subenoob
Gender
Not Telling
Location
virginia
Referral
google
Biography
Paul. Welder, car restorer.
Vehicles
1995 Legacy L Wagon
subenoob's Achievements
Member (2/11)
3
OK wheel here's an update. Bought a coil. Didn't help I don't think. BUT.... If I take a test light, put the alligator clip on the POSITIVE of the battery, and touch the probe to the YELLOW/BLUE pulse wire at the ignitor, then remove it (essentially putting 12 volts on that wire then removing it) cylinder 1/2 misfire goes away! But only for 2-3 seconds, then those cylinders fail to fire. Touch 12v to that wire, then remove, misfire gone for 2-3 seconds. What in the hell!?!?!?!?!?! Edit**** The longer I hold 12v to that wire, the longer the misfire stays away. I held 12v to that wire for about 20 seconds and it ran great for like 35 seconds!!!
Thanks for the moral support man!! Haha I'm not yet. I'm really digging this car. Its clean, and its a wagon . I've had a thing for wagons (particularly hearses) since I can remember. I don't mind yanking the engine for a separator and seal and t-belt job, but I can't keep throwing time and money at this thing without being able to have it run right and drive etc. Gonna tinker this weekend and see what I can come up with. Might just back half it and stick a 347 ford stroker in it. I have a habit of doing stuff like that....
Ah!! Thanks for clearing that up Gloyale! I was spacing there and didn't even put 2 and 2 together there!! I'll check those 2 wires now and update. Thank you again. **update** checked yellow/violet and yellow/blue wires. Meter reads 000 on both from ignitor plug to ECU. **another update** just for poops and giggles, I checked compression. 150 exactly across the board. I also pulled the outside timing covers. Marks line up, but I can't see crank of course. Checked the teeth on the back of the cam pulley to trigger cam sensor, cleaned cam sensor. Still no spark to 1/2. I don't want to send this ole girl to the great Subaru junkyard in the sky... Oh, and this thing leaks oil like a siv. Can seals, seporator, valve covers, maybe oil pan. Engine cross member is soaked and dripping after every run. Considering cutting my losses at this point man
Just a quick update, while its on my mind. Thanks for the assistance Gloyale. With everything unplugged, both blue and red/green wires read 000 from the coil harness to the ignitor plug. However, pins 13/14 on my ECU are empty on the top row. The 3rd/4th from the opposite end are both yellow. I'll investigate further. Have not checked the connectors at the top of the trans. There's a bunch of them there so I'm gonna pull them all apart and clean for good measure. I'll be sure to update later this evening when she fires right up and purrs like a kitten....(a man can dream lol) Thanks again guys! Paul.
Give me a carburetor any day!!! If my one of my carbed cars won't start, its fuel or spark. All easy fixes. The suby has crank sensor, cam sensor, O² sensors, MAP, MAF, coil, ignitor, timing belt, fuel pump, ECU all kinds of crap haha!!! Gimme a Rochester, a mechanical pump, and a distributor, preferably with points haha! I'm slowly moving up into the computer controlled world. Kicking and screaming tho. This 95 is the newest thing I've ever owned...
I'd def start with the basics. You need gas, spark, and compression to start it. One is missing from the equation. I DO NOT know if your model has a fuel pump shut off. I know my mustang for instance has a shut off that if the car senses impact it will kick the fuel cut off to stop fuel flow. Someone who better knows your car can weigh in on that. Do you hear the fuel pump come on when the key is turned on? If not start there. If so, do you have spark at all cylinders? Some one more surbaru knowledgeable will weigh in, but check the basics first. Fuel and spark, then you can investigate further accordingly. Paul
That's a great summary and I really appreciate it Fairtax. I know its hard to diagnose things like this over the interwebs, but I really appricate you guys trying! What your saying makes perfect sense and I understand completely now. I didn't mess with it a whole lot last night, but tonight I'm gonna try and be more precise and make a check list of what checks out good and what doesn't. Hopefully I can pinpoint this tonight. I'll be updating for sure. Thanks again Fairtax. I'll try and download that manual on the ole lady's laptop tonight. Thanks for that link. Paul
Another new guy intro...
subenoob replied to subenoob's topic in Meet n' Greet. Your USMB Welcome Center
Hey Suby, thanks for the welcome! I did the exact opposite. I left communist maryland-istan for VA haha!!! I love the VAB area. Its fantastic. Nowhere else I'd rather be man. Find yourself back home, we'll drink a beer and check out what kinda work we can do on that brat!! -
Edit: OK testing continuity now from the red/green at the ignitor to red/green at ECU. With the coil plugged in it reads "14". With the coil unplugged it reads "586". I'm not a whiz with these voltmeters. I only know what 2 or 3 positions do haha! What is it trying to tell me? Seems like this is not correct... ****Edit AGAIN.... Ok...im ready to send this pooperoo to the scrap yard...only kidding lol, but man is this annoying...i dunno what i did, but now when the car is running I have a pulse on blue, yellow is solid on, red is solid on. When I probe the blue it makes the engine drop RPMs for a split second, then the test light pulses. Red nor yellow have any effect...just solid on... I'm closely eyeballing the coil. I wish I could afford a new one, but I can't spend that kind of dough right now on a car I have never heard run on all 4 cylinders lol. Only 2 subies at my local pick-n-pull. A 97 and 98 Impreza and one the coil is missing the other, a bit dif than mine (male lugs for plug wires as opposed to my 95's female lugs) Just to verify. With my "el-cheapo" mutli-meter. At the coil harness, on the "200" setting (lowest) from pole 2 to 1 it reads 1.4 from pole 2 to 3 it reads 1.4. Across the plug wire lugs, on the "200k" setting (highest) 1 to 2 plug wire lugs it reads 20. Same for 3-4 lugs. Seem OK? Thanks guys, Paul.
