redskin
Everything posted by redskin
Popped the Exhaust valves and as l thought, trapped by the valve guides although once these are out the shells should fall out. each port has 2 shells split thruogh the centre, 4 in all. What does differ from standard is the 2 little pieces of extra casting around the exhaust port to space the tin away from the port wall, ( effective heat shields), these will be removed if the tin goes when l port them.
Your right, l am using a Link ECU cause when l built this car l couldn;t find or justify fitting a s/h 20 year old unit.
Thanks, to clarify, the current setup already includes, waic, open exhaust, 2.5" dump through to 3" muffler behind the wheels, EA-82T turbocharger, no airbox, 3" pipe to turbo filter, the new set up includes a 5 speed RX box l have in the shed. Adjustable camber rods, EA-82 control arms and stabiliser, rear brakes are discs.
Yes l can Ross, l'm positive my running engine does not have these either, l got a bit of a surprise when l looked into the ports but l assume without removal of the valves yet these heatshields are probably held in by the guides, will drop a valve tomorrow, check and post a photo. Thanks for the suggestion on the inlet ports, l followed your rebuild recently, did you stay with the stock cam?
l have had a spare EA-81T motor laying around the shed for near a couple of years now and recently decided, better do something with it so l have stripped it down for rebuilding, (this was uneventful), and would like a little help with some answers please. My questions are, 1. After pulling the heads and looking in the Exhaust ports l see what looks like tin heatshields inside the exhaust port, l can't remember my other motor having these, it's obvious why they are there but is it normal and as l planned to port the heads, are these easy to remove and should l. 2. Without going crazy, can anybody recommend a suitable grind for the Camshaft. l want to extract more power and still drive it every day. 3. l believe it is possible to have hydraulic lifters rebuilt quite inexpensively in the states, is this correct and any recommendations. 4. What Turbocharger would suit my needs as l plan to make a custom crosspipe and will make the flange to suit. This will do for now. Thanks in advance.
Got the WonderBrumby VERY sideways
redskin replied to Matty B's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Broken Brat Matt, , bad luck but sure it will befiring again in no time. cheers Pete. -
EA81T front springs ... vs EA82T RX front springs?
redskin replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In Australia, King Springs put out a range of front springs for any application to suit EA-81. l am running a set with KYB front struts on my turbo, cost of a pair approx. $150.Aus. -
EA81 compression, custom pistons, how much?
redskin replied to Phizinza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Give J+P pistons in Adelaide a buzz if you haven't already, they will copy anything you want, l have vintage motorcycle piston's made there, (have done so for the last 20 years), and have found the quality of the pistons to be excellent and always on the size you give them. Their price is also compareable but their better service has always won me over, good luck. -
Just bought an 84 Turbo BRAT
redskin replied to Scott F's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well done, enjoy, they really are a fun car but fit a manual box and really drive it, mine runs a 4 speed D/R, (have a 5 but to lazy to fit it for the moment), and will remain so until the clutch or gearbox lunch themselves. Pick up is quicker but it makes no real difference to economy as they're all bad, auto or not. Again good luck and know you have picked up a very desireable vehicle with very few miles on the clock and that most early Subaru enthusiasts will be envious when they know what you've got. -
Nice Drivetrain for the brat?
redskin replied to 75subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Believe me, it's all been done before, quite a few times actually, check the Australian sites. There's more than 1 MY running around with full WRX conversion, mattyB, a member on this site is running around Tasmania in a pretty awesome rig, it's a 2.2 Supercharged Brute, ( , feel free to speak up here Matt), as l said, it's all been done. -
EA81T Non-A/C Alternator Bracket
redskin replied to mikeshoup's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, you can retro fit standard 81 bits, the alt mount is the type with fan so first you must remove whatever you have there, (thermo, nothing?), to make room for it to spin. Second, you must change the engine pulley, yes l know it's the double type but what you need is the standard 81 aircon type, (it is a double also), to line up your belts if you intend to run power steering but if not the standard single 81 engine pulley must be used as the offset (as opposed to the turbo), is different. As you guy's run left hand drive l'm not sure how your power steering mount will be affected so can't speak for this. -
Not Good, but who cares, it's so much fun to drive the only thing that bothers me is that you actually have to stop to get it in.
Will EA82T turbo work on EA81T?
redskin replied to DerFahrer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, my Brat is running an RX, (EA-82), turbo, it was a very easy swap over and worth considering. The only modifications needed is the filing out of one hole on the 81 dump, (the inside lower from memory), about half a hole to suit the different stud pattern and of course the water cooling, this is Not a drama. I used ALL the 82 fittings on the inlet, they fit fine so if possible grab these too. The outlet is even easier, l plumbed it to the top heater hose before the tap on the engine side, (as opposed to the cab side), as there is a bypass just before the tap so your guaranteed continuous flow for disposal of hot water, use it, l made up a 3 way Brass joint from fittings puchased from an air tool place. You can also plumb back to the Thermostat housing but l found that it's pretty busy around there and hard to get pipes in, l used this instead to install a seperate water temp sender to keep my guage honest, it gets pretty hot down here. Hope this helps. -
Run a Sooobie on Water? ...
redskin replied to Davalos's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hmmm, not one of our better claims, l agree, but if you guy's can colonise the moon, , who knows, maybe we'll all be lining up at a Water Station. . -
will the front seats swap from a ea82 to a ea81
redskin replied to mellow65's topic in Old Gen.: 80's GL/DL/XT/Loyales...
They don't bolt straight in but are not hard to fit. lf you visit the ausubaru website and look in the tech manual it explains how the job is done and whats needed. PS, l am using 82 seats in my Brat. -
factory 5-speeds in EA81?
Yep, saw heaps of EA-81 engined EA-82 bodied 5 speed dual range Subaru's, (boy l bet you can't say that quick!), some 1600's too in Israel on a recent visit, can't recall seeing to many in Aus though but thats not to say they were never here. -
Not on Aus delivered Brumby's, they were all 4 speed dual range, the sedans and coupes are a different story. -
Yep, , for the moment, have a 5 speed RX box to go in but no hurry on that one the 4 speed is fun . -
Your right on this plus also the need to use up all the existing 4 speed parts due to the fact a new model was being developed and the flywheel/clutch thing, (different), plus a few other reasons l can't remember. All Aus brumby's came as 4wd d/r, we got no auto's or fwd models or 5 speeds, the ones here were all done after purchase. -
There very pricey in Aus too, thats if you can find a set, we would normally have to get these types of spares flown in from Japan and that also adds to the cost. The prices you have quoted would make it far easier and cheaper to order from the States, s**t, you would even save enough this way to have them air freighted in 7 days, very handy info, thanks.
oil collecting on bottom of filter
redskin replied to skinnyhb's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Front main oil seal above the oil pump is often the cause of this and usually leaves a small pool of oil on the topside of the pump also. -
Retrofitting MY wagon wiper controls to Brat?
redskin replied to dfoyl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the confirmation EJ22Ute, thats how l remember it but couldn't be sure. Must be getting old. -
l am trying to do the same conversion to my 89 Brat using a coupe switch, l know it can be done as l've done it before, (20 yr ago), but for the life of me can't remember what l did! l'm kinda sure it involved fitting the switch and a timing relay under the dash, l think you'll find the wirings for it is already there, the motor is the same. -
I have done a n/a > turbo swap on a Brat and it's not as easy as it sounds, you will need the whole motor if you want it to hang together, the cam is different, pistons, heads, and just about everything else that hangs on the outside, you will also need an ECU, wiring loom, upgraded fuel system, x-member and exhaust, that should get it down the road. lf you want to keep it on the road you might also consider upgrading the suspension as that also was different and discs on the back are the only way to go. Hope this answers your question.
