44
Everything posted by brus brother
what gb said below is what I found on the passenger side of my 05 OB I was able to pull a piece of wire through and use crimp butt connectors to make the connections outside the zone of flexion, tucking them within the gate pillar or back in the ceiling. you may find other wires that are frayed and in need of attention
I have 05 and 08 Outbacks 2.4 SOHC. I recall that OEM filters have a mechanism from preventing oil from draining back and causing a dry start and bypass pressure compatibility. Is there an aftermarket filter that is suitable or just get Subaru branded? Is there a sticky for mundane questions like this and other inquiries for TB kits/suspension parts, etc.?
Just replaced the rear sway bar links on my 05 Outback and there is still a little play (rattle) in the sway bar bushings. Looking at the brackets that hold the bushings, are the nuts welded onto the frame or is it an independent nut and bolt? I am soaking everything in sight with PB Blaster but if there is a chance of snapping that bolt off inside a fixed nut, I may just turn up the radio and forget about the noise.
Subaru Idle Relearn Procedure: 1) Turn off the lights, aircon, stereo or any system in the car that draws extra current on top of the engine. 2) Disconnect the battery for 30 mins. 3) Reconnect the battery. 4) Before you start the car for the first time, turn the key to the ON position but do NOT turn the engine over. Wait 10-15 seconds so the electronic throttle body or IACV has time to go to the factory programmed home position. 5) After waiting, start the car and let it idle without any load, lights, A/C etc. 6) Every 20 seconds or so the idle will be adjusted up and down as the ECU tries to adjust it towards a stoichiometric fuel / air mix. 7) Leave the engine running for a full 10 mins but DO NOT TOUCH THE ACCELERATOR during this time or turn on anything that will cause extra electrical current draw. 8) Turn off the engine, and leave the key in the OFF position for at least 20 sec. 9) As per step (4) turn the key back to the ON position for 10-15 sec without actually starting the engine. 10) Start the engine and leave to idle for a further 5 minutes without touching the accelerator and without turning on other systems in the car. 11) Turn off the engine again and wait at least 20 sec before restarting. 12) Take the car for a test drive as the ECU should now be fully retrained.
It may be something as simple as tune-up but if that has been addressed, then consider the following. Have you recently disconnected the battery or "cleared" any codes? In doing so, the car's ecu then needs to relearn the car. Start the car by just turning the key and let it idle without touching the gas for about 10 minutes. That first turn of the key may take a few revolutions until it starts but DO NOT step on the gas If I don't follow this step, I end up with a car that tends to stall out, even after many miles of driving.
From cold start, car ran like crap. Pulled P0303 and P0304 fault codes. After about ten minutes, car smoothed out and ran normally. Don't want to diagnose by wallet but is the likely culprit a failing ignition coil? Any other possibilities that would fail both cylinders and then recover? Humidity has been off the charts here in New England and the car sat for a few days without being driven prior to episode.
If all tests ok with the battery/cabling, as Lucky T mentioned, possibly an issue with the starter. When you say the "start" position, you don't just mean on, but rather the cranking/starting position? While someone turns the key to the start position, use a long piece of wood to tap on the starter. It may be hung up on a "dead" spot. If this works, replace the starter (rebuilt Subaru only is the recommendation on the board)
Lucky T, When I put the gauge on the system (Parts store gauge and can Arctic Freeze) it showed full. As I thought I was going to have to jump the relay to get the clutch to engage, and suck in the gas, as I just wiggled that big honkin relay in the fuse box, the clutch started spinning. The mystery of why there would be ice cold air then nothing seems to be explained by the failing relay?? Do relays fail like that where they work for a few minutes then cut out, as if heat expansion affecting performance.
ok may have figured out the mystery. If I wiggle the relay the clutch spins in and I get ice cold air. Possibly the relay is the problem? Is the symptom of a dying relay that they fail after a short period of time working? Can failure be intermittent like this where they fail after working for a few minutes and then start again after rest??
I am guessing that I am now reqally low as the clutch won't engage now. Problem is how to refill without ac running. Bypass the relay? OK never pulled a relay out before. I have identified the relay. Is it just a straight pull out or is there a retention clip that needs to be pushed back? Then, what terminals do I cross to bypass the relay?
