Everything posted by brus brother
Clutch gone bad
WOW! Can you send directions from Connecticut???
Any other Annoying Airbags?
brus brother replied to BlueSoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm The above site is for TSBs for cars by make, model and year. I guess the best thing to do is complain about every issue on the list and get it on your service record before your warranty expires and then you are covered when the inevitable occurs. You can also roam around this site for safety recalls but you would have been notified of these by SOA.
Hello From A New Member!
brus brother replied to nvrquit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am on my 4th Sub. 84-90-2000-2005 My 2000 Legacy GT handles great even compared to my wife's 05 Legacy OB iLtd. This week I am getting my 2nd reman AT installed on the 2000. Can you post, email me or PM and tell me what were the reasons for twice replacing your transmission. I am still covered under the Gold Plus plan but will soon expire. BTW, there is a site (see below) where you can find a listing of the TSB's on your particular car. That can give you a heads up on potential problems while still under warranty. The same site lists safety recalls but the TSBs cover non safety related issues that SOA has encountered enough to clue their mechanics in to fixes. The TSBs are only in synopsis form but you can get a sense of the scope and number of issues. I have noticed problems on my car that I dealt with myself only to discover through the TSB site that this was a known issue that the dealer could have fixed if only I had complained (ie loose weatherstripping, sunroof problems). Still, for the price, the package seems worthwhile. Yes the good old days were different but... in my area, the 80s and early 90s cars have been reduced to rust dust by this time. http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm
Clutch gone bad
What's a reasonable price for a clutch job on a 93 Legacy? It seems to have begun slipping in 5th gear (worn clutch?) and there is a tweeting noise in neutral that goes away if I slightly engage the clutch (throwout bearing?)... or is there a liquid additive that will cure these ills? Clutchrenew... Tweetnomore?
Rear Sunroof Sunshade Problems
I had the same issue with my 2000 Legacy GT. From the outside, open the door and stand on the doorsill with the moonroof open so you can see what's going on. In my case, the back moonroof shade had jumped the track similar to what you describe where the window would drag it back when opening the window. Examine both sides and you should be able to determine which one rides smoothly in the track and then try and gently reposition the misguided side. Then run around the yard yelling TADA! There is a Technical Service Bulletin: http://www-odi.nhtsa.dot.gov/cars/problems/tsb/results.cfm Make : SUBARU Model : LEGACY Year : 2000 Manufacturer : SUBARU OF AMERICA, INC. Service Bulletin Num : 128003 Date of Bulletin: MAY 19, 2003 NHTSA Item Number: 10001727 Component: VISIBILITY:SUN ROOF ASSEMBLY Summary: SUNSHADE FOR REAR SUNROOF ON DUAL SUNROOF MODELS. The following website is specific to your car's TSBs but doesn't mention this condition. Check out the other issues. These are not NHTSA safety recalls but rather SOA heads up bulletins for their dealerships. http://www-odi.nhtsa.dot.gov/cars/problems/tsb/results.cfm It's easy finding your way when you know where you are going!
Approx. cost of new exhaust?
brus brother replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck out JCWhitney.com and add up the numbers
hi, my names tony, im a welder addict
I've heard that it starts out innocently enough with soldering and then its a slippery slope into the dark (you have to wear those goggles) world of welding. Avoid the temptation to start and "stick" with duct tape.
Front tire causes pulling - rotate or replace
brus brother replied to bohuslav's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the toe and camber was done appropriately and alignment is on and especially since the problem followed the move of the tires, I would suspect something amiss with the tire that brought the problem with the swap. You could move the tire to the rear but then you don't know that the rear tire you bring forward is balanced. $40 to balance all 4 tires and when they are on the machine (or even just balance the one tire that brought the problem along when you moved it), the tech can tell you if you have a bent rim or even a defective tire. Put the 2 best tires/rims on the front and let us know. 10K is too soon to replace a tire unless defective and if it is defective, you should be able to get an adjustment from the seller.
brus brother replied to bohuslav's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you have the tire rebalanced??
sluggish window motor?
Just got back from the hardware store and it seems like Silicone spray (by Gunk) would do the trick for the rubber and white lithium grease for parts metal. Any objections?
Morphing an OB into GT
If my memory serves me, the Outback 2.5i Ltd is equipped with a LSD as well as side airbags (I know, the airbags haven't tested well in gov't assessment) and I kinda liked the bigger hips on the OB (NOT my preference in women though). Seems like I might try the rear sway bar upgrade and see what gives for my first tire replacement.
The automatic window doesn't want to close the last inch or so without a little tug on the glass. Is this a case of the motor on its last legs?
So it looks like I'm off to sway bar land. Where do I buy them and is installation a DIY project? Any special tools?
Hey Doc, We already owned a 2000GT and didn't want to appear that we were running a fleet service out of the house. More important, I hate the hood scoop "boy racer" look, added maintenance and the high test fuel requirement of the turbo. I know that they actually made the hood scoop functional this year but it's still not for me. The feeling of driving the OB is much less adherent on turns and that's why I question the height of the car. Could different tires enhance road huggability?
erratic engagement
Travelling in a snow storm it seemed like suddenly there was little power going to the drive. 93 Legacy manual transmission. Shifted down from 5th to 4th gear and it seems to have grabbed, shift back to 5th and it seemed to go for a while and then the same thing happened again. It wasn't apparent uinder dry conditions. Pardon the lack of clarity but I wasn't in the car when it happened. There is a little tweeting probably from the throwout bearing that you can hear at idle and disappears if you just slightly engage the clutch. I'm hoping for a "Tweet No More" additive to pour on the hood of the car and that it may also solve the mystery in the drive. Any other suggestions appreciated.
I recently bought an 05 OB 2.5iLtd for my wife. It's looks nice enough but the handling is a little disappointing when I compare it to my 00 Legacy GT. They are both automatics and wagons. It feels like I am driving the GT but following the OB. Is the height difference the major contributor in cornering etc. and is there a way to tune up the suspension on the OB to bring back that good ole feeling of the GT?
Losing Coolant
Now isn't the 2000 prone to EXTERNAL HG leaks? I am beginning to suspect something similar in my 00 Legacy GT, but the techs did a visual and said that when they go, they GO! Is it possible that a small leak is under certain conditions allowing a small stream of coolant to evaporate off on the hot engine, leaving no residue. I know that with my trany leak, they added an ultraviolet dye to the fluid and then after a while, inspected the area with a UV light. This might be a solution if you wish to eliminate the possibility of ANY external leaks.
New Trany (Again) 00 Legacy GT
Just found out today that I will be getting another reman auto trany from SOA. First one replaced at 41K due to delay engaging, apparently a known problem with the 00 Legacy. Replacement lasted 28K and started whining between 40-50 mph then making "knocking" sounds in park or neutral. Thank my lucky stars for extended warranty.
new member
brus brother replied to AB/S05Bean's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhot off the dashboard average 24 mpg
new member
brus brother replied to AB/S05Bean's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI see you have the LL Bean. I believe your's is the 6 cyl.. Is it manual or AT? I have the 05 OB 2.5i Ltd. ( a snappy monotone Champagne Gold color... better gas mileage?). It's only a 4 banger and runs on 87 octane with an auto trany. I will have to check the mileage as it is actually the missus' ride. I now drive the cast off 2000 GT also Auto., woe is me . The GT gets about 22 mpg mixed hwy. and kid chauffeur with some pinging at 87 octane, an issue I am trying to resolve. I think I remember seeing a display for mpg on the center gauge panel. I'll check the next time I'm in the car and use the automatic calculator on the dash gauges. It'll take a week or so to get a mileage count by my own calculations so I'll send you a PM if this thread is in mothballs by then.
new member
brus brother replied to AB/S05Bean's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat very minimal post was a cheap ploy by Northguy to inch closer to 2170 posts at which time he is eligible for a free encylclopedia! Cars and their designs are works in progress. My first Sub was a FWD 1984 and the latest is the 05 OBiLtd. Some will make the argument that the older Subes were the reliable workhorses and the new ones are following a road more travelled. Well, I guess as I've gotten older I don't mind some of the newer amenities like cup holders and heated seats (Note: no longer holding a cup of hot coffee precariously between your legs necessitated the need for seat warmers). While the side crash tests were not as glowing as the frontal impact test, it still beats the earlier "no airbag" design. As for the entusiasm of the USMB board members, they have been invaluable in solving mysteries of things Subaru for me and saving me many bucks to boot in the process. Moderator, please note that this current post is much more wordy than Northguy's and could possibly count for bonus posting credits in my total, inching me closer to nirvana. BTW the solid sound of the door closing is impressive on the 05s.
Overfill Oil
Decided to check my oil level after my last FREE oil change at the dealership. Looks at least one if not two quarts over! Generous souls they are. It's past the F hole, and a good ways past the notch in the dipstick. What damage can occur? Seems like every time I leave the dealership, I bring a new problem home with me.
question about 2005- 7 passanger
brus brother replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe term "Tribeca" was coined in the early 80's by clever realtors in lower Manhattan to give name to an otherwise nondescript area of former warehouses, factories and loft spaces. The name stands for the TRIangle BElow CAnal street. The area eventually caught on and is beyond trendy at this point. It was the former home of the World Trade Towers pre 9-11. That is what is in a name.
2005 Forester Wind Noise?
brus brother replied to TRIPOWER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSuzam is correct. I just returned from dealer installing passenger side gusset (did driver's side last week). I asked about the cause of the problem and he pointed out that if you lean against the glass from the inside while getting into the car in a tight space or if you open the door by pulling on the glass, it springs the metal over time and allows for the air gap and noise. He described lowering the window and pinching the metal at the top of the triangular corner to tighten the contact as Suzam describes. He thought that the new pieces he installed might have been re-engineered but who knows.
Lug Nut Torque and Sears Wheel "Technicians" !
brus brother replied to rem14's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot a post hijack! Hey Blitz, Please email me or PM. I have a question regarding an earlier post by you about pinging and can't contact you through the board for clarification. Thanks.
