dp213
2
dp213 last won the day on October 5 2017
dp213 had the most liked content!
Location
Stanwood, WA
Referral
internet
Biography
I'm a diy kinda guy and I enjoy playing with Subaru's.
Vehicles
98 outback wagon, 2000 legacy wagon
dp213's Achievements
Subaru Fanatic! (6/11)
35
Hi folks, long time, no visit from me. A friend has an 01 no turbo impreza with a p0301 code. The engine has about 20k on it since complete rebuild and until yesterday has been perfect. I know it's a cylinder 1 misfire, just trying to give him some advice for fixing it as he is to far away. The car runs fine at freeway speeds but when you slow down to a stop it almost dies. He swapped plug wires and plugs, but no change. Compression is 150 on #1. Any ideas would be great, and by the way, hes not very mechanical and hes nowhere near somewhere to take it to get checked. Thanks Dp
05 impreza
dp213 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I though forester 2.5 was the same from 99 to 04 or 05. -
I am about to do the VC on a 02 wrx. It looks pretty straight forward, but are there any little odd things I may run into? Like any o rings or seals to change. Also for the housing coming off, should I use a new gasket, or is it like the tranny pan and use a good sealer? Any advise would help. Thanks Dp
I have a 99 outback with a 93 2.2 motor in it. For 2 years now it in as has no problems at all. Now it has start in ng issues sometimes. You turn the key to start it and nothing. No click or anything. I replaced the starter with a napa starter and it was good for a couple months, it it did it again today. I didn't think to try starting it in neutral last time, but today I tried it and it started right up. It's an auto tranny. Am I looking at a neutral safety switch and if so, where is it located? Thanks Dp
My sister recently bought a 2010 outback. Today after a quick rinse with a pressure washer, they started it and noticed a bunch of stuff wasn't working. The radio, heated seats, computer display and a few other things. They stopped to get some fuses and when they started it again, everything worked. Any idea what might have caused that. Thanks
I've done a couple of those swaps and I have ordered the timing kit for an 2.5 and it works perfect. So your stuff will work. As for power loss, a bit, but not enough to be really disappointed.
- 8 replies
- timing belt
- engine swap
(and 2 more)
Tagged with:
Battery Help
dp213 replied to WhtMke's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
No. That's not cca. If the battery is old and week, or low on water, your volts might be low. Have you had the battery and alternator tested?
