Everything posted by brus brother
Did this fly off my car? - Pics inside
brus brother replied to IdiotSavant's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLatest HG posts seem to indicate that your wishes will eventually come true:banghead:
O2 cheater not working--newer cars too smart for this?
brus brother replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy has 3 cats and 5 sensors! 2 precat, 2 post cat and one on top of rear cat after the two join. I spoke with Bosch tech support after replacing the front precat with OEM and while it would seem in his interest for me to buy his sensor for the rear, he suggested it wouldn't help. Just my experience and not meant to dissuade or mislead.
brus brother replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am afraid that 2005+ models are too smart for the cheaters. I have an intermittent P0420. After reading about all of the possible real fixes, costs and potential lack of solution, I bought a small code reader for about $20 on eBay (Autel MS300). Clear the codes, drive a few cycles at various speeds to get all systems "ready", rescan to make sure no codes and no codes pending and then run to emission testing center. Since my code is intermittent, I justify this method as "coinciding" the timing of when the code is present or not with my visit to testing center.
Length of HG issues
brus brother replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDADGUMMIT!!!! So if this is the case, HGs should be replaced as part of the timing belt interval?
Length of HG issues
brus brother replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo, after the HGs are done, if done properly, how long are they good for?
Length of HG issues
brus brother replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is the consensus and verified by my friendly SOA tech: Turbo HGs do not leak. Both of my non-turbo 05's (legacy and outback) experienced the external oil leak from HG which isn't so much of a problem until it starts dripping on the exhaust. Had the sedan done under extended warranty but will probably wait until the Outback, now with 125k miles, starts smoking like a James Bond smoke screen effect.
'05 OBW 90K, Replace Tranny Fluid?
brus brother replied to Juan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDealer was misinformed. Timing belt normally at 105K miles though I recall reading that there may also be a time indicator. ie don't expect a belt not to dry rot out in 15 years just because you don't put on the miles. If you don't mind getting dirty, I do a drain and refill on my 05 every 25-30K miles. That's not a complete flush but it is what dealer charges a pretty penny for anyway. Drain from pan, replace plug with crush washer and fill from filler tube with yellow dip stick on driver's side (USA) just in front of firewall. You'll need a long neck funnel and just a little less than 4 quarts of Subaru ATF fluid (about$7 per quart). Diagram is pretty clear in owner's manual.
Broken door-molding clip on Frester
brus brother replied to Canoe2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it perhaps "look weird" because part of the broken clip is wedged behind the molding? If that is the case you may need to remove that as well when you pry the molding away before the excellent tape fix suggested by gbhrps.
No AWD steelership diagnosed as duty c and clutch pack, replaced but still NO AWD
brus brother replied to bluedotsnow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure what B.A.R. is but you would have been in a better position if another shop found the defect and provided the repair. Now it's your word against theirs? I guess you could print out this post as a time stamped record of your ordeal...
brus brother replied to bluedotsnow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBeen following the thread for a while and even commented earlier that the diagnosis was the difficult part. However, it seems at this point that there was no way that the dealer could have known that the indie shop had failed to reinstall the plate that others seem to agree is a reusable part (and therefore didn't include in the parts list) no more than they could have guessed if the indie shop had inadvertently left a peanut butter and jelly sandwich wedged inside the tranny. The omitted gasket may be worthy of a small rant. It is tough enough doing diagnosis on a problem without having the overlay of negligence of others prior "handiwork". Glad it all worked out though.
1-3-2-4's head gasket replacement
brus brother replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXvalve cover gasket/spark plug seals?
manual transmission spring pin
brus brother replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX:lol::lol::lol::lol::lol::lol::lol::lol::lol::lol: And this is why I read posts that I have no knowledge of or anything to contribute! Good one John!
Interior door panel interchangeable?
It appears that the rear interior door panels are interchangeable from the 05 to the 08 Outback. There is a different level of trim between the models as the 05 Limited is all "leather" and the 08 is a lesser model with a cloth insert mid panel. Is this middle section able to be swapped between the panels? Don't want to bother removing and monkeying around if it isn't swappable.
Is the head gasket problem fixed?
brus brother replied to Geoff77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX05 Legacy sedan Just had HGs done for leaking oil both sides. 05 Outback, haven't had the heart to look and see what evil is lurking in that pan beneath the engine now.
Parts store paint to match Glacier White?
brus brother replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhile those rattle cans are pricey, a body shop supplier who has a color scanner is probably still the most accurate as the paint on your car has usually changed/faded somewhat thru sun exposure. This may not be as critical with Arctic White as say with a deep red color. Also, I read somewhere that you need a special plasticizer additive for the bumpers to keep the paint from cracking over time.
Help with 2.5l timing realignment
brus brother replied to mccullough's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsome info on this youtube video
brus brother replied to bluedotsnow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPun intended? While yours seems to be an interesting case requiring careful and critical diagnosis, I have all too often witnessed service managers up-selling services (read preying) with caveats like "well, lil lady, you really should replace your (barely worn) brakes, blinker fluid etc. as I see you have children in the car"!
2006 Legacy sluggish
brus brother replied to kec789's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas there a different code for knock sensor? P0420 code (at least on my 05) says nothing about knock sensor. It is an intermittent code as well. Would this be consistent with your findings? PS where is the knock sensor? Ivan Imports: I already replaced the bank 1 front O2 sensor and within minutes threw 0420 again. I thought this odd since the car was driven only 2 cycles... but then again it goes off (without my resetting) for a while before returning.
My 05 Legacy...
brus brother replied to hockeylvr93's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow. I have an 05 Subaru. Mapquest here I come.
narrowing down a mysterious thunk
brus brother replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXloose heat shield? or is sound louder? pound on exhaust, see if there is any sound,
Trading up to a newer Subaru, but which one???
brus brother replied to spideyz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre these manuals or auto trans? 00 automatics have the delayed engagement on the transmissions otherwise if the hg are done, excellent car.
Fuel Filler Neck- what is that thing on the side called?
Nope, Subaru Outback! Video and story below: http://www.wtip.org/drupal/content/west-end-news-june-30
Stereo display not working
brus brother replied to csmiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRecords indicate under 36K warranty SOA replaced the unit as lights went out on both hvac and radio. Seems like your problem is different.
brus brother replied to csmiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe lights to the combined stereo/hvac unit on my 05 cut out a few times but as I recall, at restart of the car, came back on. Hasn't happened in a while but I remember mention of a questionable connector at the back of the unit. Never had to get that deep into it myself but try re-seating the power connector. Are your HVAC lights working? I can't recall if my stereo worked without the display lights but it would certainly make channel surfing difficult but not impossible. I will check my warranty service records to see what if anything was done by the dealer if it was within the warranty time period. I know I never paid out of pocket for any repair.
