About djcommie
- Birthday 07/17/1983
Contact Methods
AIM
sadjcommie
Website URL
http://daihatsu-fans.org
Skype
sa-djcommie
Gender
Male
Location
San Luis Obispo, CA
Interests
Daihatsus and Subarus. Also 323 GTXs
Occupation
Racing Communications
Referral
jamal from legacycentral/NASIOC
Biography
funky and japanese cars. Daihatsus and Subarus
Vehicles
1978 Subaru GL Wagon 4WD, 89 Daihatsu Charade
djcommie's Achievements
Advanced Member (3/11)
22
Steering Wheel Hub Adapter - 79 GF
djcommie replied to Cox Racing's topic in Historic Subaru Forum: 50's thru 70's
If you can find a hub for second gen cars, the splines are the same. I used a 1983 steering wheel in my 78 GL wagon. -
I think my Coil Ignitor Quit, How to Fix ?
djcommie replied to junk250's topic in Historic Subaru Forum: 50's thru 70's
I have collected at least 2 complete distributor+ignitor combos for the electronic ignition EA71s. I have both the Hitachi (external) and NipponDenso (internal) setups if you're interested. I sold my wagon, so I don't need them. -
The "help me finish my coupe" thread
djcommie replied to Datsunrides's topic in Historic Subaru Forum: 50's thru 70's
If the radiator is the same as a 78 wagon's, I have a freshly painted and tested one you can have for $25. It is only missing the fan switch, the one it had was busted. I have a fan shroud, but not a motor for it. You could probably fit a better than stock motor/fan in it. -
Help me identify and source a distributor cap
djcommie replied to jnorion's topic in Historic Subaru Forum: 50's thru 70's
If that is an EA71, its a Denso points style with single advance. I see PACE SETTER Part # C605Z may fit, it has holes and specifically mentions the Denso distributor. All the Hitachi units are clip on, and I even think the electronic ignition Denso units are clip on as well. -
Never got around to posting it...1978 Subaru GL Wagon 4WD
djcommie replied to djcommie's topic in Members Rides
I finally got it through smog and the DMV, and put 1400 miles on it in 3 weeks on my 45 mile commute. -
1st gen windshield and back glass gaskets needed
djcommie replied to overn's topic in Historic Subaru Forum: 50's thru 70's
I'm not running the chrome strip on the winshield or rear glass and haven't had any issues. -
Group buy - Rear diff bushings
djcommie replied to moosens's topic in Historic Subaru Forum: 50's thru 70's
I'll do a Google Sketchup drawing sometime with them, the interesting thing is that the outrigger (moustache bar) bushings are the same as the front hanger mount bushings. In addition to that part about the stopper bushings being the same as later cars, in addition to the fact that I could actually get the Gen 1 bushings might mean we don't have to make them except for performance versions of high durometer urethane. -
I always wondered how you get all the vacuum advance/retard functions working properly with the Weber, and I guess the answer is you don't and just run on centrifugal advance.
What would this all cost shipped to 93453: brown seat cover intermittent wiper box heater core (have whole box assembly?) key/lock set for wagon I could also use: heater levers/cables/controls (I only really need the mode setting plastic levers on top of the heater core that the cables attach) 2 door handle trim pieces interior panel on the wagon rear hatch (black)
