Everything posted by brus brother
420 420 420
Unfortunately, the cheaters don't appear to work on MY 05+. Tried one and then two piggybacked. My 05 has 3 cats and 5 O2 sensors. I only have bank one code so that's where I tried the spacers. That is my experience. Anyone have success with 05 and later??
New fuel pump, but still won't start
brus brother replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's a link to pdf of wiring 92 svx: http://home.arcor.de/klaushoffnau/SVX_Historie/WIRING_DIAGRAMS.pdf see page 4 area C-7 for fuel pump
brus brother replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCougar is the go to guy here on USMB for electrical gremlins. I don't receive any fee for this endorsement ;-)
brus brother replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry this: "Have you put a meter across the connector to the fuel pump? Very often on the Impreza when the ECU senses nofuel the car will not restart. It will need an ECU reset. The easiest way of doing this is to disconnect the battery for half an hour. The ECU has capacitors in it that retain a charge. By cutting the current supply the charge in the capacitors leaks away and any stored fault codes will be wiped." http://www.fixya.com/cars/t1708583-fuel_pump_not_working Not your car model but you never know and hell, go watch the Olympics while the battery is disconnected for a while. You did say it started when you first disconnected the battery but perhaps there is a sequence to get it going AFTER you did your work like when turning on a router after a modem etc... just sayin'.
brus brother replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs there any sort of alarm/security system with fuel shut-off?
driver's window wind noise fix
brus brother replied to gbhrps's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The Awesome *NEWER* Generation Picture Thread
brus brother replied to Red92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe oldie is my buddy's 1969 Subaru 360 with 11,000 miles on the odometer. Still under warranty? My 05 OB stands behind it just in case of bullies.
my subie is spooked
brus brother replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReminds me of an old movie Pete 'n' Tillie (1972). OK I'm a geezer. Anyway, a father and son play a prank on a neighbor who is annoying everyone by bragging about his new car's fuel economy. Every night, they go out and put more gas in the guy's fuel tank. Just when the neighbor reaches the ultimate height of pride over his situation, they then begin siphoning off gas until they bring him back to earth.
O2 Sensor - Where is it hiding????
brus brother replied to UMT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLocal Autozone lets you borrow the 2 types of wrenches for O2 sensors.
Seafoam ?
brus brother replied to john40iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat was the cel code?
code p0420, coolant leak
The antifoulers are available through Autozone part number 42009. They're about $6.50 for the pair. You'll have to drill them out. I have a pair already drilled out that didn't work on my 05 but everyone swears by them pre 05. Good luck. PM me if you want them.
brand new...needs balance?
brus brother replied to daveslights's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAsk to setup appointment with district manager at any dealership that is convenient to you. Ask for any bs in writing if he blows you off. Also ask to drive another like model on their lot. As for oil change, first recommended change is early due to break in metal shavings etc. contaminating the oil... or so I've been told.
Roof Rack Removal-GF8
brus brother replied to Kerplunk105's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow, I learn something new everyday here. So I should revise my earlier post to say go to Durania's house and "borrow" his when he's not lookin'.
brus brother replied to Kerplunk105's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXT-30 Go back to junkyard and borrow one from another subie. The torx screwdrivers came with the cars and were usually in the glovebox.
DANG! I jinxed myself putting scanner in car to loan out
Remove the scanner from the car immediately before the wheels fall off!
HG job finished :) Wont start :( - EDIT - Will Start :) Day 3 Update
brus brother replied to samneric's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat misfire problem and what about the bubbles in the coolant?? I feel like someone changed the channel when I went to the refrigerator!
brus brother replied to samneric's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEmily, I have an 05 with the weeping oil at the bottom of the HG. Is resurfacing a must under these circumstances when replacing the HGs? There isn't any overheating and I am wondering if that is the only indication. Is the straight edge test good enough?
Problem programming Subaru remote--Success!
brus brother replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh them young'ns... Charter member of the OFRT and you're still not fast enough ;-)
brus brother replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEd, What is odd is that from the cars 101 page linked above, your 2002 should have had the square remote with the colored buttons. Also the teardrop version shown as a replacement doesn't have the trunk release button as your new one shown, purchased from the dealer. My 2000 Legacy had the grey buttons and in-law's 2002 had the colored buttons. You stated in your first post that you can't get the car's system into program mode. I don't recall that this procedure requires any input from the remote at this stage, so then, any discussion about having the correct remote and working battery is a distraction. While there is something about programming up to 4 remotes so it could be possible that all 4 positions are "occupied", your problem appears to be about sequencing to get into programming and not the new remote (that might come later if you are truly unlucky). Here's a link to some other interpretations of this odd dance that SOA subjects us to: http://www.clubwrx.net/forums/interior-mods/66863-subaru-keyless-remote-programming-instructions.html
Stealership charging too cheap?
brus brother replied to crazyman03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwish I lived in Portland...
2005 Legacy 2.5 XT
brus brother replied to vwbuge1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck out the driver's side HG at the rear bottom and you should see oil seepage. Both of my 05s (legacy and OBi ltd) have this issue. Seems suggested "maintenance" is to do the HGs with the 105,000 mile TB.
Leaky leaky legacy hvac. (passenger's feet wet)
brus brother replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBut if you sort of just gently loosen the blockage with the wire, the "biofilm" which has likely built up within the confines of the hose will be flushed out. That's what happened with mine. We aren't talking about a cork in a bottle here. The wire will first pass through the center core of the loosely aggregated plug and then once patent, you can further trefine the opening allowing the debris to be washed out. What have you got to lose? If the plug is displaced back into the box and this method doesn't work, you can always go back to taking apart the entire front 1/2 of your car. Oh and you may have missed the part in my post where I said "problem solved". As they say though, your mileage may vary.
brus brother replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs I recall, on my old gl and loyale the hose exited near the rear of the right wheel well. I took a straightened metal coat hanger and snaked it up from the exit opening unclogging the line. Problem solved.
Intermittent Airbag Light UPDATE
UPDATED UPDATE: The dashboard airbag light came on again. A few months ago I noticed that the driver's side map light which is in the center overhead console was out so I went to change it but tested it first and it was OK so just replaced it. In the past I had similar situation and just cleaned the contacts and replaced. This time I just left it alone. When the light came on, I looked up and noticed that my wife had depressed the switch and left it in the ON position not realizing the bulb wasn't "working". I pressed the switch to the OFF position and the dashboard airbag light was now off as well. So there is some sort of electrical gremlin in the unit. It's just 4 screws and 2 connectors to replace the $130 unit. For now, I'll just do without a map light.
Marketing Research on Subaru parts suppliers
brus brother replied to ShawnW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLocal parts counter at SubaruPartsForYou.com. It's a 30 minute drive but they offer on-line pricing and I have the parts in hand. Anthony or John at the counter will help with any look-ups or special orders so I don't need to rely on my meager knowledge. Good luck Shawn. Hope you don't leave us for corporate.
