dp213
2
Everything posted by dp213
Well, I have figured out the fans aren't working. I plugged the green test plugs in and they work, but otherwise they don't work. There are 2 sensors in the coolant tube that goes across the top of the motor, is the single wire sensor feed the temp gauge and the multi wire sensor right next to it the one that controls the fans?
My 98 gt has been getting hot sometimes. I had a leak down test done and that was fine. I then replaced the water pump, thermostat, and radiator. It was fine for a couple days, but now it's doing it again. The only thing I haven't changed is the heater core and this morning I noticed a bit of a film on the lower windshield inside. It's not losing coolant anywhere and it's not pushing bubbles into the overflow.
Blinker issue
dp213 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Will do. Thanks -
P1121 still
The switch in mine does not have a plug on the switch. The wires come out of the switch and run up by the engine bay. Can I use one that has the plug at the switch and just get the extension to go with it. -
P1121 still
That's the one I thought. 97 gt wagon with auto -
P1121 still
On an auto tranny, is it the switch on the passenger side of the tranny? -
P1121
Is the neutral safety switch on the passenger side of the tranny -
I have a 98 gt wagon with auto trans. A year ago when I ought it both motor and tranny were bad. I swapped in a low miles tranny and rear end from a 97 legacy and a high miles 95 2.2 motor. Last week motor died so I just installed a different low miles 95 2.2. Car runs and drives great, but now it is throwing a p1121 code. (Neutral safety switch) I clear it and it comes back the second time I start it every time. Car still runs and drives great, I just don't have any idea where the neutral safety switch is or what would cause this.
Last week I posted about the 99 obw I bought. The po was doing 65 on the freeway and lost power. Shop said timing went and motor was bad. I bought it with the intent of swapping motors. When I opened up the timing covers one of the idler pulleys was in pieces. I decided to put a new one on and retime it and it runs perfect. No valve damage was done. Well I picked up a 99 legacy gt sedan, also with a dual cam 2.5 that had rear ended a truck. Motor looked fine except a very small hole in the passenger side timing cover. I tried starting it but it had no spark. After trying and trying, I decided to open up the timing cover. I found the upper passenger side cam pulley was shattered. I put a new pulley on it and timed it and it started and runs perfect. So that 2 for 2 in 2 weeks that double cam 2.5 motors have had catastrophic timing failure, but yet no internal damage. So my question is, does everyone just assume those motors are bad when timing fails? Or am I really that lucky? I'm starting to question all that I've read about valve damage when timing fails.
