45
Everything posted by brus brother
You don't say what year it is but I have a 2000 Legacy GT and from day one there was a clunking especially noticeable at slow speed when turning over a slight bump like going into a driveway etc.. After many calls and complaints to SOA, who continued to describe the situation as "normal" (it had first appeared in MY1997 by some mechanic"s recollection), they came up with a fix under warranty that included changing out the power steering lines. I don't think it helped much but more a case that I had grown accustomed to the sound by then. Did you only suddenly become aware of the noise? If not, speak with the dealer or regional rep. from SOA until you are dead certain that you need your wallet lightened. I recall a post on the site about this issue where some had proposed replacing the bushing for the strut as a fix for the "clunking". Is your sound only on one side? If so why did the dealer recommend both struts? Use the Search function here and search under "clunking or clunk" especially on this New Generation forum.
This is a warranty issue and hope you are still covered. There was a recent post about head gasket complaints and one of the respondents pooh poohed HGs as a continuing problem instead "We seem to have more early '00-'02 Legacy's in for delayed engagement of the auto tranny's then headgaskets. (Due to an O-ring not holding pressure, it's been corrected)" You can read and contact by PM or ?email Dr. Outback the author of this quote found at the following link: http://www.ultimatesubaru.org/forum/showthread.php?t=23282&page=2&pp=10&highlight=head+gasket So, lucky you, you don't have head gasket problems but you do have the delayed engagement of AT. I had mine changed out under warranty and the mechanic pretty much ordered the replacement transmission by my description as he had obviously seen it before! Hope this helps.
"Still, there's nothing like popping the hood of some old Detroit iron where you have enough room to sit inside the engine bay with three buddies while you tinker on the engine..." Love the imagery. What does a locking extension look like? I've got a few bucks to squander. As you can see I waited for 68,000 miles to change the plugs and PCV valve and amazingly, the car no longer pings with 89 octane. It's a frickin' miracle and I'm off to Lourdes.
I have a 2000 Legacy GT Wagon and a 2005 OB 2.5i Ltd. They are both automatic but I find the handling and cornering of the 2000GT better than the OB. The OB is a more luxurious car. I might have gone for the GT wagon this year were it not for the damn hood scoop. My desire for the "boy racer" look has passed. That said, I am still a big Sub fan and I feel there is good value in their product and I think the styling for the 05 MY Outback hit the mark. To me the styling has the flavor of a refined Lexus SUV just not as big or trucklike. Buy a Subaru or I'll bloody your nose!
Thanks. Access is a pain having to remove the air intakes on the passenger side and I found I had to lift the washer up and out to get at the drivers side. I tightened the plugs until I felt the crush washer and then a touch more(no torque wrench). I did use the anti-seize grease and that seemed to help them slide home. The damn socket kept coming off and staying on the plug so I duct taped the bugger to the extension. I bought the T wrench but that didn't fit with all the other piping and hoses so that one goes back to Autozone. I may look for an upgrade from the $4 plug socket as the duct tape thing seems compensatory for poor engineering.
http://legacygt.com/forums/showthread.php?t=2023&highlight=seatbelt+warning I don't endorse disabling safety functions. The above site gives instructions on how to disable the CONSTANT warning. The alarm will still ring 5 or so times when you first start the car but then it stops. Follow the directions. It worked for me the first time I tried it. The constant warning reminds me of what I've told my wife on a few occasions, "I heard you twice the first time".
Any tips on changing spark plugs on 2000 Legacy. It's only been 68000 miles and I figured... splurge. Anyway, looks like I need to buy a smaller size spark plug socket for the NGK plugs (not platinum @$2.09 at discountparts.com aka Liberty Subaru in NJ). They seem so far inset that it may be tricky not crossing threads as I don't get much feedback through a wrench and always relied on touch in the past. Any advice from those who have "been there, did it, bought the t-shirt"?
Hate to be the one to ponder the obvious but coincidences do happen. I once was doing some rewiring and somehow simultaneously turned the dashboard dimmer switch on the column down to zero. After some head scratching and fretting I simply readjusted the dimmer and voila Tessler was reborn. This was on a 2000 Legacy and I don't know where or if your's is located but just a thought. Common things happen commonly.
http://www.ultimatesubaru.org/forum/showthread.php?t=20595&page=1&pp=10&highlight=rear+washer The above link should take you to a related post, scroll down to the reponse from Ferret. He talks about a check valve in the rear pillar. I knew I'd find it. Glad you were able to come up with a solution but the fact that there is a Subaru solution should take you back to the dealer that sold you the $50 pump unnecessarily and you can dope slap him.
Subaru Designers Sence of Humor??
brus brother replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Quote: Originally Posted by 4RnrRick Come on guys........ do you know that almost ALL AC compressors say that. It stands for Suction and Discharge. ....and your point would be? -
Exhaust Fixed! Thanks Guys!
"oily Loyale"? Is there any other kind of Loyale. Great that Moosens has parts for.... EVERYTHING! Good to meet y'all. Safe driving. -
Doesn't seem that the class action was allowed by the courts! So what is the next best step? The time frame seems shorter than the class action mentioned but I guess you'd be better off spending your time pleading your own case. They have the law power to wear you down. Contact SOA directly and ask how THEY have decided to respond to the well documented problem with these HGs. Speak of their supposed reputation for reliability. If they balk,at least ask if they will make accomodations to purchase of new vehicle since you may still be inclined to trust their reliability.
John, I agree with your sentiments. Unfortunately SOA has tried to keep this problem quiet. This website is an aberation from the norm in that there are many here who are real car enthusiasts. Cars are not sold just to this type but rather to the many others who barely know where the gas filler cap is located. The newer Subes don't seem to share the reliability of the 1st Gen variety and the price tag has certainly strayed from the utilitarian. Still I recently bought an 05 OB i Ltd and this is now the 4th Sub I've owned. If you bought the 99 from a dealer, I would think you should have received the courtesy of advisory and extended coverage. As I stated earlier, I wasn't sure if the 99 was covered for external HG leaks but you seem confident so, contact SOA and beat them 'till they are dead and then kick them twice afterwards. Wait for a response and then repeat the procedure mentioned above. G'luck
Are there any tried and true leather care products/techniques? I'd like to maintain that new leather look as long as possible but I wonder if it is a losing battle. I ignored this on my sofa (under a skylight and UV effects) and eventually it cracked and faded. I'm hoping my 05 lasts "forever" and the leather interior doesn't give away its age over time.
