46
Everything posted by brus brother
Make sure your battery connections are solid. if you are sure that the battery is good and there is a good connection to the starter, try tapping the starter as someone turns the key. Don't need to stick your hands down there, just bet a long piece of wood and tap it with a hammer from above. Starter may be on the way out and it gets stuck on a dead spot? I traveled with a length of wood and hammer for a few weeks before replacing my 05 starter. I think you might be able to rebuild the starter solenoid on yours. Mine was a one piece unit that had to be replaced.
Well, GD does this for a living and you do it out of necessity or intellectual curiosity (I do understand the challenge). So, I am sure that GD would not want you hanging around the shop as he is trying to earn a living wage to feed his family. Can you imagine what a customer would say if you tried to bill them for the hours you have invested in this project? So, you are welcome to all of the free professional (GD) advice and others like myself with limited experience here on the site. Only here to help.
need to climb in the back, pop off the retaining pins that hold the interior and then peek in. On my 05 there is a white lever on the driver's side of the panel but don't know about the 99. You are in for some contortions but there are a bunch of youtube videos that should help you visualize. just type "stuck rear hatch subaru" in the search bar on youtube, maybe someone else on board with that vintage can fill in some details.
+ on finding a good independent Subaru mechanic. Perhaps starting another thread and asking for one in your area will get you a lead. I might not even rely on Midas' report of a leaking "seal". I recall that the interval for 05 is 105K miles OR 8 years Time wise you seem to be way over. Age can be a byitch! + on getting the idlers, gears and tensioners done An experienced subaru mechanic could evaluate the idlers etc. for wear and need of replacement but as I mentioned, time wise, you seem to be over the mark. ALSO, shortly after my 05 timing belt replacement at 105, the car developed an external headgasket leak. Started as weeping around the gaskets but is now crying a river! I just keep an eye on the oil level and hopefully will make it to the next interval. Currently at 180K miles. So if your's has begun weeping and you plan on owning for a while, have them look at the HGs and decide. A few more dollars invested now while they have the engine apart will save the headache later on.
Dadgummit! Today, unable to unlock rear hatch. no actuator sound. so I climbed in and there is an access panel dead center right at the bottom of the interior panel that pops right out. Little white lever on driver's side operates the lock. Pulled the boot on the passenger side and sure enough one of my previous repaired joints (solder and shrink) failed. Failed at the splice of the new wire added! I am asking myself for a full refund. Shoddy workmanship!
The broken wires in the 05 and other OBs appear to be a common problem. Before you peel back the headliner, slide up the rubber boots on either side of the hatch and separate the bundled wires. My broken wire(s) were pretty obvious. BTW in my case the breaks were within the boot on the passenger side (of course I checked the drivers side first). Since there isn't much spare wire, I ended up splicing in/heat shrinking a piece of wire.
There are 2 different issues. First, whenever there is a CEL, the cruise control light will also blink and cruise will become inactivated. Clearing the code will turn off the CEL and cruise will perform as normal until or if it throws another code. I have gotten use to my blinking CEL due to persistent P0420 Your second issue is a puzzle to me. As others have asked, is there an aftermarket alarm system, remote starter or radio cut and splice. Remove brake light bulbs and see if symptoms persist. Is there any corrosion in the bulb sockets?
did you have to remove the interior panel to lube the assembly or can the handle be lubricated from the exterior at the hinge points? Also for the op, there may be a broken wire within the rubber channels at the upper corners of the hatch. i will dig out one of my previous posts on my 05 with pics. Does the door lock via the switch? http://www.ultimatesubaru.org/forum/topic/163213-broken-wire-to-rear-hatch/
