43
Everything posted by brus brother
Cookie is right. Search and ye shall find. Indeed as I recall the post, there is an upgraded (larger) rotor and brake assembly on later models that accomodates the increase in weight. See if the dealer or SOA would cut you a deal to upgrade now since you'll have to be paying the price every 25K miles yourself otherwise.
I am no "rocket surgeon" when it comes to ABS but are the brake pads and fluid within normal limits? I think my brake light (ABS?) came on when the pads wore to the point of creating very low brake fluid in the reservoir. Brian, welcome to the site where the mutterings of genius and madmen are posted side by side. Regards, The Mad Hatter
When did it start to run "crappy"? My 90 Loyale went belly up after I hosed off the engine. Spark plug wires or connections? Try using the old wires or verify good contact. Residual water in distributor cap or coil plug insert? Dry out inside of distributor cap... if you've got one on the Leg 91. Common things happen commonly! If you hear something clip clopping down the road, chances are that is a horse and not a zebra (exception for those USMB members from Africa).
00 Legacy GT. 60K miles. Transmission replaced under warranty at 30K as it lagged going from reverse to drive. As far as the HG no problems yet... as the fellow who fell from a skyscraper yelled at each floor going by... so far so good. I did get the stop leak added last time at the dealer to get the extended 8 yr/100K warranty on the external HG leak.
Ditto on getting them to replace your gaskets again/ resurface heads and THEN put the oatmeal in for good measure! Show no mercy, they admit they have a problem now. Did you have to pay the first time around as I think they are reimbursing those who paid themselves before they admitted the problem. Good luck.
http://www.repairfaq.org/REPAIR/F_cdfaq.html Work your way through this site. I don't know if your's is belt driven or gear driven. The rubber bands stretch and lose function and earlier cassettes and cds were notorious for just such problems. Hope this helps. PS this showed up as a simple Google "CD Repair" search.
front end 90 Loyale 4WD AT
brus brother replied to brus brother's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey Miles Are ball joints a DIY job or are there special tools required? Does the alignment need to be redone after changing? Thanks -
When rotating my bald tires last week I noticed that the right front tire has a little play in it if you grab the wheel and try rocking it by hand. I've always considered the steering mechanism (front end) to be in the realm of hobbits and uber gods. What should I be looking for? (A newer car with less than 150,000 miles?) The CV joint was replaced about 7,000 miles ago. Any suggestions or insults?
OK I wish I could blame some inferior mechanic but 'twas me who didn't tighten the lug nuts after recently taking the safety precaution of rotating my bald tires to the rear. So the death trap no longer roams the road just DAD (dumb as dirt). Thanks Noah for reminding me that common things occur most commonly.
OK My 90 Loyale AT just started making this flop flop flop sound from the left front wheel. Sounds like I have a flat but tire pressure is good. I feel it a little in the steering. Doesn't change when I step on the brake or when I engage the 4WD. Any thoughts or prayers appreciated. Be forewarned, I am on the road with this death trap so stay back a few feet if you see me.
Commuter is probably on the right track. Reread his posts and tighten the nut down! If as you said, you were able to loosen the nut by hand, it was too losse and allowing the arm to slip. The system is designed to prevent a stuck wiper from burning out the wiper motor. I had the same situation this past winter after pushing heavy snow. Tigthened the nut (as per Commuter's suggestion) and I've been happy since.
Addition to valve cover gaskets were the rubber boots (washers) around the bolts that hold the valve covers on. The first aftermarket set leaked so go SOA. They do come in the kit so you'll be getting them if you do the cover gaskets (individually, they cost as much as the whole kit, go figure). Anyway, as previous writer said, you are leaking a LOT of oil for it to be valve cover gaskets.
GT Radial is the name of the manufacturer. Apparently widely distributed in Aus and NZ, it has found its way to CT good ole USA. I don't know if their extremely competitive rates reflect a desire to gain a foothold in the market or just peddling snake oil. I did use Tire Rack in the past for the Continental ContiTouringContact and was somewhat satisfied but in spite of keeping inflation at the Sub spec of 32lbs, the outer AND inner tread wore at 20,000 miles as if I had been running it underinflated!? So I figure why spend the extra for Continental which come to about $105 installed as compared to the GT Radials at $74 installed. Returning tires for credit to TireRack is a exercise in futility. Any comments from the cheap seats?
Same symptoms. My 2000 Legacy GT auto transmission was replaced under warranty at about 37,000 mi and the ease with which the tech diagnosed the problem with a nod to the service manager gave me the impression that this was a well known problem. You might approach SOA dierctly or ask the dealer to do it for you to see if they'll cut you some slack or share the expense.
brakes
brus brother replied to truk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Hey Truk I just went through the exact same thing with RR on my 2000 GT Legacy. It was the wear indicator which happened to score the rotor as well as "indicate" wear. Seems like they could come up with a more subtle way of letting you know the pads need replacement other than scoring the rotor! BTW, they said the front rotors needed to be resurfaced after 10,000 miles even though the pads were fine. Is this normal or is it related to an issue I read hear about undersized rotors on this model. Apologies for hijacking your post. I paid the dealer $240 total for rear brakes/resurface rotor but independent quoted nearly the same price. I'll be checking back for DIY tips for the next go around. -
On my 90 Loyale there were these rubber boots or gaskets that fit around the bolts holding the valve cover in place. Leaked like hell and dripped and found their way back to the lowest point (gravity is so predictable). First aftermarket set leaked and so I switched to SOA and voila the leak was gone. If'n you got that type of bolt through design, check for leaks around the bolts.
