brus brother
    46
Everything posted by brus brother
  1. Can you provide a picture of the connector? Get yourself a mirror and a flashlight and you should be able to see where the mate is for that connector. It's impossible to see under there otherwise. I "disabled" my motorized seat one time after some overzealous cleaning. Another possibility would be a passenger in the rear seat sticking their feet under the driver's seat and disconnecting the cable. Once you visualize where it goes the trick will be to reattach it essentially by feel. There may also be a connector to the side airbag so BE VERY CAREFUL while monkeying around in there or better yet disconnect the battery first.
  2. Well sounds like you'll be going back in the water... If you can identify the color of the wire for the reverse lights, remove the gaiter at both ends and tug on that color wire from either end of the boot. Since you said you cut and taped the boot, you might open that up as well to make sure the wire is intact and not frayed as you tug on it. If the wire is intact, trace the wire from the bulb back to the easiest point of access of a connector before and after the bundle and check for continuity along the way. Could be one of your connections failed (mine did the first time) or it is one of the wires you didn't repair (yet). Electricity is a linear event.
  3. Agreed on availability of piece for replacement if it needs to be replaced. I am not getting any failure reports of sealing though have been warned that aftermarkets can have issues. My situation is that a tether that doesn't relate to function other than forgetfulness of the operator failed first on the 08 and then later on the 05. Making the cap idiot proof as far as leaving it at a gas station is the only function of the tether. The adjacent plastic did not seem fatigued as I was able to jam it into the weed whacker gas line splint. 86 Trans am is an admirable save. I have a buddy nursing three 1968 Subaru 360 sedans and one truck. He actually found rings for the engine through SOA for peanuts. So I will take my bow as MacGyver in training and report back in the future if/when it fails. Believe me, as a practicing dentist, I know full well of the potential or should I say inevitability for failure of parts made by God no less parts made by man!
  4. Darn. I knew I should have titled this post "Broken Gas Cap Tether... Just Buy a New One" Perhaps there should be an entire section in the FAQ Sticky Compilation for "Broken item, buy a new one" Problems Solved!
  5. @GD, I admire your tenacity. However, the thought of squirreling away one (or two) spare parts for every possible scenario, for the day they may become useful, is beyond the storage capacity of my attic, basement and garage. I will continue to cobble together solutions and remedies when possible but at some point realize that there does come a time to say "when".
  6. The gas cap tether on both my 05 and 08 outback broke. getting forgetful and not wanting to leave it at a gas station or on the roof of the car... I searched around on the web and found someone making a replacement for about $10. Subaru only sells the cap which comes with the tether for about $26. I saw a youtube video where they lapped the broken ends, glued them and used small zip ties. I have a simpler solution and time will tell if it is durable. I didn't use any adhesive but just jammed the broken ends into a small piece of chain saw gas line. I don't know the exact id of the line but it was a real tight fit and seems to be holding. If it fails I might consider some silicone or other adhesive like M-1. sorry picture attached out of focus.
  7. http://www.subaruoutback.org/forums/attachments/problems-maintenance/14955d1255045860-remove-rear-cargo-area-moulding-231372-rear-quarter-trim-60.pdf check out diagram where it says wagon model also some other tips, tools and tricks within these posts: http://www.subaruoutback.org/forums/80-electrical-electronics/19618-third-brake-light-license-lights-out-most-time.html http://www.subaruoutback.org/forums/66-problems-maintenance/20824-remove-rear-cargo-area-moulding.html
  8. l r interchange 05-09 same front axle refurb from dealer is $165 used on car-part.com in the $95 range in the CT area
  9. dang, not seeing those deals on ebay... 2005 subaru outback automatic limited driver side... what am I missing??
  10. heard plenty of horror stories about autozone and advanced auto axles... car-parts.com around here get around $75 for grade A in my MY. will call dealer tomorrow and see what their remans are...
  11. I have a bad back so when I discovered there was a small tear in the driver side outer boot accompanied by clicking, I had the outer boot replaced/regreased. It is original to the car at 178K miles. Perhaps it is the inner joint??
  12. My left front cv on my 05 OB is getting worse by the week. It occurs on hard left turns more so on an incline. I can't tell if it is outer or inner. Not yet clicking on straight ahead. At what point and what can be expected with catastrophic failure, Any suggestions for replacements that won't cause more headaches than what's already in there?
  13. As gbhrps mentioned (and you have already experienced) the likely culprit is that flex point within that bundle of wires. In an earlier post, a member suggested inserting a length of new wire so that the solder joint is no longer in the flex area but before and after. I share your pain as I also have an 05 with recurring issues with that bundle of wires.
  14. Exactly. It was a Lada and it was this fellow's daily driver. Very proud owner originally from the old country. Located in Westport , CT guy said he takes regular long haul trips to Boston etc. with nary a concern. Every joint and weld had oil on it and it seemed to be holding up pretty well.
  15. I was recently at a small car show and someone had an ancient Russian made car. Every seem and joint was coated in oil. The owner claims this is the only way they can keep rust at bay. I have heard of farmers using this on their plows and machinery. Not sure if it works but it sure is cheap!
  16. what is odd is that the first picture you attached of your new wiper doesn't appear to have the spline within the head as compared to the second picture posted?
  17. well you already bought the new one but if it were me (as cheap as I am) I would have just epoxyed the old wiper back on the splined piece. as others have said, a small gear puller which can be borrowed from autozone or other auto stores that lend out tools will get that splined piece off, and you can use your brandy new wiper arm
  18. Check out your local Autozone or similar parts stores. My local one loans (just leave a deposit) various tools. They may have a small gear puller that would work for your purpose.
  19. here's a link to a previous posting concerning broken wires in the boot on the passenger side of the rear gate with a picture of my broken wires. Once you pull the boot back tug on each of the 10 or so wires in the bundle and one may just easily evidence itself. i tried simple solder splicing once and it failed. Use a crimp last time and when that fails I will splice in a wire so that the repair is not right at the flex point.
  20. Not sure if those Imprezza model and years are the same body types but why not just search one of the online retailers and see if the part numbers match up??
  21. As GD said, don't fall in love with this car. Seller can clear the codes so the light doesn't come on again for a few miles and by then you've bought someone else's issue.
