dp213
    2
Everything posted by dp213
  1. I just did my belt yesterday and it looked almost identical to your line up. Mine runs great.
  2. I agree with that. I'm not a big fan either. I did it for a temp fix until I had time to do thechead gaskets. I am going to do head gaskets on an older Suby tomorrow but I have not done a h6. I do know there are 56 bolts in the timing cover alone. And dual timing chains with a lot of guides to keep them in place. :-)
  3. They say that the blue devil head gasket repair is the best. Its usually available at any parts store and they keep it in back so you have to ask for it. (People like to steel it, its expensive). It worked on a ranger for me. But the problem is it sounds like exhaust side is leaking into water side. If that's the case, it probably wont work because the pressure is flowing the wrong way for the additive to get to the leak.
  4. They say that the blue devil head gasket repair is the best. Its usually available at any parts store and they keep it in back so you have to ask for it. (People like to steel it, its expensive). It worked on a ranger for me. But the problem is it sounds like exhaust side is leaking into water side. If that's the case, it probably wont work because the pressure is flowing the wrong way for the additive to get to the leak.
  5. Both cars are 5 speeds. So I can use the 2.2 motor and intake, will I have any cel to deal with
  6. I found out its a 98 2.2 from an impreza with a 5 speed. The outback is a 5 speed also.
  7. I have a 98 2.2 from an impreza that I want to use to replace the bad 2.5 in my 98 outback. Can it be done without a lot of hassle? Do I use the 2.2 or 2.5 intake.
  8. What about the cyclops headlight option they had on brats. I am working on a brat and the guy has a cyclops grill he wants me to install. Also this brat has flip up ttops.
  9. Thank you very much for the info. Dp213
  10. Can I put a 2.2 motor from a 2002 impreza into a 1998 outback. Thanks
  11. Can I put a 2.2 motor from a 2002 impreza into a 1998 outback. Thanks
  12. I can't figure out what year the ea81 motor is. Does year matter when ordering gaskets. Also are the ea82 heads the same as an ea81.
  13. I am about to go through an ea81 motor for a friends brat. Is there a recommended brand for a gasket set. (Head, intake, valve covers, etc). Also with a lot of miles on it, what else should I think about doing to it? Thanks
  14. Will lowering coilovers from a 2001 forester work on my 98 gt wagon. Dp213
  15. Doing a compression check after work tomorrow and going to see if I can find a vacuum gauge also
  16. Looks like #1 & #3 aren't firing. I changed the plugs, wires, and distributor. No change.
