43
Everything posted by brus brother
there are a couple of youtube generic videos on releasing broken/stuck latches. I don't have your model (and I have the flu) so I can't evaluate how easy it is to access the latch as in this https://www.youtube.com/watch?v=xMrjwUfdiiE Edit: Whenever I've run into situations where I keep hammering, pressing, pulling, pushing etc. in one direction without success, I turn my efforts 180 degrees and see if that works.
That is a big unknown here in the NE rust belt. Be prepared to have to drill that sucker out.
- 16 replies
- differential
- leak
(and 1 more)
Tagged with:
they probably just diagnosed with the obd code. I have had p0420 on my 05 OB for the past 100K miles. No loss of power or gas mileage. I'll need HGs at the next TB interval. and maybe then install an aftermarket cat. Can't see throwing new original Subaru cat at the car with 210K miles I just clear the code and reset systems to pass inspections every two years. A clogged cat will reduce/eliminate power so if the medium is catastrophically degraded and blocking the exhaust it may reduce power. Once saw a car that plain wouldn't accelerate. Disconnected cat and it ran REAL loud but at least it got home.
- 23 replies
- oil leak
- piston slap
(and 2 more)
Tagged with:
cornering sound might lend towards bearing. more when turning to one direction than another? when you are travelling straight if you turn the wheel side to side does the sound change? always indicate year and model in postings as there is oftentimes known model specific issues (i.e. Forrester right rear wheel bearings)
Call up your local Subaru dealership and ask them to match the online price mentioned by idosubaru. MOST dealerships now have online divisions in their parts departments. They all get their inventory from SOA. At the very least, they might allow you to return the old one for the core charge since they all get sent back to Subaru of America.
The variable might just be Tony Soprano's hot temper Go sit in a few subies at your local dealer and check the temperature readings. If they are more in line with your app (or even each other +/-) and markedly different as compared to yours then there is something amiss with your sensor. That would be the scientificological approach as I understand it from reading Roller Derby Monthly magazine...
yup there is talk of damage to the cable or rust at the interface with the hub
- 9 replies
- cv axle replacement
- brakes pulsing
(and 3 more)
Tagged with:
