43
Everything posted by brus brother
Won't say I told you so because I didn't since smarter members than I (Nipper and Jonathan) were already chiming in. As a long time lurker here I have seen many gremlins turn out to be the result of a failing alternator. Similarly, I have read that aftermarkets are a headache waiting to recur. Better a rebuilt from Subaru which aren't that much more expensive than aftermarket ones. Maybe even rebuild your own instead of trading it in for a sketchy aftermarket?
your post was deleted...
"get a bicycle"
very funny
Yup comes a time to take it to the pros. Trust me I know.
I retired YESTERDAY from 40 years in dentistry.
If it is the only element running through the boot, you could possibly pull the old one out and find a pinch or pinhole leak? Tip: hook/tape a string to the old one when you pull the hose so you can more easily replace it. I would check Home Depot or similar parts store in the area where they sell hoses for refrigerator ice machines. They might have ones long enough already bagged or sold by the foot. If the hose itself goes into the reservoir, pull the hose out of the reservoir and cut a 1/4 inch piece to check the size. You probably won't want to add a splice to the existing line because of its overall age and apparent lack of access. If you don't intend on keeping the car long, use the squeegee at the gas station and call it a day. ;-)
http://www.scoobyenthusiast.com/subaru-components/where-are-windshield-washer-pumps-located-subaru/ Pump and reservoir locations show pre 1995 with separate rear config. Does your front reservoir have two little pump motors associated with it or one? Might check a Subaru dealership parts department and see if your vin# shows separate reservoir. In the past my local dealership provided me a schematic for projects which may help you trace the hose routing and any connection points.
Sounds about right. Start with the simplest. 1. Tires (same size and make), check tire pressure, check tire balance, check wear patterns. 2. Alignment (In my case this was critical) An alignment shop should be able to assess if any of the suspension is way off. I would expect that with your car's vintage/mileage there is going to be some normal wear in suspension, so don't be alarmed into replacing too many elements at first. Are there any audible noises when going over bumps?
as John suggested, might be some baffle/cat honeycomb has broken loose and occludes the exhaust when going uphill. If you live somewhere remote, you could disconnect the exhaust and see if that cures the issue. It will be pretty loud! A friend had such a condition but it was more immediate. Complete loss of power. Cracked the exhaust after the manifold and he was able to chug a lug home to make repairs. I think he eventually just removed the cat and vacuumed out the dislodged honeycomb.
+1 local This is not a blanket statement but I have sat in dealerships and listened to hard selling of services to "the little lady". "I see you have children with you... you wouldn't want your blinker to suddenly stop working." A good local mechanic will likely be busy enough not to need to sell his services. Be reminded to keep itemized receipts in the event any Subaru warranty issues arise.
