Everything posted by brus brother
2005 Subaru Baja Passenger side turn signal lights stuck on.
brus brother replied to AKIRA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"At one point, his passenger side turn signal lights came on and stayed on (solid, not flashing). They are on even when you take the keys out of the car." Any chance this involves the toggle switch on top of the steering column?? Switch half way on/off?
How to Disable Seatbelt Beeping Sound for 2014 Subaru Impreza?
brus brother replied to arose10's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTurn the ignition key to on but DO NOT start the car. Now buckle and unbuckle the drivers seatbelt about ten or fifteen times QUICKLY and then turn the ignition key to off. Now turn the key on and start the car as normal. If you were successful as I was on my 05 OB, the chime will chime 5 times when you first turn the key to on and then stop. It will also disable the seatbelt warning for the passenger seat.
2005 Outback -- recall coming for corroded brake lines + other issues
brus brother replied to freekraz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ultimatesubaru.org/forum/topic/147526-subaru-recalls-660000-vehicles-for-brake-line-corrosion-again/ From the reponses to the above linked post, the brake line corrosion thing is not just with Subarus, so you can not rest easy even after the recall work is done, since considering GM's refusal to take responsibility cited in a NY Times article, while you may be able to stop, some other GM or other make car may come slamming into you! This is an industry wide problem that Subaru is at least taking the initiative in addressing. Hope you get the wheel bearing issue resolved.
anyone need free 2002 wrx shell? CT Craigslist below.
http://newhaven.craigslist.org/zip/4570599744.html
What have I done to our '06 Outback? 2.5 normally aspirated, auto.
brus brother replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCoat terminal with dielectric grease after cleaning and perhaps a sacrificial penny (or two if you are feeling flush) resting on top of the battery?
brus brother replied to mtsmiths's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, computer needs to relearn. Drive as you would normally use the car and eventually it will have enough cycles to relearn the ways of your Subaru.
Front axle replacement
brus brother replied to dcam868's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs it REALLY noisy yet? If not, just clean it, pack it with grease, reboot and drive on.
Subaru Recalls 660,000 Vehicles for Brake Line Corrosion... again
I'd gather up the bills and present it to Subaru and see what they say.
GM refuses recall. Subaru cited as doing the right thing! http://www.nytimes.com/2014/07/08/automobiles/gm-resists-recalling-trucks-over-brake-line-problem.html?hp&action=click&pgtype=Homepage&version=HpSumSmallMedia&module=first-column-region®ion=top-news&WT.nav=top-news&_r=0
Subaru Recall NY Times article link Probably just being overly cautious but please don't tailgate too close to me just in case. My 05 and 08 were part of the earlier recall but apparently the powers that be deemed even that to be ineffective. Just for the northern states with salty roads.
2000 Legacy Cabin Air Recirculation Flap Actuator - Do I really need to Remove the Dash?
brus brother replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry, nothing to add but in another recent post a link describes the steps for dash removal/access heater core process that bemoans that Subaru starts with the heater core and then builds the entire car around it.
FIXED!! Trany delayed forward engagement
brus brother replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs far as the heat shield rattles, many have had success with using large hose clamps to add rigidity. Really low tech but non invasive. I once complained when I brought my car in for service and they fixed it by screwing a stainless screw through the heat shield into the exhaust. I found that a bit aggressive and destructive... but it did work. On an old 1991 Loyale,, an indie ripped the heat shields off and told me not to drive over high grass. Is it something about Subies or do all cars with heat shields fail at the same rate?
05 Outback AWD tricky on some winter roads
I have an 05 OB and thought that I too was experiencing the Ghostwalking mentioned here. New tires and realignment (which was way off) and the four corners of the car stopped fighting with each other for control. Problem solved.
Did my heater core go south?
brus brother replied to tbolt1003's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe best comment in the above link is that Subaru starts with the heater core and then builds an entire car around it!
Need a project car? 1969 Subaru Micro Truck
http://www.ebay.com/itm/111390323552?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2648 They just keep on going and going and going... Mods: Probably not posted in correct forum but Is there an Older than Old Gen forum?
2000 lego L awd tranny
http://www.canadiantechnician.com/products.cfm?intDocID=2280
2005 Legacy Wagon Limited - How to make it more "cool"?
brus brother replied to Grey47's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCoincidentally, Cougar posted on the following link a youtube video on how to access/remove/replace/modify the hvac/radio combo. Adding the aux would still be another task in the world of soldering to the board but if you opt to replace the head unit, here's how. http://www.ultimatesubaru.org/forum/topic/147297-radio-volume-going-crazy/?do=findComment&comment=1237126
anyone looking for a 2.2
brus brother replied to Downbound's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell from the pics, it does appear that the doors are functional...
brus brother replied to Grey47's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't get granny's bloomers all bunched up. I believe my initial statement highlighted above makes room for all kinds of teen drivers, in this case gals. I have heard similar comments from teen boys who envisioned themselves boy racers with a neato wing on the back of their car and not wanting an Outback. The original poster raised the point of granny cars so if his daughter had a preference, perhaps a swap at this point would be more in order than sinking more $ into this car. Just sayin'
brus brother replied to Grey47's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have a teenage daughter? Seriously... lift, bigger tires, tint? I would have jumped at those suggestions when I was a teenage boy but I'm not sure how much more this scholastic young lady will groove on Grandma even with shades, high heels or a "lift".
brus brother replied to Grey47's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYup, nearly impossible to easily swap out the head unit. I have seen some earlier posts where people hardwired the unit with an aux input. I will poke around and see if I can locate them if you are dead set on some serious work. I know where you are coming from wanting to reward your daughter but honestly, the wagon will always be "grandma". This will always be the case unless she is the outdorsy/sporty type who needs room to haul stuff around. Why don't you do what I did which was to drive the wagon myself and I bought my daughter an 05 sedan. Even if you were to sell the wagon for what you put into it and just broke even, your daughter would likely be happier with the sedan. Congratulations on the ACT scores, scholarships or not. Be proud.
Radio volume going crazy
brus brother replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI feel your pain. My 2005 has the same all in one HVAC and radio. Recently, the lights on the unit flicker on and off. I plan on doing nothing about it as it comes and goes. I have a long list of "do nothing about its". Sometimes these gremlins give in to my superior will and revert back to normal.
'05 OB Rear Wheel Bearing Humming 3 years. How long will it last?
brus brother replied to Juan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would bring the receipt and speak with service mgr. If no positive response, call SOA.
05 Outback Steering Shimmy
What I've learned here on Roller Derby is that after market axles are a crap shoot. Best to have the original axles rebooted or replaced with OEM. Otherwise, odd symptoms are reported including shimmying or even your dog howling unexpectedly in the middle of the night ;-)
Best subaru for a first cheap car
The 2.2 is considered bullet proof. Non-interference so somewhat lax maintenance and a broken timing belt won't mash up the engine. I stand corrected by the masters. Enough power for the Impreza footprint. Auto is just fine for me as I am past the boy racer stage. If the Impreza fits your needs size-wise, then why buy the larger Outbacks and Legacys? They will just cost you more to run. Hope I don't sound too much like your dad but that is what I'd advise my daughter/son if asked. Just sayin'...
