Everything posted by brus brother
Noise from the trunk
brus brother replied to pos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFine work especially the split hose. In problem #1 I started at the last picture, I couldn't discern that something not factory original was present until I reviewed the top down sequence.
Help with Seat Belt Alert
brus brother replied to jmelynn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere ya go.http://www.ultimatesubaru.org/forum/showthread.php?t=57945&highlight=seat+belt+chime Welcome to the board.
Removing outer tie rod without busting boot?
brus brother replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX:grin::grin::grin::grin:
Need help replacing a key
brus brother replied to ultranub47's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's some info: See under 2 button http://www.rjes.com/html/my00-07_immobiliser.html Doesn't really clarify if your "market" ie Japan used an immobilizer.
brus brother replied to pos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 for the rattling connectors
Code P2096 Now what?
I don't really use cruise control so I see your point. Keep us posted.
Welcome to the board TJ. Unfortunately I still get the code 0420. I haven't replaced the cat $$. I bought a code reader/clearer Link It will also test that all systems are "ready" as in ready for emissions testing! I clear the code and it stays off for a while. The code comes and goes and I only need be concerned in passing emissions every two years. Clear the code, drive a fews cycles and all systems will test ready. Drive to test center, smile, pay the fee and away you go.
EJ22t won't start, floods with gas
brus brother replied to hellosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you using genuine Subaru plug wires?
This is a Subaru?
brus brother replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll give it a try. What tattoo?
This is a Subaru?
brus brother replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNow THIS is a Subaru.
New Member w/95 Legacy L - How To Keep It Reliable
brus brother replied to elmo1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSpeaking of CT winters, the CT DOT just responded to truckers request concerning road deicing materials. "The Motor Transport Association of Connecticut says legislators should make deicers like magnesium chloride illegal. Association President Michael Riley told the Republican-American of Waterbury ( http://bit.ly/11BAtQ7) that the chemical is corroding trucks at an unprecedented rate and officials should be worried about it affecting bridge metal. State DOT spokesman Kevin Nursick says the mix works well and it's up to motorists to wash their cars to avoid corrosion." Doh, why didn't I think of that...
I think i have owls!
brus brother replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMore likely Va and Room.
brus brother replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso then kick both sides a few times ;-)
Snow tires w/o TPMS valves on car equipped with monitoring system
Will snow tires/wheels from 2005 OB without Tire Pressure Monitoring System (TPMS) valves cause any problems if installed on 2008 Outback that came equipped with TPMS?
brus brother replied to elmo1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure if this model falls prey to the fuel filler pipe "protector" that traps sand and road dirt until it effects a rust through and leaking gas. Simple enough fix, remove the "protector" (look inside the right rear wheel well) and rinse away all debris that has collected there already.
oxygen sensor code P0030 2003 outback 2.5
brus brother replied to bluebird's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.obd-codes.com/p0030 See above link for some general info. Bank one sensor 1 is the passenger side sensor, BEFORE the catalytic converter . They can be hard to get out so spray the threads with PB Blaster a few times over a few days before wrenching.
p1507 code
brus brother replied to rick3114's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXO2 refers to the oxygen (O2) sensor. Not sure if you just have one or two pre-catalytic (front) converter sensors and one or two post-catalytic converter (rear or secondary) sensors. They provide feedback for emissions efficiency of the catalytic converter(s) by comparing the values pre and post converter. They look like the butt end of a spark plug sticking into the exhaust system before and after the catalytic converter. There is an electrical connection attached to same.
FIXED!! Trany delayed forward engagement
brus brother replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPlease report back with your results. Claims are that results are almost immediate.
brus brother replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSee post #252. It seems that Rooster2 does the ATF drain refill + Trans-X on a yearly basis as the Trans-X loses its efficiency. Doesn't appear that he does a flush but that shouldn't really change the effectiveness of the Trans-X remedy. Welcome to the board and good luck.
Feels like being I'm being pushed into turns
Personally, not trying to be unfair. Came here looking for direction only. The referenced links do seem to indicate that some 05 owners were experiencing problems within the same time range Setright decries for Audi/VW products. Have an appointment for next week for an alignment and will ask that they evaluate suspension/bushings/blinker fluid. Just don't want that "heart in my throat" feeling next snowfall. Nipper, you've already upgraded/updated some suspension elements so you may have already addressed any cause or you might just be lucky with your 05. I don't remember if you posted anywhere but how many miles on your Sandymobile?
Subaru recalls nearly 634,000 cars and SUVs
01/03/2013 05:13:14 AM PST DETROIT—Subaru is recalling nearly 634,000 cars and SUVs in the U.S. because lights beneath the doors can overheat and cause fires. The recall affects all Outback and Legacy cars from model years 2010 and 2011. Also included are Tribeca SUVs from 2006 through 2012 and Forester SUVs from 2009 through 2012. Subaru says the Tribecas and Foresters were sold before January of 2012. The company says moisture can get into puddle lights beneath the doors and cause a short circuit that can melt plastic and cause fires. The National Highway Traffic Safety Administration says on its website that Subaru will install an additional fuse at no cost to the owners. The recall is expected to begin in February. Moderator; please move to where appropriate.
Hey Nipper, Thanks for the research. Problems are reported starting from post #7 to 33. YIKES! This is not a one-off problem. I'm going for an alignment Thursday before any new snowfall. I'll report back with my numbers. The first time I became aware of this was just this year after snow began falling and then a few days later when there was a little slush left on the road. Only my wife and I were in the car at that time and the next time it was just me. I have been using the mighty Subaru to move a LOT of cut trees to a friend's after Sandy's storm. Wonder if that extra weight did any damage... If it is some other wonky tuning issue with the AWD, would it help to add (or is it remove?) the fuse to deactivate the AWD to help in the diagnosis?
Gloyale, How much weight are we talking about? Couple of 50 lb. bags of sand over the rear axle? Are you suggesting a rear alignment? My reading indicates that SOA may have changed the specs on these years. This was a pretty scary experience and I'm not letting my wife drive this car until I sort it out.
hmmm. What to do? Just went down and inspected the fluid. Looks pink and happy. 130,000 miles. Fluid was changed about 15K ago. Always did a drain and fill on regular basis. Never did a flush. I just took it out and ran tight circles at low speed and there didn't seem to be a struggle. No jumping, shuddering. Trying to figure out what else it might be: When it warms up, I guess I'll check the rear diff to ensure decent fluids and level? Must admit I haven't been back there lately! Power steering? Any ideas welcome. I did curb the right front in icy conditions last week hard enough to take some meat our of the rim. No shimmy, shake or vibration at any speed.
Well we just got our first taste of winter and I get an uneasy feeling from my 05 OB auto like I am being pushed from behind when driving on snow. Makes me feel like I am sliding into turns, like the rear wants to fish out behind me. I only have all seasons on it (still plenty of tread) but I don't remember this sensation last winter. I don't think I've experienced any TB issues and have faithfully changed fluids. The upside is that the uneasy feeling definitely keeps me at or under the speed limit for the roads.
