dp213
2
Everything posted by dp213
There should be about 6 total plastic clips that hold the grill on. I think it's 4 across the top and 2 lower. The top ones you can usually get a pair of needle nose and squeeze the release tabs in and pull out gently on the grill. The lower ones are a bit harder. Your supposed to be able to lift straight up on the grill, but the clips like to break. Subaru still sells all of the grill clips if they do break, but it's about $5 each.
CEL
dp213 replied to Twagoss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Go to an auto parts store and have them scan it -
97 outback
dp213 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
HAS, did your thumb button still push in even though it wouldn't shift out of park -
97 outback
Does unplugging it disable the power door locks. And also where under the dash is it. I can't find it -
Is there any way to remove the factory alarm from my outback. It goes into security mode (marker lights flashing) for no reason sometimes, and won't start. I don't have the remote button, and only about half the time hiring the lock button on the door will turn it off. Usually I have to remove the negative battery cable and reconnect it with key on. I have dealt with it for about a year, but now I'm going to sell the car and I need to fix it. Thanks
95 2.2 oil pump
Thank you -
Tranny issue?
Don't remember, got it from the shop I bought the tranny from. It was what they (require). -
Tranny issue?
It's an auto and all fluids are correct and at the right level. -
You did use the marks on the pullies and not the arrows when lining everything up?
- 4 replies
- 2.5L
- timing belt
(and 2 more)
Tagged with:
