43
Everything posted by brus brother
From FAQ: How do I attach a file to a post? To attach a file to your post, you need to be using the main 'New Post' or 'New Thread' page and not 'Quick Reply'. To use the main 'New Post' page, click the 'Post Reply' button in the relevant thread. On this page, below the message box, you will find a button labelled 'Manage Attachments'. Clicking this button will open a new window for uploading attachments. You can upload an attachment either from your computer or from another URL by using the appropriate box on this page. Alternatively you can click the Attachment Icon to open this page. To upload a file from your computer, click the 'Browse' button and locate the file. To upload a file from another URL, enter the full URL for the file in the second box on this page. Once you have completed one of the boxes, click 'Upload'. Once the upload is completed the file name will appear below the input boxes in this window. You can then close the window to return to the new post screen. What files types can I use? How large can attachments be? In the attachment window you will find a list of the allowed file types and their maximum sizes. Files that are larger than these sizes will be rejected. There may also be an overall quota limit to the number of attachments you can post to the board. How do I add an image to a post? If you have uploaded an image as an attachment, you can click the arrow next to the 'Attachment Icon' and select it from the list. This will be inserted into your post and can be located where you want it displayed. To include an image that is not uploaded as an attachment and is located on another website, you can do so by copying the full URL to the image, (not the page on which the image is located), and either pressing the 'Insert Image' icon or by typing after it, ensuring that you do not have any spaces before or after the URL of the image. You can insert pictures from your albums (?) in this way too.
I think y'all may have missed the point that this is a dealer only proposition with some help from SOA. I didn't catch this before the 80K warranty ran out so shame on me. Effectively, my out of pocket $300 cost will about equal what I would have to pay for a TB job. The rest of the $ from SOA would cover the HG work. All them extra parts your tossin' in will add up pretty darn quick, especially at dealer prices. Just saying... BTW, the tech does the HGs in the car all the time. Says he just tilts the engine.
3" of rain is a good opportunity for some differential diagnosis. Cover the sunroofs with plastic (garbage bags etc) and duct tape the edges. If you are wet tomorrow, then it is either the windshield seal or the drain from the cowling area below the windshield. BTW, does it ever get wet simply by running the AC or actually, the same if you run the defroster which may coincide with when it is raining? If that is the case, perhaps the drain line from that unit has come detached from the AC unit under the dash.
Actually, at this point, the oil is settling on the cross member so none is even appearing on my garage floor. The oil mixing with coolant that GG describes as a rarity is somewhat comforting. So what years did/will SOA HG be considered solid? My 08 at 60K is dry but as I said, both 05s (105K and 82K) are weeping. The discussion and link referenced damage to cats (I have an intermittent P0420 on my 105K 05) from oil burning etc. That info is all over the board as well. The post did verify that the cheaters don't work on 05+. But that's another story.
Found the following in a link on the NASIOC site relating to 05+ and potential fouling of cats: "Your model year has a problem where it starts to leak very early from the oil return galleries on the bottom of the heads. Make no mistake: it IS a headgasket leak and you DO need to do something about it. You'll get no further warning before it converts to a much more serious oil-to-coolant leak." BOTH of my 05's have the telltale oil leak at the driver's side! My passenger cat is in P0420 mode off and on. Anybody tracking these leaks and ultimate failure rates?
Thanks for the link but even more now to worry about with MY05 "Your model year has a problem where it starts to leak very early from the oil return galleries on the bottom of the heads. Make no mistake: it IS a headgasket leak and you DO need to do somehting about it. You'll get no further warning before it converts to a much more serious oil-to-coolant leak." BOTH of my 05's have the telltale oil leak at the driver's side! Anybody tracking these leaks and failure rates? May have to start a new thread.
After some reading it appears the 05s are subject to an "oil only" external head gasket leak problem. As I said, the "wet" area is beneath the driver side rear cylinder and on the cross-member below. Does a coolant leak leave a residue after the car is sitting overnight or would it dry without a trace unlike oil leaks?
I've had the 0420 for the past year or so. Started at just about the same mileage. It generally means the passenger side cat converter is heading south. Saving numerous trips to local Autozone to have the code cleared each time, I bought a cheap $20 code reader/clearer from ebay and played around with the spark plug cheater trick (search 0420 code on this site). Unfortunately, our 2005s don't seem to like the cheaters and didn't 'fix" the problem. The code doesn't affect drive-ability. I too replaced the front O2 sensor but that didn't help. The code comes and goes so the "threshold" may be a little to tight in the computer's spec. The blinking cruise control goes along with the code which apparently becomes inactive with the CEL. Passing state state emission tests is tricky but after I clear the code and the car runs a particular set of cycles/speed runs and all systems are reading as "ready", I have been able to pass before it threw the code again. I have read that there are some performance companies that will reformat the computer to eliminate this parameter but I haven't bothered with it (cost/benefit $300 versus replace the cat $700 after market which gets pricey itself and some say doesn't prevent the code from coming back). Sorry to hear you are facing these headaches with your "new" car but quite possibly the previous owner had just reset the light before selling it to you.
Have been futzin' around with p0420 code for a while and had a nice chat with Bosch tech support. They call back within 15 minutes of leaving a message. I would give them a call since my local Autozone's data base was wrong and gave me the wrong part # for my 05. Even my local Subie tech says stick with OEM for the front sensor as this controls the engine performance. From what I've read, the rear sensors on the other hand are worth the risk since they just throw a code to tell you when you are polluting and the cat is shot.
