brus brother
    43
Everything posted by brus brother
  1. http://www.cybrrpartspro.com/Chilton%20Manuals/8797m/8797CH04_36.HTML This is for Vacuum lines. http://www.cybrrpartspro.com/Chilton%20Manuals/8797m/8797.HTML This is the Home Page for this very valuable site.
  2. Moosens checked out my 90 Loyale and with his encouragement planned to do the front engine leaks. On closer inspection, it appears that there are leaks in the area of the front diff.. The only problem I see is that the oil drips onto the exhaust and smells a lot. Adding fluids occasionally isn't that much of a bother. So perhaps the real solution is to create a system of gutters and downspouts that catch and redirect the oil drippings away from the hot exhaust. With some ingenuity, the oil could be collected and redirected into the fill tube.
  3. Is there any problem mixing the orange antifreeze with the old green type or should I drain the old and start fresh? Is there a preferred of these two types for the Subaru 90 Loyale?
  4. The following site will give you the sequence for removing as well as the sequence for installing and torques for various heads. I will also post the main page url for this site as it is most informative. Head info: http://www.cybrrpartspro.com/Chilton%20Manuals/8797m/8797CH03_16.HTML Main page: http://www.cybrrpartspro.com/Chilton%20Manuals/8797m/8797.HTML Let me know if you can't get to these sites and I will long hand the information to you. G'Luck
  5. ... hit it with something hard... oh yeah, you already did that. Glad to hear you passed the crash test.
  6. My 90 Loyale sprang a fuel leak. The "fuel damper" rusted out. It is located right beyond the fuel pump. No dealers stocked it around here and none could say that it regulated anything other than noise. I disconnected the bugger from the fuel pump and substituted a 3/8 fuel line hose with clamps. I'm no longer leaking but does anyone know if there is any purpose that this $45 item served. The car seems to run well so far but remember the story of the fellow who fell from a skyscraper... at every floor they heard him yell out... so far so good!
  7. OK, before I undertake the variety of oil leak fixes suggested on this site, I'd like to start out with as clear a picture of where the leaks are actually coming from and then start the project with as clean a work area as possible. What's the easiest way, other than have someone else do it, to clean and any precautions? I have a gravel driveway, close to my well and adjacent to a wetland so I'd prefer not eventually drinking the runoff. Are there any "safe" substances and techniques?
  8. Got so excited I forgot to post the site so here it is... http://www.endwrench.com/pdf/engine/FtCamBeltReplaceW01.pdf
  9. With the help from the compatriots at the New Gen website I was led to the following website. Unfortunately, as detailed as it is with photos and all, it is for the 2.2 and seemingly elsewhere for the 2.5. It's a very thorough how to and worth the view if you have the time.
  10. Thanks LB from the land below you. That is the site I was thinking about but it appears my 90 Loyale has a 1.8l engine. I will search the endwrench site for anything specific to my engine. Occasionally, local dealers run a $275 US timing belt special and I am tempted although the incidental cam/oil seals etc. could make the price worth the greasy nails. I will try and not test your memory past the 48 hr. warranty. Yep, this site is a wealth of helpful enthusiasts. Many thanks again.
  11. Does anyone recall the excellent website with actual photos posted by one of the visitors to the New Gen or Older Sub website?? I'm chocking on oil burning oil smells and may have to dive in!
  12. Thanks ECB. That site is a dandy yet there was another one with actual photos that another contributor to the New Gen or Older Sub sites had posted. Anyone else have a clue?
  13. Does anyone have experience with any of these additives to stop leaks where it involves the seal between engine and auto trans? I seem to be going through diff oil on a fairly regular basis. The bottom of my car looks and smells like the oil fields of Iraq (not on fire though) and I'm sure I am also seeping from the valve cover bolt seals and probably the oil pump etc.. Is there a predictable additive fix for these varieities of leaks? It's a 90 Loyale AT with east coast rust galore at 144K miles. I hate to throw too much in the way of mechanical fixes at it... how about the new 2004 model hmmmmmm...
  14. Where is that excellent website detailing with pictures the changing of timing belts? The link was posted here before... or was it on the New Generation site?
  15. Not sure where the AC was installed. I guess it might not have been factory but I'm not sure since I got the car from the third owner. So far, the car is running pretty well with three new NKGs and wires. What's so great about running on four cylinders anyway? Thanks for the sympathy.
  16. Can't even seem to get the spark plug socket into the space no less any wobbly or extension
  17. The AC is closer to the battery. What then??
  18. Apparently there are also seals for the bolts that hold the valve cover on and it appears mine are leaking there (noticed after I changed the valve cover gaskets).
  19. I've never changed the spark plugs on this 90 Loyale with AC. Do I need to disassemble the entire front part of the car to access the front plug that appears buried under the AC compressor? Can the compressor be rotated out of the way or what??
  20. I've never changed the spark plugs on Loyale 90 with AC before. It appears that the front plug is buried under the AC compressor. What do I need to move, remove, destroy in order to get at that plug. Does the AC compressor simply rotate up out of the way?
  21. The question remains, is it necessary to use gray Permatex on the plugs as one suggested.
  22. Hey Kevinsubaru, I like the simplicity of your method. Did you use the Permatex sealant on the plugs?
  23. The manual calls for 75/90 gear oil for 90 Loyale. There is only synthetic available at my local stores in that weight. I have some 80/90 gear oil and have contemplated using it. Is there that much difference? I like the through the wheel well, over the shoulder, around the tree approach to the rear diff but I think the $5 pump or even the squeeze bottle the oil comes in with a feeder hose may just do the trick. I will try and post again after I wash the oil out of my eyes.
  24. Properly educated with your helpful tips in hand, I will now go watch TV.
  25. Is there any homespun way of opening the drain and fill plug on rear diff on a 90 Loyale or do I have to get a special tool? It is an internal square on the plug.
