Dania02525
Dania02525 last won the day on October 10 2014
Dania02525 had the most liked content!
Gender
Female
Location
Austin
Referral
DeltaCams sent me here
Biography
Outdoor adventurer trying to make my car keep up!
Vehicles
1982 Subaru Brat
Dania02525's Achievements
Advanced Member (3/11)
10
Thanks, I reached out to him, but it looks like he hasn't been online since 25 Feb, so I'll wait to hear back. In the mean time, I'm talking with RetroRoo about a bit more specifics on how he does the swaps. Denver is certainly an easier ride from Texas than Oregon, but I'm really most concerned with who's going to do a bang up job on it. Whoever does it, I'll definately request that they update the project on the board here (preferably with photos) so all of you can ride along with me as the car comes together :-)
The paint needs to be done- eventually. I'm not super picky on it, and I was considering an easy to paint color like a gunmetal mettalic or something anyway. Its probably something that could be sprayed pretty easily and still come out good enough for me. My other option is Mexico- they can do a nice job there for pretty cheap if I go that route. I'm mostly concerned with the mechanicals, wiring, and the interior stuff. How do you guys get the HVAC doors working? My cables are all old and cracked and I can't change where the air comes out reliably. If it can be done by someone, great- but if not, that is something I'd probably get a bunch of servos and convert to a fully electrical setup myself.
I totally understand this. I've got a solid, straight brat without rust but which is worn from the years and is showing its age in lack of technology. Considering the depreciation I would lose out on when buying a $25k toyota, I think its perfectly reasonable to spend $5-8k on putting my brat together. Also, I prefer to stay away from banks and credit, and prefer to stay away from required emissions tests and associated BS with 25 year and newer cars.
I'm thinking about having someone do a full ej swap, with 5sp trans, power steering, wiring, etc in my 82 brat. If I had the space or time, I would do it myself, but unfortunately I do not. So I come to you, experts of USMB. I know some of you are capable, so could you do it for me? I'm considering doing this instead of dropping a sizable downpayment on a new or newish tacoma, but those trucks really aren't exactly what I want. I want a fully restored brat. I'm in texas, but if I decide to do it and find the right person to do it, I can bring the car anywhere in the lower 48 to you, and leave it with you for as long as you need it. Here's what I would want: EJ swap + wiring 5 sp power steering pugs and 2-4" lift Interior and paint, if you know someone. (I've got some spare interior parts) If you do it, you can have a clean ea81 with new weber carb and whatever other parts from the brat you don't use. I know this isn't the proper forum for it, but I want to make sure this gets seen by the real experts on here. If there are any questions about what I'm looking for, post them on here. If you've got an idea of what the cost of something like this would be (you do the work and find the parts needed) please PM me. Thanks!!!!
- ABANDONED SUBARU ALERT -
Dania02525 replied to Subaruist's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I want that front brush guard! -
Perhaps these were answered someplace, but I wasn't able to find enough. I'm considering going from the small valve EA81 heads to the larger valve ones, via machine shop work at RAM performance. I trust them to do an awesome job since thier engines keep planes in the air, but I'm just wondering if this is worth it to do. Obviously it will flow better, but it it really worth $700? I'll also be doing a FI conversion from an 88 ea82 car, so I know thats where the majority of the power increase will come from for my currenly single barrel carter setup. Anyone done just the valves and have an idea of how much the increased flow matters? Edit: I should mention that Ron at Ram performance plans on doing a 5 angle valve job, and including new SS valves and new brass guides.
Complete 4WD Axles
Dania02525 replied to JuhaKankkunen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The EMPI one looks beefier? than the one I recieved from Oreilly. Better boot material too. It is apparently new as well and came with an axle nut unlike the one from Oreilly's. -
This. Its true that if our engines were operating at 100% efficiency already, thermodynamics would make it impossible to extract any additional energy from a lower potential energy substance- like water. The problem with this is that our engines don't operate anywhere near 100% efficiency, and there are as mentioned by ferox a myriad of factors going into that level of efficiency. A car engine is not a perfect heat engine- its operation and power output is not precisely dependent on its total energy input, but also the speed of the reaction. Something that could speed up this reaction itself or facilitate this reaction happening faster could increase its power without adding any additional sources of energy to the system (think catalyst). The real question is whether the amount of whatever you put into this system is enough to meaningfully affect the efficiency. If you consider how much O2 is used by an engine, as well as how much elemental H is used (that in the fuel), I think you would need massively more than what's being produced here. There could be some other mechanism at work here however. The hotspots produced from leaning out the engine could perhaps be offset by some localized water vapor conducting the heat away better than the CO2 exhaust. Or the elemental H2 is acting as an ignition primer for the fuel vapor in the combustion chamber. The problem with this idea is that you need 4x more H2 in a given area to reach the same flammability as gasoline vapor, which means you would need to be producing 4x more H2 than total gasoline vapor delivered by volume- alot!!! Edit: yes, there are engines running on h2, but they use extremly high pressure tanks to carry enough fuel to go anywhere. This is because much of the thermal energy that makes our engines turn is a result of the C-H bonds, and the burning of C rather than the burning of H. You also need lots of volume of H2 to reach the levels it needs to burn.
soft tonneau cover for second gen brat?
Dania02525 replied to belacane's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I can definitely have the fabric manufactured, I'll just have to research some snap in railings for it. I'll use my 2nd Gen as a template and keep everyone updated -
Finally got tonneau cover done!
Dania02525 replied to ettev's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Since this thread is back from the dead- I thought I might ask here- I work for a cover manufacturer, so I could probably have a really pro looking soft tonneau cover made for the 2nd gen ones. I'm not sure what to do for attachements or railing, so if anyone has any idea, let me know. I'd love to make it as simple as possible- as close to bolt on as can be. I have access to weathermax fabric, which is marine rated and stands up in use as sail covers, so I think it would last quite well as a tonneau cover. If there is interest on the forum, I can measure my car and make a prototype.. -
*she Fixed that for ya :-)
