brus brother
    46
Everything posted by brus brother
  1. My 05 OB has a sound similar to what you are describing in location but not related to turn signal. Mine is from the HVAC actuator for the blower door. Try different selections on the HVAC when the noise occurs and you may notice a difference. Mine comes and goes as well.
  2. to be clear... you are referring to a two bottle oxy-propane system? not just the propane bottle from hardware aisle?
  3. Gravity is inescapable. Going up a hill, loss of power might be a clogged cat converter? Pieces of medium shifting to restrict flow.
  4. The clicking just may be unrelated to the window failure. Can you change the sound of the clicking by selecting different modes from the hvac system. My 05 OB has an intermittent clicking which I am told is the selector failing to actuate the blower door.
  5. Just checked my numbers butane 1760 deg F mapp 2900 deg F atsa big difference I was very comfortable with the small size and ready availability of the micro torch.
  6. the car came with a "wrench" to allow you to close the roof if the power sin't working but I'm not sure that would help in your circumstance. http://www.subarumanuals.org/subaru-2533.html in an emergency (heading towards a hurricane) I might suggest that you retract it then gently manually coax it along as you try to close it with the motor.
  7. I've always envied people with acetylene torches who can heat and remove rusted fasteners with ease. Changing out rear sway bar bushings, with somewhat limited access to the top bolt that wouldn't budge with PB Blaster and arm power. Today I tried my Harbor Freight Butane Micro torch. Costs about $13 when on sale and waddayaknow... 2000 1760 degrees (?) of butane heat alternating with PB Blaster and it did the trick. May not be enough heat to conquer ball joint rust issues here in the northeast but It gives a real fine tip of concentrated heat to the flame and I will keep it in mind when working in close quarters near rubber bushings etc.
  8. It is a pain to get those wires through the rubber. Attach a piece of dental floss (I am a retired dentist ) to one broken end of the shortest piece and pull the broken wire back out of the gaiter. Make the splice connection and then reattach and use the floss to pull the spliced wire back through and connect to the other side.
  9. what gb said below is what I found on the passenger side of my 05 OB I was able to pull a piece of wire through and use crimp butt connectors to make the connections outside the zone of flexion, tucking them within the gate pillar or back in the ceiling. you may find other wires that are frayed and in need of attention
  10. Realized after changing oil that I neglected the filter. It is overdue. Can I just change the filter or will I be showered with oil if I don't drain the sump first?
  11. I have 05 and 08 Outbacks 2.4 SOHC. I recall that OEM filters have a mechanism from preventing oil from draining back and causing a dry start and bypass pressure compatibility. Is there an aftermarket filter that is suitable or just get Subaru branded? Is there a sticky for mundane questions like this and other inquiries for TB kits/suspension parts, etc.?
  12. I can't answer your question directly but my 05 AC clutch wouldn't engage sporadically. Turns out the relay was crapping out. Simple fix. Find the relay in the box and tap on it. If there is another same size relay in the box, swap them out and see if that resolves the issue.
  13. Just replaced the rear sway bar links on my 05 Outback and there is still a little play (rattle) in the sway bar bushings. Looking at the brackets that hold the bushings, are the nuts welded onto the frame or is it an independent nut and bolt? I am soaking everything in sight with PB Blaster but if there is a chance of snapping that bolt off inside a fixed nut, I may just turn up the radio and forget about the noise.
  14. you are working blind get a cheap code scanner you can get a scanner like this on ebay LINK for about $10 this should tell you enough to help you decide you'd kick yourself if it was something simple and you junked the car
  15. makes sense. you did disconnect the battery to install the lights? that would require the ecu to relearn.
  16. tap right above the "3" button on my 05 Outback There is a poor ground connection right at that location. Hasn't happened in a while but that resulted in the entire HVAC unit /radio going blank.
  17. Subaru Idle Relearn Procedure: 1) Turn off the lights, aircon, stereo or any system in the car that draws extra current on top of the engine. 2) Disconnect the battery for 30 mins. 3) Reconnect the battery. 4) Before you start the car for the first time, turn the key to the ON position but do NOT turn the engine over. Wait 10-15 seconds so the electronic throttle body or IACV has time to go to the factory programmed home position. 5) After waiting, start the car and let it idle without any load, lights, A/C etc. 6) Every 20 seconds or so the idle will be adjusted up and down as the ECU tries to adjust it towards a stoichiometric fuel / air mix. 7) Leave the engine running for a full 10 mins but DO NOT TOUCH THE ACCELERATOR during this time or turn on anything that will cause extra electrical current draw. 8) Turn off the engine, and leave the key in the OFF position for at least 20 sec. 9) As per step (4) turn the key back to the ON position for 10-15 sec without actually starting the engine. 10) Start the engine and leave to idle for a further 5 minutes without touching the accelerator and without turning on other systems in the car. 11) Turn off the engine again and wait at least 20 sec before restarting. 12) Take the car for a test drive as the ECU should now be fully retrained.
  18. It may be something as simple as tune-up but if that has been addressed, then consider the following. Have you recently disconnected the battery or "cleared" any codes? In doing so, the car's ecu then needs to relearn the car. Start the car by just turning the key and let it idle without touching the gas for about 10 minutes. That first turn of the key may take a few revolutions until it starts but DO NOT step on the gas If I don't follow this step, I end up with a car that tends to stall out, even after many miles of driving.
  19. while someone turns the key, whack the starter with a length of 2x4 or pipe youtube link
  20. From cold start, car ran like crap. Pulled P0303 and P0304 fault codes. After about ten minutes, car smoothed out and ran normally. Don't want to diagnose by wallet but is the likely culprit a failing ignition coil? Any other possibilities that would fail both cylinders and then recover? Humidity has been off the charts here in New England and the car sat for a few days without being driven prior to episode.
  21. If all tests ok with the battery/cabling, as Lucky T mentioned, possibly an issue with the starter. When you say the "start" position, you don't just mean on, but rather the cranking/starting position? While someone turns the key to the start position, use a long piece of wood to tap on the starter. It may be hung up on a "dead" spot. If this works, replace the starter (rebuilt Subaru only is the recommendation on the board)
