43
brus brother last won the day on August 25 2024
brus brother had the most liked content!
About brus brother
- Birthday 02/02/1952
Contact Methods
Website URL
http://
Gender
Not Telling
Location
Connecticut
Occupation
Dentist
Vehicles
08 OB, 05 OB, 05 sedan
Recent Profile Visitors
brus brother's Achievements
Subaru Master (10/11)
328
2 years ago I was in Lake Placid NY overnight -30F Alternator screamed like a banshee in the morning. Went into local Autozone and clerk said to wait til noon when temps return to tolerable. Followed his advice and all was good after a late breakfast. Before jumping to conclusions, I suggest pancakes and bacon.
My 2008 ran like crap after high humidity/cool conditions. Was ready to change out coil pack and instead dried out the interior contacts of the pack where the wires plug in and sprayed with WD40 and all was well. Have you tried spraying water around the wires when dark outside with car running to see if there are any sparkly light shows? In my case, I didn't have the light show but the rough running was related to the damp coil pack. Fingers crossed for something simple.
I just packed the hole. No mesh. My repair was in the crotch of a y as the exhaust splits to 2 mufflers. Just checked out of curiosity and it is still holding strong. Couldn't hurt to create a "wrap" of the edges of the hole where some material is on the inside and some on the outside and then fill in the middle. Or tuck a tiny piece of copper mesh on the inside slathered with the sealant. Attach and use a piece of dental floss or thin string to pull the patch up against the inner wall and then slather on a coat on the exterior surface. The area I worked on wasn't conducive to cleaning so I just relied on the silicone to do its best.
Going on the real cheap for a nickel sized hole, there are furnace repair/sealing silicone caulks available at Home Depot good for 1000 degrees. Cost around $15 for 10 oz caulking tube. I have made some lasting repairs where welds at y junctions failed. Other areas have begun to leak but original repair is still solid 4 years later. https://www.homedepot.com/p/3M-10-1-fl-oz-Red-Fire-Barrier-CP-25WB-Plus-Sealant-CP25WB-10/100166701 "3M™ Fire Barrier Sealant CP 25WB+ shall be a one component, ready-to-use, gun-grade, latex-based, intumescent firestop sealant capable of expanding a minimum of three times its dried volume when exposed to temperatures above 1000°F (538°C)." Beyond 1000 degrees, ya got other problems.
https://www.amazon.com/dp/B09ZXZ3KXK?psc=1&ref=ppx_yo2ov_dt_b_product_details The above link seems to permanently solve the issue for $30. Changes the function to default to OFF. Read the reviews as it appears to not include installation instructions. History: So many complained that SOA did a software upgrade to allow the user to disable this function. Now there is an option on the infotainment screen to disable the function BUT it will default to the ON position each restart. Have you updated the software on your vehicle? This can be done OTA (over the air). I read that the auto stop/start function works when you stomp on the brake pedal. Does it kick in for a soft press? Happily, this function was never available on my 2019 Outback lower end model.
