About its_masters
- Birthday 05/20/1997
Gender
Male
Location
United States
Interests
autocross, rallycross, hunting, automotive, business, computers, music
Occupation
Crew Member @ Little Caesars
Vehicles
1998 Subaru Legacy Outback Limited 5 Speed
its_masters's Achievements
Advanced Member (3/11)
2
I recently blew my stock engine which is an EJ251. I just picked up a low milage engine out of an 09, which I believe is an EJ253 with Variable Valve Timing. I was told swapping my heads and intake will work, but from reading some of other posts, I'm not so sure. Some say that the pistons are shaped differently and hit the valves of the 251 heads. Some say to just leave the 253 heads on and keep the VVT disconnected. I'm not really sure what to do here. Any help is appreciated!
I did a tranny swap a week or so ago and then the car sat in the garage a few days while I was on vacation. I drove it before hand And had 0 problems. On the way home I did blow a ball joint how ever but that problem is now taken care of. I can shift into all of my other gears, but cannot shift into reverse. Please help! I can't be without a vehicle!
I'm swapping parts from my 98 trans to my 97 trans (doing a drivetrain swap), and the clutch fork doesnt seem to want to stay in place. It seems like the clip slips off the pivot ball. I had this problem last time as well, the TOB would slide too far off the shaft. I was told to get an 06+ fork, but that involves a new fork, TOB, and pivot ball, and i dont really want to spend the money for that...
Every now and again my buddies tranny (or in that general area) makes a noise like your going over a rumble strip and then makes a popping noise. Im thinking it's either the CV joint or a U joint. Can anyone confirm this? I just wanted to make sure it isnt a common issue that i missed. Thanks in advance!
Yepp. Planned on doing all that while i have it out. I've replaced one of those separator plates in a different subaru already, the darn thing was cracked all to hell and leaking everywhere in there. The upgrade helped out a lot. I don't have any trusted machinists around here anymore (they managed to destroy my previous flywheel and still tried to charge me) so if i have to get the flywheel resurfaced, i may just buy a new one unless a different shop has popped up since then. So talking about gear ratios, how will the 3.90 be compared to the 4.11? I can't imagine much, but is there anything should expect?
