB or we probably would have gotten stuck. There was one steep rock face with a sharp transition at the bottom that I hit a little too fast in the OB. Yesterday morning we pulled the trans out of the Subaru and discovered the pressure plate was packed with grass. The fingers were almost flat and the bolts didn’t have to unthread very far before they had no tension on them and the fingers didn’t move up much. We clamped the fingers down using a big toggle clamp and socket and blew/picked all the grass out. Then the fingers sat up at an angle. Disc looks good. Definitely have to get/make a cover for the bottom of the bellhousing. We got some good video so eventually I'll edit that and post it. We are considering going back to their next race in April. Any thoughts on bellhousing cover or our overheating issue? It sounds stupid but I would like to be able to run the AC, it gets hot in suits and helmets in an enclosed car.
  18. Replaced the rear diff recently, it was whining badly again. The one I'd put in a couple years ago was ancient though. I should probably change the oil in that occasionally. I've done some brake work and replaced a rear wheel bearing. Found a crack on one of the front knuckles months ago. It's near the caliper bolt head. Before I did anything else I test welded a plate on an old knuckle and couldn't hammer it off, so the weld seemed to hold. Ground out the crack: Welded it up and created a fillet: Couple months later I noticed that the other three spindles were cracked in a similar spot. So I did the same thing to them. Grind out crack, preheat, weld. So far I haven't seen any more cracks but we haven't done much offroading since then. Planning on heading to Texas next week to see how it holds up to a desert race.
  19. Thanks for that tip. My radio died a few weeks ago and when I had that out I spotted a black box. It says Subaru security unit so I unplugged it. Alarm hasn't gone off since. Everything else still seems to work.
  20. Any more hints as to where this is on a 99 OB? I've looked under the dash several times and can't find anything as described online. I've had the car for two years and the alarm just started going off a few weeks ago after replacing the battery. I've unplugged the seat belt control which has been great. I tried unplugging the "keyless entry unit" which is the only black box I could find but then the car just doesn't run. I followed the wires from the security light but they just go into a giant bundle of a hundred wires above the fuse box. I do have the key fob but I think its battery is dead. I really just don't want the alarm but I might try to resurrect the remote so I can put it in valet mode for now. Any help on where I can actually find the alarm unit or what it looks like would be great.
  21. Got a different mount for the tablet (GPS) which is much more stable than the X mount I had. Mounted the visors to the cage since I had them and haven't found anything better. Tried adding friction to them by preloading the springs. This turned out to be pretty easy but didn't do much. I also mounted the brackets at an angle that had more friction than how they were mounted stock, but they still swing around when cornering.
  22. Had our old CBs checked out at a local CB shop. They were both OK but the antennas we had were both bad, which explains why they didn't work very well. Installed one of them in the dash of the Outback. I was happy with how well it fit below the radio. Here you can see the hack job the PO did on the radio wiring. Screwed in place perfectly. Just enough room for the mic cable to come out the side and towards the front. Don't have a picture of it but we screwed a mic hook just to the right of the radio so it's not just bouncing around the car. Antenna is mounted on the rear corner of the hood with a big washer underneath. So far it seems to be working great now, we had the other CB and a magnetic mount antenna I got on CL in the Impreza on our last trip. Very nice being able to instantly communicate with each other.
  23. On Friday we hooked the Impreza up to the Outback to check out the Trans Wisconsin Adventure Trail. It looked like heavy rain all day in Indiana but none in Wisconsin and I've wanted to check out this route for a while. Basically a bunch of gravel roads someone has made a route out of that goes north/south through Wisconsin, following the Mississippi for a while. On the way we saw a flock of bald eagles eating a carcass (probably a deer) out in a field. As soon as we stopped and got out to take pictures they all started to fly off but my friend counted nineteen of them. Far more than I've ever seen in one place before. Took about two hours to get to the first real gravel road so we unhooked the cars and set up the gopros. A few of the gravel roads were windy and somewhat narrow with a few ditches or stream crossings, and there was probably at least a half mile long muddy stretch. The Outback could definitely hit the ditches faster than the Impreza and handled the mud better but what we were on could probably be driven in almost anything. We did play with the steering brake and it seems to do nothing at low speeds, which I've noticed before, but over 30 or 40mph it turns the car quite aggressively. We definitely locked up the inside rear tire at least once. Most of the route was wide gravel roads and maybe 1/3 pavement. It's about what I expected, not really challenging but interesting and scenic. It probably becomes more sandy and muddy as you go north. We drove about 150 miles, about a quarter of the route, and it was dark so we hopped on the interstate and went back home. I probably won't bother putting a video up on youtube as it wouldn't be very exciting to watch.
  24. First I just added some square tubing to the stock ones. http://www.ultimatesubaru.org/forum/topic/144953-99-outback-build-advice-wanted/page-2?do=findComment&comment=1231150 That seemed to work but when we made the long travel I built new control arms to make them stronger and shift the wheels forward and out a little. http://www.ultimatesubaru.org/forum/topic/144953-99-outback-build-advice-wanted/page-4?do=findComment&comment=1270481 http://www.ultimatesubaru.org/forum/topic/144953-99-outback-build-advice-wanted/page-4?do=findComment&comment=1272393 Really we've only bent a couple of stock arms and every time it was when we clipped a big rock while going 10-20mph.
  25. Video of our last trip to Interlake. We were more focused on testing the car than shooting video but we did get a few good clips.
