pontoontodd
    55
Everything posted by pontoontodd
  1. Thanks for that tip. Makes sense looking at the input shaft teeth.
  2. While the exhaust was off, I sleeved a major leak and it's much quieter now. The driveshaft u joints all felt sticky so we replaced them all. One of the old cups appeared to have no needles in it. Now that I've driven it a few times I'm glad I did the group N mounts. It only causes a little more NVH than normal under full load, low rpm, in fifth gear. Otherwise unnoticeable. The higher clamping force clutch doesn't seem to have much more effort than stock either.
  3. The 2 x 2 x .120 should be plenty strong. You could run the new rails inside the stock frame and bolt them in from the top like the EJ cars. Weld some nuts inside the new rails, drill holes in the top of the stock rails. Probably best to put some kind of stop in the old rails so if you hit something too hard it doesn't just bend/shear the bolts. Not sure what you mean by 4 chassis rails though.
  4. Reverse idler gear missing about 1/4 of the teeth: Took a couple highway trips with the unevenly worn mud tires and locked up the center diff last fall. Since I mainly drive it on the highway or off road, I kept driving it. You can see the lower gear in this picture welded to the shaft: That broke/pushed the snapring out that holds the viscous plates in, although they were still all in place. Also broke the outer cage of the bearing that supports the center diff, but it was all intact and functional when we took the trans apart. We were barely able to get this sleeve off the input of the trans with a 3 jaw puller. As you can see the base kept chipping. Is this an original part or some kind of repair sleeve?
  5. Alright, that makes sense.
  6. In case anyone is interested, we are now planning on meeting at Rush off road park in KY the weekend of April 25th.
  7. In the chance this helps your diagnosis, I've had a similar issue with my 99 Outback. Normally this happens when it's wet. Since I siliconed the spark plug boots in the heads it hasn't happened nearly as often. Car will run fine until the needle on the temp gauge swings up to the middle. Engine will stall at the next stop (manual). Engine will immediately restart, but runs very rough. Lots of bucking under light acceleration. Seems to run fine with more throttle and RPM. Shut off the engine, even for a few seconds, while coasting or stopped, and restart it and it will run fine the rest of the day. One time I had a long drive home and the restarting trick did not work. The engine would only run well above 1/2 throttle or near idle, which was a PITA cruising on the highway. Reader's digest version - try shutting the engine off next time it runs rough, count to ten, then restart it and see if it runs better.
  8. When you guys talk about "t casing it", how exactly would you do that? Keep the stock front drive and just use the t case to drop the rear drive? Use front and rear outputs of the t case and use some other IFS or front axle? If you're doing that, why not use a RWD trans? Just curious, I've heard a bunch of people on this forum now hint at doing this but I've never seen how they've done it.
  9. If your steering is wobbling, the first thing you should check is the u-jointed steering shaft that connects the column to the rack. You may have to remove it to tell for sure if it's bad. At a minimum watch it while someone else rocks the steering wheel back and forth slightly and watch if you can see any slop. Not super hard to replace. I had an old VW with dried up steering u joints that was sloppy enough to cause the wobble you're talking about. Another thing I had to replace on my car was the rack. You could rock the driver's side of the rack up and down in the housing a signficant amount, say 1/16" of an inch. It should be rock solid. More difficult to replace but not too bad. You should also check the inner and outer tie rod ends. Pretty easy to replace if you have the right tools. Check the lower balljoints and wheel bearings too. A lot of those components were in need of replacement when I got my Outback but haven't had to be replaced a second time, even after a lot of off road abuse. The best way to check all this is to jack the front end of the car up and rock the tire by the top and bottom. If it is at all sloppy, try to see if it's the balljoint or wheel bearing that's moving. Then rock it in a steering motion (front and back of the tire). You can really only see the outer tie rod but should be able to tell if there's any slop in the steering system. Watch the steering wheel through the windshield to see if you have any slop. If everything is in good shape, you should not be able to feel any slop in either direction. If you have enough time on your hands, remove the front struts and remove the front springs (make sure to do that safely with spring compressors). You will be able to tell if the struts are bad if there's no resistance up or down or if they have any slop side to side. Check that the springs don't have a coil broken off too.
  10. He still has the Geolanders that came on it. They still have decent tread but they're obviously not very good in the mud. It was super slick, the Toyota with street tires might have been worse.
  11. Thanks for the advice on the clutch cover. I'll try the hose thing if it happens again. Definitely agree on the mudflaps, I could see removing the disc brake dust shields too. Not sure I agree on the timing belt covers, I suppose I should pop one off and see how much stuff is in there.
  12. I think the main cause of the clutch slipping was mud in the pressure plate. I cleaned some of it out and the fingers came up: You can still see the machining marks on most of the friction surface. Disc and flywheel still looked good too. Is there a dust/splash shield that covers the bottom of the flywheel for these cars?
  13. More than I'm willing to spend, although it is low mileage with rear diff and axles. Good to know that option is out there.
  14. That would be great. Easily the biggest handicap to car ownership around here. What do they use near you, sand?
  15. Here's a little trick I figured out that might help someone down the road. I got the nut off the top of the shift linkage bolt but couldn't break the bolt loose. I was starting to round off the hex head. I put the nut back on so I wouldn't damage the threads and put a big socket over the bolt head and pressed it out with a c clamp. If you learn nothing else from this build thread, you should learn never to buy a car from the midwest.
  16. Good to know. How expensive is expensive? Once I have the bad one out and a good one in, I'll probably look more seriously at setting it up with a low range or other mods. Also, how common is trans breakage when offroading these cars? I've heard of guys street racing them breaking first but not off roading. I'm going to keep driving the suspension as is for a while, but so far I think long travel struts in front would be much easier and cheaper than the a arm setup with almost as much travel. I'm hoping the higher clamping force will make the clutch last longer. Hopefully I'll just get a little more wheelspin and less clutch slip when starting. This trans is out of the same year Outback so I should be good, but is there an easy way to check the ring and pinion ratio without taking the trans apart? Next question: We did tear/wear out a brake hose in the rear. There was clearance for it to go up in an upside down U between the tire and strut/reservoir. Then that clearance got filled with mud. I've been thinking about replacing all the brake lines for a while. One of them rusted out last fall and had to be fixed. I should probably reroute them on the suspension with this added travel. The ABS has never worked and takes up space and adds a lot of plumbing. I've always wanted some kind of cutting brake or functional handbrake. My thought is to just run braided stainless -3 from the master, tee to the front calipers. Then run a line from the master to a cutting brake (single handle, left rear, right rear) and from there back to the rear calipers. I could put in two hand brakes and have four wheel independent braking capabilities. Rock crawlers often do this so they can lock up both fronts by pushing both forward, both rears by pulling both, either rear by pulling one, etc. That would cost hundreds more dollars and require a lot more plumbing. Do you know what fittings I would need to do that or where would be the best place to get the fittings/line/etc? I think the Subaru master is 10mm x 1.0 and the calipers are all just banjos.
  17. The auto would definitely be better for crawling, or going to that park we went to Sunday. As you can probably tell I don't have a lot of interest in going super slow. The suspension is almost all bolt on. We'll see how it holds up, but I'm definitely interested in building suspension kits for sale if you have the $$...
  18. Alright, time for more advice wanted. Long story, and eventually I'll at least put up some video, but we went to an off road park yesterday that was all rutted muddy trails. On the plus side, the long travel seemed to work great and we even went over a rock pile that I never would have attempted before. After hundreds of starts/stops and a bunch of pulling people out, my clutch was starting to slip. Then near the end of the day I broke reverse. Not sure how, it just suddenly didn't work and made bad noises. Fortunately we were able to drive home but the clutch did slip a few times just flooring the gas pedal in fourth or fifth gear. So I need a new clutch and trans. I was looking at the Exedy HD, specifically 15801. I think I've found a trans not too far way for $350, I will probably just get that and then try to fix this one when I have time. I would really like lower gearing and/or locking diffs but that's probably not something that's going to happen in the next couple weeks. Thoughts?
  19. The long travel definitely helps. Even with the 1.5" lift on the stock struts it was able to get up that 5' steep hill and the Impreza can't though. It does ride much better than the Impreza now. We definitely would have bent some struts on the Outback if we had driven it that hard on the stock suspension. And that Bronco has some city boy tires so that was holding him back some. We've done a little more tuning since then and the front is great now. Plan on going out Sunday to see how well it does in the mud/dirt, maybe some small rock piles. We have a bunch of other ideas on the front ends. One is to have a more solid lower rad support and have rails that connect either end of that to the bumper and then down to the swaybar mounts. Also instead of the rectangular tubing under the oil pan something like a 10" C channel that could sit up higher and surround the oil pan. If I did another one from scratch that's how I'd do it anyhow. How were you thinking of tieing it into the crossmember? Right now it bolts to the middle of the crossmember behind the oil pan. Any ideas on a shorter radiator or raising/tilting it for better approach angle? Something like a Cherokee rad and fans would be good but they're too wide. I've seen someone put the rad and fans on top of the engine but with no hood.
  20. The oil pan is badly smashed in again. So bad this time the oil pickup tube was bent up a bit (found that out when trying to put a good pan on). The guard was bent up and the engine must be moving around quite a bit on the mounts since the valve covers appear to be rubbing on the crossmember slightly. The rubber in the engine mounts has been cracked for a long time. I got group N engine mounts, expensive but hopefully they will keep the engine in place better. Changed the guard a bit to make it easier to remove, farther from the oil pan, and a bit stronger. Hopefully it isn't too low now. Eventually I'd like to put a piece of 10" C channel under the oil pan.
  21. We might meet some friends at little Sahara in OK the weekend of April 11th to check out the dunes. We also might go to Black Mountain in KY, possibly instead of going to OK, sometime in April for some trail riding. Let me know if you're interested in either. It would be good to have more Subarus join us.
  22. We were trying to break the suspension on Saturday and couldn't. This isn't how I plan on driving it normally, just figured it would be best to find the weak links close to home if there are any.
  23. Good call on the wire and switch. Speaking of starters and alternators, should we worry about having one of those fail? We beat on the car hard on Saturday and didn't bend or break any suspension. Got some good video too so hopefully I'll have that edited and posted in a few days.
