Everything posted by brus brother
Where does this go? *see pic*
brus brother replied to jonnygorman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyup that is probably just a link to the picture on his computer. If jonny clicks on it, it just might work, linking to his own file on his own computer. My guess is he needs to upload the file to USMB
clank in rt rear
from dead stop occasionally I get a clank from the right rear when accelerating. where to look first... yeah I know, the right rear ;-) 2005 OB 165K miles
Discount Subaru Parts
brus brother replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsubarupartsforyou.com part is 14.78 and shipping to Charleston sc 10.52 total $25.30
brus brother replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry subarupartsforyou.com they are local to me here in CT at Dan Perkins Subaru. I can walk right in and order parts at the shop/internet price. Ask for John or Anthony and mention USMB.
squeaky rear shock 05 OB
checked again. silicone sprayed all bushings and it still appears to be coming from the top of the rear shock. Is there any easy way to access that mounting area for silicone spraying to at least verify the source. Are there any bushings internal to the shock that could squeak? never did shocks before.
as the title says... is it possible that "internal" bushings are squeaking. I don't have a lift but sprayed the siht out of the area with silicone but no relief. Can I access the top of the shock from inside the Outback? Any suggestions as the squeak is driving my wife (and follows to me) crazy!
Need some input on a difficult decision
brus brother replied to vikingDBA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 05 started an external hg oil leak around 105k miles. I am currently at 170K miles. I have free oil changes for life with dealer and they always report that the leak has gotten worse (oil leak). OK so I keep a paper bag weighted down with rocks in the garage to catch the oil drips and have never run low on oil between my free oil changes. Am thinking about renting the car out to seal driveways. People around here just love that stink of fresh oil soaking into their crumbly asphalt driveways. Anyways, a local subie shade tree mechanic here in CT quoted ~$400 labor to replace hgs. He also knows my car and all of its other deficiencies (wheel bearings. P0420 - and after all testing and praying, points to cat being shot, climate control motor going out) His recommendation... just drive it! It is my station car and I'm not headed to the outback in my Outback. If it is still kicking around 210K for the next tb scheduled replacement, I'll probably do the hgs at that point. As in your case, my car still runs well enough so tough call but if you haven't done the tb service, hunt around some more. It may be worth your while from Harrisonbuirg, Pa to take a road trip and park in GrossGary's driveway and block him in until he agrees to work on your car!
Climate Control Issue!
brus brother replied to ethmail11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust checking but did you pull the fuses and test or just visual inspection... I have been fooled in the past.
Got Po420 code want to replace downstream 02, DEnso or OEM ?
brus brother replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou'll need to drill these out but: antifouler from autozone orf wm http://www.walmart.com/ip/Dorman-42009-Spark-Plug-Non-Fouler-18mm-Gasket-Seat-Pack-of-2/191881703?wmlspartner=wlpa&selectedSellerId=371&adid=22222222227040538595&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=99532280554&wl4=pla-234123911074&wl5=9003369&wl6=&wl7=&wl8=&wl9=pla&wl10=111839980&wl11=online&wl12=191881703&wl13=&veh=sem search google and there are some sellers that drill them out for you for a little more $ That being said: This DID NOT WORK on my 05 OB. Something about the way the computer reads info on 05+ models. Just our luck huh?! I bought a cheap code reader for about $20 and for the past 5 years, I clear the code so as to pass inspections and away I go. Never found a leak, never found a cause. Never found that it affects performance other than disabling cruise control and the light show of blinkers in the dash cluster.
'05 Outback -- Water accumulating in passenger footwell
brus brother replied to freekraz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOf course FT is correct! I just came home with my 05 OB with A/C blaring. The tube indeed sticks out of the lower firewall just lateral to the forward cat on the passenger side. If nothing or little is draining try snaking as above with coat hanger or a few gentle blasts of compressed air might be needed. Instead of coat hanger maybe try a long zip tie. More flexible around corners. I used the coat hanger on my old Loyale and I think it may have been a little less of a torturous route on that oldie.
brus brother replied to freekraz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso first remove the floor mats and let them dry in the sun for a couple of days. spray them with lysol once dry to help control mold. now look to see if condensation is draining from the a/c-defroster when you run the car. it should drain in the same area (right rear well) straight to the ground. if not the hose may be blocked. If you can find the hose, gently snake a coat hanger up and see if it clears any blockage. The blockage is usually just an aggregated biofilm that is actually fairly soft and won't require much coaching to clear. Correction because I am an idiot... "rear wheel well" I must have been asleep when I wrote that!
2006 Legacy GT Oily smell and smoke
brus brother replied to mikeshilk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you check to see if one of your cv boots is torn? That grease has a particularly nasty smell when it is flung onto the engine/exhaust.
New CV Joint Boot Clamp Tightening
brus brother replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAgreed, Would brake cleaning spray be a good solvent to clean in place?
brus brother replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXin video above guy reused the existing clamps. they are already bent at exact mark.
brus brother replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis guy does the boot (inner) without removing the axle... least is best?
2006 Subaru Forester car audio
brus brother replied to Ward's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtry a different sd card?
remanufactured power steering pumps - successful?
brus brother replied to nnealley's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.subaruoutback.org/forums/66-problems-maintenance/108746-leaking-power-steering-pump.html see post #8 for recap o ring at top of pump
brus brother replied to nnealley's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ultimatesubaru.org/forum/topic/151953-05-ob-power-steering-fluid-leak/ My 05 was leaking and this single o ring mentioned in the above link solved my problem.
Have CEL on with flashing cruise light on a 2005 Legacy ?
brus brother replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+ on the wife / gas cap loose. in fact, when I opened the filler door, the cap fell out!
06 Legacy post Accident; Worth repairing?
yup, don't brake which will just lower the nose and give the furry friend a glide path up the hood into the windshield and then you are lap dancing with a deer. glad your friend passed the crash test.
brus brother replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a 2005 OB and since 105,000 miles (currently at 165,000) I started with the P0420 cat efficiency below threshold. Replaced the front and rear O2 sensors on the passenger side with no positive outcome. There are a total of three cats and five sensors on my 05. Brilliant! I bought a cheapo code reader/eraser for $19 on ebay and clear the codes and allow the systems to reset every two years for CT inspections. I think I've done that dance four times so far. I have become accustomed to the flashing lights. Initially, I used black electrical tape to hide them for a while but took it off for inspection and never replaced the tape.. The cruise is deactivated with a CEL but I don't use cruise so not a loss for me. I priced Eastern catalytic for a replacement at around $125 but probably only good for a year or two. Will change it out when I am ready to sell.
Ball joint removal hell
My head just burst into flames thinking about all of the what ifs...
08 Outback here in good old salty Connecticut. Thought ball joint replacement would be a snap but looks like the snap part may end up being the pinch bolt that holds he joint in place! Soaked it in PB Blaster for a few days but I can't budge it with a 6 point socket. I am afraid that I will soon be in "drill her out hell" once I snap the bolt. It seems as though the design with the open space that is pinched together allows road salt and cryptonite like rust to occur from the middle of the bolt outward as well as from each end inward. I suppose some heat might help but without a lift, I may just be cooking the outer cv boot before I am done. Is it reasonable to think that continued use of PB Blaster will eventually overcome the will of Mr. Rust?
2 issues .cruise control. Thermo switch
brus brother replied to Subaru cars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf this is a game of charades... I'm stumped.
HG leak? Oil in recesses on top of engine?
Well, mine is on the passenger side so... maybe... nah... I see HGs in my future. I wonder if this external oil leak may also have an internal component that killed the cat on the passenger side... Changed the O2 sensors and plugs were fine so can't explain what caused the friggin' P0420 failed cat on the passenger bank.
