sirrobert09
Location
Streetsboro Ohio
Vehicles
03 impreza wrx 98 subaru rs 05 legacy 2.5
sirrobert09's Achievements
Member (2/11)
0
well all figured out but i cant get the injectors to seal back up in the manifold they leak from the top on the passenger side the driver side is just dripping. They where fine with no leaks after installation. the o-rings are not torn and the bolts are all the way down. Was going to try another set of o-rings from my metric box that are a tiny bit thicker. Would they hold up to the fuel or do they need to be made of something special?
okay finally a success after building a fuel pressure tester ( fuel pressure came out good) pulling the cats (not clogged) finally just pulled all the injectors and built myself a cleaning rig. set the psi on my compressor to about 20 ran straight chevron techron through them both directions back in the car no more stuttering. Car still feels kinda lacking on power tho but may just be from me going from my wrx to automatic 2.5i Thanks for all the help
for amusements sake i unplugged the knock sensor just to make sure it wasn't causing any issues the timing advance looked slightly less erratic for a second then right back to normal with the same results under throttle. I have no idea how far the throttle should be open at idle the computer says its idling at 14% throttle and seems to be responding on the graph correctly. What are the two black objects inline near the firewall one on the fuel line in and one on the return line they are about where the fuel filter would be on my 98 rs and 03 wrx.
i have 2 charts i logged while fussing with it they are taken at separate times in the first one Air to fuel ration measured 15 seconds to 29 seconds is with light throttle the other segments are when I give it normal throttle in the stuttering range http://i1159.photobucket.com/albums/p633/alestor666/screenshot_zpsc8e5ebc9.jpg?t=1397426414 the second one is the timing advance at the start is with blipped throttle when it stutters then it flat lines after letting off the second major dip is at about 23 seconds with a small bit of throttle timing was pulled to almost -15 this isn't normal is it? http://i1159.photobucket.com/albums/p633/alestor666/screenshot1_zpsb113c137.jpg?t=1397426412 i didn't want to post the images in the post as they where huge
So the battle still continues Replaced plugs and wires still no luck. when watching the timing advance and the torque app right when it stutters the timing jump from the normal idle of about 15 degrees advanced to any where from -9 to -2 soon as it passes that point jumps back up to 15-20. So is the car detecting a knock at low RPMS and just pulling the timing like crazy? Here is a video i took https://www.youtube.com/watch?v=9xhoonBNixg
wasnt able to get ahold of my uncle with the pressure gauge..... did pull the plugs saw a bit of oil seaping through the spark plug seals replaced those and plugs made zero difference still stutters and chokes when hit with full throttle or any amount of reasonable throttle from idle any thing over about 2,500 rpms it doesn't stutter from. Tried running the tourqe app on my phone with it just to see if i could find anything realy noticable aside from the the o2 sensor curves didnt realy match what I see on my other cars seemed more stable and flat then my wrx with very little changes. Was listening to the injectors with a screw driver to the ear could hear them all fireing sounded okay. any chance the pressure regulator by the firewall could cause the issues?
