Bob Nieuwsma
Location
Eureka Mt
Referral
Google
Vehicles
1996 Subaru
Bob Nieuwsma's Achievements
Advanced Member (3/11)
I have a very urgent request PLEASE Our daughter has a 2013 Crosstreck and her boyfriend ran it out of oil and now the engine is toast. What should I do? Buy a wrecking yard engine and try to find the lowest mile one I can find or buy a JDM engine with a warrantee. I have done engine swaps on my 96 and 99 outbacks so I don`t suppose this will be to terribly different. Any advice would be greatly appreciated.
Can I put a 2.2 non egr motor with a manual tranny into a 2001 outback with a manual tranny? Will it run? I am looking to make a beat around car to run to town and back and cruise around the hills and keep the miles off my good car. I don`t care if a the check engine light stays on but don`t want to attempt it and reall screw something up! Thank you for your advise.
I am not sure what to do! I have so many questions! I will try to be brief and summerize. 1st suby is a 1996 outback which I did a 2.2 swap back in 2014. The 2.2 had 125,000 on it at the time, now has 200,000 give or take and runs great and does not use any oil after I switched to Chevron 10w40. It is a 95 0r 96 dual port engine.But the car is in pretty rough shape and has a u joint ready to fall out and you can`t just buy a u joint you have to but a complete drive line! $250.00 bucks on E bay. Just bought 2nd suby a 1999 outback aniversery addition super clean car with 161,000 on it and a blown head gasket. Bubbles in the radiator overflow tank, but it runs good, doesn`t over heat unless you drive it hard. I want to keep this car for as long as possible because it is so clean. And with it came a Legacy wagon 2.2 manual transmission ( not sure what year because I havn`t brought it home yet.) The guy said you can have it for a hundred bucks!! Here`s my questions #1 do I put the 2.2 from the 96 into the 99 and just drive it? or pull the 2.2 heads and put them on the 99 2.5 block and frankenmotor it? ( I`ve read the 99 block is the best for this! ) #2 Will the increased compression give me better mileage? or just more power? sometimes more power means better mileage but not always! #3 Will the frankenmotor be an interference motor when done? I really don`t care because if I can do this I can change a belt every 80,000 miles! 2x and the car will be done anyways. #4 Will the heads of the 2.2 parts car with manual tranny work on the 96? I know it is not an EGR motor but if it will work I could keep it around just as a run around car to help make the 99 last longer. ( I don`t care if the check engine light is on ) find a driveshaft out of a wrecking yard and run it into the ground. #5 or just part out the 96 and keep everything of value for the 99? #6 The heads on the 2.2 in the 96 were resurfaced but if I do the franken motor should I do a valve job and put in new lash adjusters? #7 If I do a frankenmotor will I need to run premium fuel? My goal is to have a nice car that is good in the winter here in Montana! An outback with snow tires will go anywhere this old man wants to go (61) this year. Our other car is a 2006 Toyota Corrola which is a great car 40mpg but not a winter car like a Subaru! But if I can keep the 96 going it would be great for beating around the mountains, running to town ect. Thanks in advance to those who choose to give their advise and opinions.
Ok I am not very good at computer stuff so if I posted in the wrong place I am sorry. So I have a little story and I will try to be brief. I did a 2.2 swap a few years ago in a 1996 outback and it worked great! I just picked up a super clean 1999 out back that is super clean and an aniversary edition with a 2.5 which of course has a blown head gasket! I also picked up a older legacy wagon parts car with a 2.2 and a manual transmission. I am planning on putting the 2.2 from my 1996 in the 1999 which I know will work. My question is if I remember corectly to do a swap it needs to be out of a car with auto tranny for the EGR, so I want to rebuild the one out of the car with the manual tranny and eventually put it in the 1999. Are the blocks the same? Can I rebuild the engine and take my intake off of the one I am running now for the EGR. Thank you
I know that the head gasket failed because of the water pump failing and it overheating. After it overheated I put another water pump on and it overheated again after a couple of weeks so I believe the head gasket was weak then failed. I am going to have both heads resurfaced and would like to put quality gaskets back in it. Also I think I am going to go to Subaru and get a new water pump and forget the reman from napa.
I did a 2.2 swap with lots of help from USMB THANK YOU EVERYONE I am not much of a computer person or mechanic! so I do not spend much time here. So I did my swap about a year and a half ago and everything was good, then the NAPA water pump I installed when it swapped failed and caused the car to overheat. Now I have a blown head gasket!! I do not really want to go to Napa again if their parts have become so inferior. Should I go to the dealer or is there a better place with better gaskets? Thank you all in advance.
Yes! it is smoother, quieter, and has just as much power as the 2.5, but it was not running right when i pulled it. I am very curious as to what mileage I will get now. I`m running premium to get away from the ethanol. The wife is happy and that is what really counts! She even said she could tell the difference in how much smoother it felt.
It was quite simple, it was harder getting the 2.5 out than putting the 2.2 in. Everything was plug and play just like they said, I`ve got 140psi on 2 and 145 on 2, not as hi as I had hoped for but good enough and fairly close. The check engine light came back on after about 10 min of running, found out it was the knock sensor, replaced it and no light. This motor purrs like a kitten and has as power as my 2.5 had. I am very pleased with everything. Thank you all again. God Bless
OK so I have my 2.2 to put in my 96 outback, we are going to put new crank and cam seals in it, new belts and plugs, With 122k should I adjust the valves while it`s out? and what should they be set at? also what should the flex plate and torque converter be torqued at. I would appreciate any advise as I only want to do this one time. Are there any other seals or gaskets that should be replaced? The plan is to do the swap this weekend. Thank you all so much for all the advice I have been given over the last couple of weeks. May God Bless you all!!
