dp213
2
Everything posted by dp213
Yes it is for the windshield. I had to look really close on my 99 outback to see the element in the bottom 3 inches. It was almost unseeable, but it was there. If it isn't, then yes, you would have to replace the windshield. I had one done in a 99 outback and it was $280 then yesterday I had one done in a 2000 outback at the same shop and it was $230.
outback
dp213 replied to dangerous's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If your in Washington, we are selling a 2000 outback with 150k on it. Head gaskets done at 110k, and I am going to install new timing kit this week and reseal the complete motor. It's a great car, but she wants the very nice 98 Gt I am working on. Just a thought. By the way, asking price it $4300 -
If it was just a lite high, it has probably done no damage, and probably my not the reason for oil in the tubes. It probably needs new tube seals and you should do the valve cover gaskets also since you have to remove them to do the seals. As for how hard, I'm not positive, but after 06, getting the valve covers off with the engine in the car isn't fun. Hopefully someone will verify, but I think you have to raise the engine aittle to get the drivers side off. Again, I'm not positive.
- 15 replies
- spark plug
- oil
(and 1 more)
Tagged with:
I have a 99 Forester engine that I want to put into a 2000 outback. Only thing I'm not sure of is the oil filter on the Forester motor. It has a big adapter with a couple hoses running to it, where the outback doesn't. Looks like I can just pull the adapter, but 1 hose goes right into the block. Any ideas what to do
If you are a fan of the older outback, like me, I have replaced the dual cam 2.5 with the 2.2 from anywhere from 1990 - 1995. I have done about 15 of them and everyone has been very happy with them. The early 2.2 is non interference and has the dual port heads so you don't have to change the y pipe. I currently have a 97 outback with a 93 2.2 in it and it has entry of power. It's an easy swap and with a 95 - 98 2.2 intake, it's pretty much if and play. Just my 2 cents
Valve clearance
dp213 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Everything looked good, so I picked picked up the 99 head gaskets today. They are thicker than the 2000 gaskets, so I am pulling the motor in the morning and going to try and do the head gaskets and have it running again by hopefully 2 or 3 tomorrow. I will update with the outcome when I get done. Thanks -
Valve clearance
My fear is, if the valves are making contact, even though the motor runs good, are the valves probably damaged? It has about 20 miles run time on it
