Quick links:
to see all of our videos, just check out my youtube channel:
https://www.youtube.com/user/pontoontodd
The start of the long travel build starts on post 81: http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-4?do=findComment&comment=1266961
Fairly current pictures of the long travel struts on page 25:
https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1355228
Tips for building an EJ Subaru for off road:
Build protection for the radiator and oil pan. (see below for something basic) (post 32 for something more elaborate) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-2?do=findComment&comment=1221826
Front skidplate if you want to be thorough. (post 480) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-20?do=findComment&comment=1341248
Build protection for the gas tank. (post 5) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1217857
Lift the suspension with strut spacers. (post 7) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1217859
Better solution is to build or buy better struts and springs.
With a lift, and especially with long travel suspension, a higher lift jack is required. (post 265) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-11?do=findComment&comment=1319081
Get off road tires. Mud is the most likely place to get stuck or have traction problems, so mud tires are best. They're also more resistant to puncture.
Make sure you have a flywheel dust shield. (post 248) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-10?do=findComment&comment=1316910
Reinforce the front control arms. (post 44) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-2?do=findComment&comment=1231150
Or build heavier duty, wider arms. (post 85) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-4?do=findComment&comment=1270481
Use alloy wheels, definitely not Forester steel wheels.
Torque lug nuts to 100 ft-lbs.
Dielectric grease in the spark plug pockets on DOHC EJ25.
If you spend a lot of time in the woods you should build fabricated bumpers. Almost worth building to have something solid to tie your radiator protection to. (post 4) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1217856
Rear bumper / gas tank protection. (post 161) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-7?do=findComment&comment=1290470
Get folding side mirrors if the car didn't come with them. (post 47) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-2?do=findComment&comment=1245301
Reinforce/skid the rear subframe mounts. (post 50) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-2?do=findComment&comment=1246237
Replace the brake lines if you live in the rust belt with flex stainless braided and add a buggy style steering brake. (post 143) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-6?do=findComment&comment=1284093
Check wheel bearings, ball joints, and tie rods for slop.
Check knuckles (spindles) for cracks at the base of the strut mounts. (post 237) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-10?do=findComment&comment=1313874
Upgrade to bolt on wheel bearings if you have press in wheel bearings. (post 266) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-11?do=findComment&comment=1319135
Sleeve front control arm mounts in crossmember. (post 159) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-7?do=findComment&comment=1286994
(post 314) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-13?do=findComment&comment=1325958
Install group N engine mounts to keep the engine from moving around so much. (post 107) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-5?do=findComment&comment=1277770
Additional HID lights wired to fog light switch only with headlights on high. (post 189) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-8?do=findComment&comment=1299016
Larger / centrifugal air filter for dust. (post 271) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-11?do=findComment&comment=1319259
Cooling system testing. (post 339) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-14?do=findComment&comment=1328108
Radiator upgrade. (post 363) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-15?do=findComment&comment=1329904
B pillar electric jacks. (post 541) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-22?do=findComment&comment=1345331
Quick release fasteners for spare tire. (post 542) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-22?do=findComment&comment=1345473
CBs for communication.
Tablet for GPS. (post 52) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-3?do=findComment&comment=1249804
Speed strap is the best thing we've found for recovery. Pretty quick and easy to loop them around almost anything, 2" model seems indestructible for Subaru use. Much faster than winching.
Trail fixes:
If your clutch starts slipping because you don't have a flywheel dust shield, spray water in the top of the bellhousing through the throwout fork hole with a garden hose and pump the clutch. from Uberoo
If your engine is running rough, unplug MAF, TPS, and O2 sensors one at a time and see if one of those makes it run more smoothly. from Uberoo
Racing safety modifications:
Fuel cell. (post 160) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-7?do=findComment&comment=1287392
Roll cage. (post 211) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-9?do=findComment&comment=1306131
Race seats and five point harnesses. (post 213) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-9?do=findComment&comment=1306611
Window nets, extinguisher, and padding. (post 214) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-9?do=findComment&comment=1306778
Rear lights, first aid, driveshaft strap. (post 215) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-9?do=findComment&comment=1307189
Transmission scattershield. (post 248) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-10?do=findComment&comment=1316910
Trip reports:
September 2014 Upper Peninsula of Michigan (post 54) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-3?do=findComment&comment=1251178
April 2015 Black Mountain Kentucky (post 140) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-6?do=findComment&comment=1283318
July 2015 Badlands Indiana (post 176) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-8?do=findComment&comment=1295716
November 2015 Interlake Indiana (post 226) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-10?do=findComment&comment=1308438
January 2016 Notrees Texas (post 238) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-10?do=findComment&comment=1315301
April 2016 Notrees Texas (post 275) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-11?do=findComment&comment=1323898
May 2016 Smoky Mountains (post 343) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-14?do=findComment&comment=1328449
July 2016 Upper Peninsula (UP) of Michigan (post 372) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-15?do=findComment&comment=1332038
August 2016 Vegas to Reno Nevada (post 403) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-17?do=findComment&comment=1335235
November 2016 California to Illinois (post 503) http://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/page-21?do=findComment&comment=1342977
April 2017 Notrees Texas https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1356707
May 2017 Badlands https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1358036
July 2017 UP https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1362143
August 2017 Vegas to Reno Nevada https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1364935
November 2017 Illinois to California and back https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1371258
November 2017 Badlands https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1372399
February 2018 southern Illinois https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1378234
February 2018 Arkansas https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1379018
March 2018 Mine Made off road park in Kentucky https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1380686
April 2018 Arkansas https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1382616
May 2018 Arkansas https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1384499
May 2018 Illinois to Tennessee https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1385484
June 2018 UP https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1385849
July 2018 UP https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1387742
October 2018 New Mexico and Arizona https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1392330
November 2018 Badlands https://www.ultimatesubaru.org/forum/topic/144953-long-travel-outbacks-or-making-subarus-faster-and-more-reliable-offroad/?do=findComment&comment=1393425
Original first post:
I got this 99 Outback about six months ago for a three day off road trip in the Upper Peninsula of Michigan. We did about 480 miles off pavement over three days.
Pix of it next to my 96 Impreza with city boy tires:
215 75 15 Hankook Dynapro MTs and Forester steel wheels ($20 each on ebay) on the Outback and slightly oversized BFG winter slaloms on the Impreza:
This was the only mod on both cars before the trip:
Video from the trip:
