43
Everything posted by brus brother
diff fluid wont stay in front diff!
brus brother replied to schreckman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Seems like my tranny fluid and front diff fluids are mixing it up. Does anyone know on a 90 Loyale AT whether the tranny can be removed to repair the seal or do you have to come in the front way? -
Help: Need Pics Of Ea82 Carbed Engine!
brus brother replied to JonOfScio's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.cybrrpartspro.com/Chilton%20Manuals/8797m/8797CH04_36.HTML This is for Vacuum lines. http://www.cybrrpartspro.com/Chilton%20Manuals/8797m/8797.HTML This is the Home Page for this very valuable site. -
oil leaking on my 1.8 Gl 4WD '86 Coupe
brus brother replied to ocsike74's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Moosens checked out my 90 Loyale and with his encouragement planned to do the front engine leaks. On closer inspection, it appears that there are leaks in the area of the front diff.. The only problem I see is that the oil drips onto the exhaust and smells a lot. Adding fluids occasionally isn't that much of a bother. So perhaps the real solution is to create a system of gutters and downspouts that catch and redirect the oil drippings away from the hot exhaust. With some ingenuity, the oil could be collected and redirected into the fill tube. -
Is there any problem mixing the orange antifreeze with the old green type or should I drain the old and start fresh? Is there a preferred of these two types for the Subaru 90 Loyale?
The following site will give you the sequence for removing as well as the sequence for installing and torques for various heads. I will also post the main page url for this site as it is most informative. Head info: http://www.cybrrpartspro.com/Chilton%20Manuals/8797m/8797CH03_16.HTML Main page: http://www.cybrrpartspro.com/Chilton%20Manuals/8797m/8797.HTML Let me know if you can't get to these sites and I will long hand the information to you. G'Luck
My 90 Loyale sprang a fuel leak. The "fuel damper" rusted out. It is located right beyond the fuel pump. No dealers stocked it around here and none could say that it regulated anything other than noise. I disconnected the bugger from the fuel pump and substituted a 3/8 fuel line hose with clamps. I'm no longer leaking but does anyone know if there is any purpose that this $45 item served. The car seems to run well so far but remember the story of the fellow who fell from a skyscraper... at every floor they heard him yell out... so far so good!
OK, before I undertake the variety of oil leak fixes suggested on this site, I'd like to start out with as clear a picture of where the leaks are actually coming from and then start the project with as clean a work area as possible. What's the easiest way, other than have someone else do it, to clean and any precautions? I have a gravel driveway, close to my well and adjacent to a wetland so I'd prefer not eventually drinking the runoff. Are there any "safe" substances and techniques?
Got so excited I forgot to post the site so here it is... http://www.endwrench.com/pdf/engine/FtCamBeltReplaceW01.pdf
With the help from the compatriots at the New Gen website I was led to the following website. Unfortunately, as detailed as it is with photos and all, it is for the 2.2 and seemingly elsewhere for the 2.5. It's a very thorough how to and worth the view if you have the time.
Thanks LB from the land below you. That is the site I was thinking about but it appears my 90 Loyale has a 1.8l engine. I will search the endwrench site for anything specific to my engine. Occasionally, local dealers run a $275 US timing belt special and I am tempted although the incidental cam/oil seals etc. could make the price worth the greasy nails. I will try and not test your memory past the 48 hr. warranty. Yep, this site is a wealth of helpful enthusiasts. Many thanks again.
Thanks ECB. That site is a dandy yet there was another one with actual photos that another contributor to the New Gen or Older Sub sites had posted. Anyone else have a clue?
Does anyone have experience with any of these additives to stop leaks where it involves the seal between engine and auto trans? I seem to be going through diff oil on a fairly regular basis. The bottom of my car looks and smells like the oil fields of Iraq (not on fire though) and I'm sure I am also seeping from the valve cover bolt seals and probably the oil pump etc.. Is there a predictable additive fix for these varieities of leaks? It's a 90 Loyale AT with east coast rust galore at 144K miles. I hate to throw too much in the way of mechanical fixes at it... how about the new 2004 model hmmmmmm...
Where is that excellent website detailing with pictures the changing of timing belts? The link was posted here before... or was it on the New Generation site?
Not sure where the AC was installed. I guess it might not have been factory but I'm not sure since I got the car from the third owner. So far, the car is running pretty well with three new NKGs and wires. What's so great about running on four cylinders anyway? Thanks for the sympathy.
Can't even seem to get the spark plug socket into the space no less any wobbly or extension
The AC is closer to the battery. What then??
I've never changed the spark plugs on Loyale 90 with AC before. It appears that the front plug is buried under the AC compressor. What do I need to move, remove, destroy in order to get at that plug. Does the AC compressor simply rotate up out of the way?
The manual calls for 75/90 gear oil for 90 Loyale. There is only synthetic available at my local stores in that weight. I have some 80/90 gear oil and have contemplated using it. Is there that much difference? I like the through the wheel well, over the shoulder, around the tree approach to the rear diff but I think the $5 pump or even the squeeze bottle the oil comes in with a feeder hose may just do the trick. I will try and post again after I wash the oil out of my eyes.
