misledxcracker
About misledxcracker
- Birthday 11/02/1985
Location
Bullhead City
Interests
Subaru!
Vehicles
'87 XT N/A 2WD 5MT
misledxcracker's Achievements
Certified Subaru Nut (8/11)
10
Its been leaking gear oil for quite a while now, but when I drained it there were about two and a half quarts left in it.I'm assuming I need a whole different transmission then? No way I could split this transmission and possibly fix it? I can't find a tranny, let alone 2WD for any less than $200. How much do these trannys weigh approximately? I gotta hurry and get this thing on the road, stuck in New Mexico and its no fun...
I figured it out! My diff isn't toast... Apparently using a bolt/nut in place of the roll pin on the axle isn't such a hot idea... The nut and bolt apparently fell off somewhere, allowing the DOJ end of the axle to repeatedly slam into the shaft seal until it finally knocked the bearing sideways! The shaft now turns like it should, one going one way and the opposite side going the other way. No grinds, no thumping noise and no binding. No metal in the gear oil! I think it'll be fine
Just read another thread similar to mine... I did get a loud pop then it seriously felt like the tire went flat. Managed to drive it this way for five miles then I lost all gears. The speedometer goes up JUST like a broken CV would cause. Already over halfway pulling the transmission.... I'm really hoping I'm not wasting my time pulling it. Neither of the axles have split or deformed boots and they're both less than a year old. It seriously seems like it wants to somewhat catch when I wiggle the CVs on the DOJ area... maybe the output shaft bearing(s) went? I have a strong feeling the diff didn't exactly grenade just because it let me get so far after it happened...
Hey everyone, been off the forum a while... I have an '87 XT, 2WD 5MT, N/A MPFI... almost 190K miles Anyhow, so I drove out of Los Angeles and got to Albuquerque when I heard a LOUD bang noise and it surely seemed like I blew a CV for the millionth time, as the car was shaking and rattling like hell... but I somehow managed to pull into a parking lot. Now I don't have any gears whatsoever, not even reverse. The best way I can describe the noise is it sounded like marbles were in the transmission. I was well aware that the axle seals on the tranny were leaking and they had been for a while. I took off the axles to see if the output shafts move and apparently they do not. I can feel a little bit of play at the shafts. What's crazy is the speedometer moves like a typical axle failure but I don't see a single thing wrong with the axles. OK now if I have it running and in gear, I can wiggle the DOJ around and it sounds like a clanking/popping noise but doesn't move the shafts. I can put it in any gear without any resistance or odd noises. Could it be possible that an output shaft?
Loud engine ticking started suddenly?
misledxcracker replied to Ropre's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When I reseal an oil pump, I use wheel bearing grease, as it's kinda "heavy". NO on the RTV -
throttle sensor
misledxcracker replied to Coldfusion868's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Once you get it adjusted, you may want to mark it somehow so you can re-position it again if needed be. Kinda like marking a distributor I guess. -
Checked that pin, Naru you were absolutely right. Car runs and drives now. What did I do? Trusting my instincts to a point, I went and yanked another CAS out of an Isuzu Trooper (third CAS) and the XT fired up no problem! Thank you Cougar and Naru for helping me out, at least now I know a lot more about wiring and such Now watch the Jag take a dump on me.... LOL
1989 Subaru XT? or is it?
Clean all the grounds you can find (the FSM has this information, you can find it on subaruxt.com) and also maybe clean up the coil bracket connection a little. Clean up the coolant temperature sensor contacts (on the intake, not the radiator) and inspect the wiring that plugs into it.... may need to replace that! The main wiring harness runs under the carpet/seat on the passenger side, it may be in your best interest to check out the crimp connections on the harness under the sill plate, repair as needed. There's also a ground under there... There are some things that interchange with the XT but very few. I have an '87 with MPFI and without a turbo. Cool little cars, get tons of compliments, but oh boy are they problematic.... still trying to figure out WHY Subaru put the ECU in the trunk! -
I know how to swap the CAS out of the distributor. Subaru is not the only one that uses these rather specific CAS units.... Mercury Villagers and Isuzu Troopers do as well. Wow, my Jag does not have a single issue, yet my XT is parked and inoperable..... Should be the other way around! 91 octane and a straight 6 really kills me on gas!
brute clutch kit okay?
misledxcracker replied to Danny88GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a 2WD MPFI XT.... I went for a Sachs kit from the local auto parts store, it was around $100 and came with practically everything needed. I saw that Brute Force kit... decided it was "too cheap" for my liking. And just a reminder, be careful on whom does the machining on the flywheel if you choose to do so!
