Toadspit
Everything posted by Toadspit
/No they refused to waive the core but after leaving at 5am and getting back at 4pm I now have the used transmission bolted in but it's still at the shop and I'll finish hooking everything back up in the morning. Thankfully I have a good friend at work that jumped at the idea to make a road trip out of it with me because there is a pretty good chance my old van would not have made it. I made sure he didn't have to spend a dime on food or gas. I figured it was the least I could do.
I've checked Craigslist and had no luck which suprised me because I've seen them crashed on there before and I've even purchased a subaru legacy L on there that turned out to be an awesome deal. I finished pulling the transmission on mine yesterday after work. I ended up not pulling the engine a 3Rd time and it wasn't as difficult as I thought it would be. I've also gotten all of the external parts and the exhaust hanger off of it but I'm still nervous about needing something off of it after the exchange so I will call them today and ask about waiving the core charge. Thanks for the input guys
I'm pondering that option right now. The only thing that makes that such a tough call is the transmission that fit my criteria is 225 or so miles away. Returning the core later makes that a 1000 trip. I wish I could have found one with decent milage much closer but subarus aren't quite as popular here as they are in other places
okay guys thanks for the input. First of all sorry about the post being confusing. I was on the clock and tried to post really fast. Apparently it was way too fast. I have taken my outback to my place of employment to start this swap. It is kind of nice being able to do this kind of work in a climate controlled garage which I don't have at home. So tomorrow after work I'll go to our grounds shop and start the removal process and I'll be taking the core to the yard that the used AT is coming from. I have no idea what a junkyard wants with the core but ooh well. I'm not sure what I should strip from the old AT but solenoids come to mind first. I'm pretty sure the clutch packs are gone in the old one since I had no transmission codes but I didn't have AWD. Thank you all for your input. I am greatful. Any other comments or suggestions are much appreciated
mine wasn't quite like yours in that mine would start and barely run and it never got over a few hundred rpm and then died. I quick test of the TPS with your Ohm meter while opening and closing the throttle will either prove or disprove this. If your ohms don't go up and down in relation to the throttle position then remove your TPS and open the throttle just a hair and hold it while reinstalling the TPS
I have changed clutch, pressure plate, pilot bearing with fork, retainer clips and all while just sliding the mt back after removing exhaust and drive shift but I wouldn't count on it being a clutch failure. I'm guessing you've already washed your hands of the deal by now but thought I'd throw in my 2 cents
I thought that the noise I was hearing between the engine and bell housing was my torque converter but after replacing it I drove it only about 40 miles before there was a loud knock, only once but it then became obvious that the AT was toast so if anybody knows where I can get a decent transmission at a fair price feel free to chime in
Voltage drop to fuel pump
Toadspit replied to soobie87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
loose or broken connections would be where I would start. next I would visually inspect the fuel pump wires from the pump all the way to the fuse. voltage drop generally occurs when a run of wire is too small for its length. As am example I've installed really long runs of wire for street lights and to prevent voltage drop we start with a wire bigger than your thumb at the begging of the run and end up with a wire that is no bigger than a pencil led. My point is that if anywhere along your fuel pump wire is partly cut or has damaged connectors that would reduce the amount of surface that current can be carried on it will result in voltage drop -
How important is it to have the outer sleeve attached to the new TC before install? My c clip is trashed and I have the engine pulled in a friend's garage and I'm 6 inches from being able to close the garage door and I don't wanna get him robbed of tools in the middle of the night. When I first swapped the engine in this thing I had no choice but to pull the TC still attached to the flex plate and I installed it by just sliding it all back together but since this is a new one I need to know if it's bad to install it without the snout Thanks in advance
seems to me that there is a need to look elsewhere. Although losing power steering fluid from the pump would possible distribute it mainly across the right side of the engine especially at high speeds I believe that the loss of 1 quart of oil every 600 miles would have me looking somewhere else before I attempted to purchase a now PS pump. Personally I've never seen a valve cover distribute leaked oil in the manner described. I should also add that I've never seen the seal at the block halfs leak either . That doesn't mean it doesn't happen but I have never seen it I'm sure there are others with more Subaru experience than me though. wish I had more to offer
