Everything posted by brus brother
Shot Brake Caliper?
So many possibilities, cv, rotors, calipers, rattling heat shields, all the while trying to outrun the rust... but there's good rubber on the road thanks to you. Drive safe and mind those bugs up north.
Shot Brake Caliper?
- Shot Brake Caliper?
90 Loyale. At first I thought I was dealing with some front suspension gremlin but now it seems brake related. Occasionally I get this horrible groaning/ginding noise on slow braking. It may be more obvious when turning at the same time. I can feel it right through the steering. The brake pads are new. I didn't resurface the rotor. Is it possible that the piston from the caliper is getting hung up and causing these symptoms?- groaning front end
90 Loyale makes a horrible groaning sound when hard turning right at dead slow speed. I can feel it in the steering. I checked ps fluid level. Is there some bushing or whatnot that could be the culprit. How to diagnose?- 90 loyale power steering
I seem to keep adding power steering fluid. Where does it go?? I don't seem to have any major external leak? Is there any problem with filling beond "capacity"?- Power Steering problem on '93 Legacy
brus brother replied to syphon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs there such a thing as overfilling the PS reservoir?- Power Steering problem on '93 Legacy
brus brother replied to syphon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLast time I had symptoms, I too thought the fluid "looked fine" but in reality, the fluid level was low! I'm not sure how the reservoir is set up but it took a fair amount of Dextron to top it off. Symptoms gone.- Where does one get paint for these old school cars?
Unless you are going to paint your entire car, I've been told that pro paint shops have a sampling "gun" that works similar to how Home Depot/Lowes matches paint color. This will take into account matching old faded paint. P.S. Rustoleum white works great on my 90 Loyale. I use it on a monthly basis to touch up rust spots kinda like acne coverup cream.- tire size
I need new tires for my 90 Loyale 4WD wagon. I've gotten differing recommendations for size. The placard on the drivers column says 165/13 when talking about load. I currently have 165/80/13 on the car. TireRack recommends 185/70/13. Other on-line stores say 175/70/13. What gives?- tire size
I need new tires for my 90 Loyale 4WD wagon. I've gotten differing recommendations for size. The placard on the drivers column says 165/13 when talking about load. I currently have 165/80/13 on the car. TireRack recommends 185/70/13. Other on-line stores say 175/70/13. What gives?- CEL 1997 Outback
There is unfortunately a "knock" coming from the lower engine! I wish it was just a misinformed sensor! Hep me pleeeze.- CEL 1997 Outback
I've got a 97 Outback with 168,000 miles. HG repaired at 110,000. Now I'm getting a CEL that local mechanic states is a knock sensor? from the lower engine. The light comes on and goes off without much rhyme or reason. Is this something that will kill the engine sooner than later? Is there anything that can be done other than a rebuild or replace?? Thanks- EJ22 valve cover leak
brus brother replied to teppichkopf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes this engine also have the little boots (washers) around the valve cover bolts? That's where mine leaked and the oil just made it's way down. Feel around the bolts to try to determine actual source of leaks. The suggestion to clean the engine first and then do some diagnosis before opening her up is a good tip.- Engine revving uncontrollably
brus brother replied to farnhamt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd take Subau of America up on their kind offer of 3yr/36,000 warranty. Let them figure it out or at the very least, create a record on file. Good luck.- strange clicking sound gives me a "spyhunter" style smokescreen
http://home.comcast.net/~c.moe/pvc_mod.pdf This will take you to a FSB about this very problem of smoking on hard right turns. I too freaked the first time I experienced it and started dreaming about my next car. Anyway, I never did the recommended fix but did replace the PCV valve (courtesy of Moosens - thank you) and haven't noticed the problem since. I hope the ticking is as simple a problem to solve.- Reverse squeal
brus brother replied to jeddkaren's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCookie is right. Search and ye shall find. Indeed as I recall the post, there is an upgraded (larger) rotor and brake assembly on later models that accomodates the increase in weight. See if the dealer or SOA would cut you a deal to upgrade now since you'll have to be paying the price every 25K miles yourself otherwise.- Transmission has delay in engaging
brus brother replied to iayers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup, my tranny (00 Legacy GT 36K) was replaced under warranty. It was slow going from R to D and attributed to some sort of solenoid as I recall and the dealer even gave me a loaner while they swapped out the tranny.- new member- car trouble
brus brother replied to badgah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am no "rocket surgeon" when it comes to ABS but are the brake pads and fluid within normal limits? I think my brake light (ABS?) came on when the pads wore to the point of creating very low brake fluid in the reservoir. Brian, welcome to the site where the mutterings of genius and madmen are posted side by side. Regards, The Mad Hatter- Help won't start and it has to be done today
brus brother replied to sho's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVacuum line to the EGR solenoid?- Help won't start and it has to be done today
brus brother replied to sho's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen did it start to run "crappy"? My 90 Loyale went belly up after I hosed off the engine. Spark plug wires or connections? Try using the old wires or verify good contact. Residual water in distributor cap or coil plug insert? Dry out inside of distributor cap... if you've got one on the Leg 91. Common things happen commonly! If you hear something clip clopping down the road, chances are that is a horse and not a zebra (exception for those USMB members from Africa).- Ineptitude is my middle name (CD player)
brus brother replied to Lesbaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn addition to Shawn's warning, be certain that you only use genuine Subaru tweezers and bandana when working on the CD player.- Ineptitude is my middle name (CD player)
brus brother replied to Lesbaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.repairfaq.org/REPAIR/F_cdfaq4.html#CDFAQ_009 I searched the site a little more. Looks like eithjer a stretched band in the transport or chipped or dirty gears. Let me know what it looks like once you've performed exploratory suirgery.- i want to know who doesn't .........
brus brother replied to legacy2.5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX00 Legacy GT. 60K miles. Transmission replaced under warranty at 30K as it lagged going from reverse to drive. As far as the HG no problems yet... as the fellow who fell from a skyscraper yelled at each floor going by... so far so good. I did get the stop leak added last time at the dealer to get the extended 8 yr/100K warranty on the external HG leak.- coolant additvie question
brus brother replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDitto on getting them to replace your gaskets again/ resurface heads and THEN put the oatmeal in for good measure! Show no mercy, they admit they have a problem now. Did you have to pay the first time around as I think they are reimbursing those who paid themselves before they admitted the problem. Good luck.- Ineptitude is my middle name (CD player)
brus brother replied to Lesbaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.repairfaq.org/REPAIR/F_cdfaq.html Work your way through this site. I don't know if your's is belt driven or gear driven. The rubber bands stretch and lose function and earlier cassettes and cds were notorious for just such problems. Hope this helps. PS this showed up as a simple Google "CD Repair" search. - Shot Brake Caliper?
