dannybito
Location
port st lucie, Florida
Vehicles
93 Impreza
dannybito's Achievements
Member (2/11)
I measured the tires and they are same. You guys are great! I was about give up and get rid of it but I will change the duty c. Does anyone have part numbet or know where to get it? The dealer had 7 different solenoids. I also found this on eBay http://m.ebay.com/itm/251480197765?nav=SEARCH Right part? Also you recommend I drop and clean the pan? To add more detail to the picture.the front of the transmission does leak a little, the binding is worse when taking right turns and it shudders when going into gear. Now do you believe it still worth working on this transmission? Should I look into replacing the torque converter? Or clutch?
Ok did 3 drain and fills.driving a bit each time.going through all gears when draining and on the last fill I put a bottle of lucas in. Now the torque bind is much better. It still happens when I turn right.I have it in fwd and it doesnt help. Im thinking of driving for a week or so then doing another drain and fill. I will change the differential fluids this weekend.80w90 in both the front and rear? If it still binds in fwd does that mean something else is wrong besides the duty c? I only ask because im considering putting a transmission in but I am unsure since the engine had 300k.
Sorry I was posting on my phone and it posted twice. It was overfilled by a quart.no fluid blew out it just had bubbles in the fluid.it's a 93 impreza awd auto with 300k now.I changed the fluid because I just got the car and thought ut would help.yes it flashes the code for the duty c But it has been since I got it.the first fluid I drained was very black and smelt bad.The fluid I reused was in between.the whole time it was overfilled it had no torque bind but after I drained and refilled it its been very bad. No the fwd doesnt help.I was going to try refilling with new fluid
