Everything posted by brus brother
05 Outback Steering Shimmy
Aftermarket axles or original Subaru axles? Did the shimmying relate to when the axles were done? Switching tires front to rear as our Texan friend suggested above might have diagnosed the problem unless all the tires were out of balance...
Is there a way to weld this captive nut? Cut frame rail and have limited access
brus brother replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs there room to get a nut splitter up there? The power of the almighty wedge. Google Image Link with many sizes and shapes
HELP!
Welcome to the board. Unless you are about to careen over a cliff, HELP! is not a suitable title. Please repost with sufficient information not to waste people's time who may have no knowledge or interest in your issue. Perhaps something like "Which coil overs fit 2001 LL (BE)"
Totally SCREWED by AAMCO...
brus brother replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's outrageous! How long do they expect this guy to wait to get his car back?
brus brother replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave car towed to a shop to install a junk yard/rebuilt if available. Open complaint/chargeback with CC company as soon as it is off their premises.
Head lights
Did you by any chance hit the "virgin switch", that little toggle switch on top of the steering column?? You may have hit it while cleaning or reaching through the steering wheel to reset the trip odometer? Subaru techs also refer to it as the battery kill switch since it kills many a battery when the lights are left running.
Rear end wandering on rough roads - solved
brus brother replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs with Nipper, the strange wandering (the Ghost?) first noticed on rutted snowy or slushy roads, on my 05 OB turned out to be poor alignment and the four corners of the car fighting for supremacy. Alignment and new balanced tires ended the battle.
headlights come on when car off, off when car on
brus brother replied to ruabean's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a toggle switch atop the steering wheel column. Once virgins, some among us have inadvertently hit the switch while cleaning, reaching through the steering wheel to change the trip odometer etc.. It is also called the kill switch by Subaru techs since it kills many a battery when the driver doesn't realize that the (parking?) lights stay on, even when ignition is off, when the switch is in the on position and drains the battery. It is intended as a safety feature in some areas for double parking.
brus brother replied to ruabean's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK before carefully reading the storyline, my first thought was that a newbie had hit the virgin switch on top of the steering column...
- window problems
NOISE - CV or wheel bearing?
brus brother replied to kickascii's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso consider that aftermarket axles (NEW or rebuilt) are viewed as potentially problematic in my reading on USMB site. It is possible that the one you replaced a year ago was going bad. Consensus is to always rebuild the Subaru axles if you can as they are more reliable than aftermarkets, so save you old one and reboot it anyway. There is also one or two aftermarket manufacturers that get the thumbs up but NOT Advanced Auto, PepBoys or Autozone or the other chains. I can't recall the manufacturer. Perhaps someone else will chime in.
Question about slick road stability
brus brother replied to Bushwick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs I reported in other posts, I had the same sensation that the 4 corners of the car were fighting each other for control. Got 4 new/balanced tires and a proper alignment (it was way out of specs) and all is well. BTW, bought the tires retail and had Subaru mount/balance and align. Thought they'd be more sensitive to our little friends.
high pitched whine 2003 outback
brus brother replied to bluebird's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like the wear indicators on your brake pads are, well... indicating wear. Often called "tweeter" or "squealer" it consists of a small tab of thin metal attached to the brake pad that rubs on the brake rotor when the pads are nearly worn out.
question about catalytic convereters
brus brother replied to charm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInteresting read. I always like to hear from the guys in the trenches here as I too see the occasional flashing warning lights and every unknown new noise as potentially resulting in my car flipping end over end and causing at least moderate bodily harm. My 0420 showed up at 105K on a fairly well maintained car. Unfortunately my 05 Outback has 5 O2 sensors and the cheaters don't work (I've tried)! I too am old enough to remember burning eyes from emissions from various environmental sources and am glad to contribute to a world that betters its condition even if I am just one grain of sand on the beach. The "power of one" is recognizable if that one person throwing the cigarette out the window mentioned earlier, on a dry SoCal day, starts a fire that burns down your house! OK, enough of my Geezer Grousing. This post has devolved into opinions (yeah, we all have one of those too) on what is tolerable. Perhaps the old tail pipe sniffer test could allay some concerns but my State relies on the OBDII output. I guess I would be more comfortable with flashing the ECU if I knew the real number of how far my system was out of tolerance. Cardoc on Subaru Outbacks does a fine job of analyzing 0420 here and helps individuals analyze some of the parameters if Charm wants to analyze his problem further. You never know when the aha moment may present itself.
Erratic HVAC/radio controls 05 Outback
My 2005 OB has the single HVAC unit combined with the radio unit. Last week I replaced a rear brake light and whether related or not, I since have an intermittent problem with the HVAC/radio controls. First time, the digital display on the radio was unintelligible (only parts of numbers and letters) and the HVAC was unresponsive. Restart had no effect. Finally turned the light switch on the stalk on and all worked as expected. Turned lights off and once again got the erratic behavior. Yesterday, the controls were unresponsive on both the radio and hvac until I turned the lights on. Turned car off and restarted and all worked as expected with or without lights. Close encounters of the third kind??
"Ghost Walking"
brus brother replied to ShawnW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLast winter I experienced horrendous handling in my 05 OB and at first I thought the ghost had taken up residence in my car. Turns out the alignment was way off. The four corners of the car were fighting each other for supremacy. New tires/balance and alignment and the ghost was exorcised. Just sayin' if you hear something clip-clopping down the road, chances are it is a horse and not a zebra. Common things occur commonly.
Mirror removal on 1999 Subaru Legacy Outback
brus brother replied to dcubed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSometimes you can drill a slot across the gutted Phillips screw head that would then accept a standard head screw driver (impact or manual). Use a dremmel tool to cut slot.
Erratic starting related to a/t shifter?
Today, it wouldn't start. Turned key to off position and then back on and it started. Does that clue point in any direction? Other times that hasn't had any effect... I'm gonna just keep posting symptoms until the day when I'll have to post asking for a ride home.
ok just happened again. neutral position made no difference. jiggled and cursed. let it move forward in neutral. still nothing. turned key on and off and removed a few times and eventually it just started. no rhyme or reason yet here...
Actually, yesterday after trying everything else, I did move the selector to neutral and it started. Whether it was a coincidence or not (having jiggled every which way first), I will determine at the next occurrence. If it is the "Park position" that is faulty, what does a repair entail?
05 Automatic OB Recently and with increasing frequency the car won't start until I move the a/t selector. Initially it just required a side to side jiggle but today I seemed to have to do everything but take it out on the dance floor to get it going. Don't want the wife to get stuck with this. Is there something adjustable?
My happy wanderer...
brus brother replied to radiodave1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLast winter I experienced wandering in light snow conditions. Almost like the 4 corners of the car were fighting for control and if I came through a rut in the snow, one corner would win out over the others as power was transferred. Had wheels balanced and alignment done and it disappeared.
Wheel Bearing Question
brus brother replied to crazyman03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas the axle replacement aftermarket? Plenty of reports of vibration if not genuine Subaru or certain aftermarket. Many here recommend go with a FW Enterprises axle (mwolf1303@juno.com). They were formerly MWE axles out Denver area. Apparently they rebuild genuine Sub axles. But your question was wheel bearing. My front right wheel bearing is heading south. More of a cyclical thrumbing sound when loading the outside wheel in a left turn. If your axle was aftermarket with any sort of warranty, you might consider swapping it out and see if the fit is different. I HATE doing work... twice!
- How to disable auto lock chime?
As Fairtax suggested, check your owner's manual. A brandy new 2014?? At the very least, ask the salesman to modify this as a courtesy. If you find the particular sequence for your car, please post it here. Welcome to the board. I know your model isn't listed at the below link but it has to be one such "simple" fix. Do they really have to make it so complicated?!? http://www.cars101.com/subaru/keyless.html#08chirp 2009, 2008 Outback Legacy, Tribeca, Impreza Audible Chirp when locking/unlocking give you an audible signal when the doors lock and unlock. If desired, you may turn the audible signal off. Do the following to deactivate the audible signal. You can also use the same steps to restore the function. 1. Sit in the driver’s seat and shut all doors and the rear gate. 2. Hold down the UNLOCK side of the power door locking switch. 3. While holding down the “UNLOCK” side of the power door locking switch, pull the key out and re-insert it into the ignition switch at least 6 times within 10 seconds after Step 2. 4. Open and close the driver’s door once within 10 seconds after Step 3. 5. The turn signal lights flash 3 times to indicate completion of the setting.
