44
Everything posted by brus brother
I know it's only a few bucks for the contacts but with 168K miles on the starter, are the brushes in the starter heading south as well?? Safer to just plug and play a new starter (more than a few bucks)? So the click click click is the solenoid trying to move the plunger?? Then what does hitting the solenoid with a hammer do? (the mule analogy notwithstanding)
More time on my hands now. I decided to back track. Had just started the car a few hours ago and it was still in the garage so I didn't think to try it then and there and just proceeded to remove the little push on connector from the ignition to the starter solenoid to play around with hot wiring so I can revisit juvenile hall when I am way over the hill ;-) OK key off / plug disconnected, POS of battery jumped to spade plug on solenoid made crank. He thinks to himself, OK if you have a problem again, at least you can jump it with the key ON and start the car and limp home. Great tell the wife "tada... all glory and honor be mine" Notice a little greening inside the connector and use my handy dental pick and scratch inside a little bit. Spade seems clean. Put connector back on and... no start, just click click click click. Dadgummit! OK nothing to tell the wife about here. Push connector on and off a few times. nada. Take a long solid 1/2" diameter solid plastic rod and wind it down atop the starter solenoid and give it a good tap with a hammer. Turn key and it starts. Sooooooooooo not wanting to carry hot wiring tool kit or a hammer to start the car, am I now looking at rebuilding the solenoid or is there more diagnosis to be done before wasting $10 on contacts?
wanted to add: new battery I had sprayed lithium grease on terminals and that crap had melted and seeped down between the connectors and post but i had cleaned that off yesterday when this all started. I still think something is heating/expanding and malfunctions until cooled. just my opionion from the rowdy cheap seats!
2005 OB Automatic New Battery Parked car after 10 minutes car wouldn't start. In the past I occasionally had issues where I would have to jiggle the gear shifter to get it started but it always then started. I don't know if this is the same issue or unrelated. Am going back with a wire to jump from the battery to the starter solenoid to see if anything happens. Would that work if the safety switch is shot or is there a relay I need to check (and how do I do that?) Please don't let me misdirect with misinformation so any thoughts appreciated.
If they don't pay in the allotted time (determined by the court) then you will need a marshal to get your money. All costs associated with marshal, additional fees AND interest are added to your judgment. As I suggested earlier, have a friend pay them by check if possible and then you can see where they bank and freeze their account until they settle up with you. THAT will get their attention.
oops sorry i missed the details. 2005 OB. rear is worse than front but was pricing it out in case i did both. search at Advance Auto brought up bearings as well as hub/bearing combo. if i go with the combo i will monkey around with the heat and cold method on the old one. as i mentioned the price of soa is better than BeckArnley. fronts are pricey with either.
Well it looks like SubaruPartsForYou.com which is online but local to me has the genuine parts for the rear bearing for less than the Beck and Arnley. So I guess I'll go genuine for that. For those trying to save a few bucks, does it make sense to replace just the bearing or if paying someone to do the job, labor wise, just bolt on the new assembly. I was googling around before I came across the hub/bearing assembly and found a clever youtube video "pressing" a bearing in without a press. Basically put the hub in an oven, put the bearing in a freezer and then once at altered temps and shrinkage/expansion has been achieved, you can just drop the bearing into the hub. Start viewing at 8:42 where the fun begins. Wonder if the grease is affected as the temperatures reach equilibrium.Oh well, not for the feint of heart or those whose wife wouldn't let you muck up the oven.
