46
Everything posted by brus brother
Drats! Recurring 0420 on 05 OB. MY 05 has 5 sensors and three cats. Sensors are located: 2 pre cat, 2 post cat and one atop the rear secondary cat. Under the hood it says Calif. emissions. I had the 0420 (bank 1 below threshold) so I had already experimented with the cheater on the passenger post cat sensor without success. Yesterday I installed a new oem pre cat sensor on passenger side (bank 1) hoping that it was getting lazy at 130,000 miles and if so prevent it from damaging the cat if this was the case but the code recurred. While trying to correctly identify the aftermarket sensors, I spoke with tech support at Bosch who was dubious that replacing the post cat sensor would help in my situation. (Remember it is in his interest to sell more sensors). He said that this sensor would become slower in response if failing and not more active so less likely to throw code. I reinstalled the cheater on the post cat sensor in one last ditch effort but it looks like a new cat may be coming in the future to eat out of my wallet!
Just wanted to UPDATE the post for future searchers. I brought the car to the dealer. The tech did some testing and suggested that it was a defective (failing) unit which is contained in the overhead (map light) center console. Watch and wait was suggested due to intermittent nature of problem. Well it has been nearly 2 weeks and the airbag light that been occurring daily, has yet to come back on. If this continues, then the only thing that has remedied this was a reseating of the two connectors to this unit.
OK I'm thoroughly confused. I have P0420 code - for bank 1 (passenger side in US) catalytic efficiency below threshold 1.) MY 05 Outback has a total of 5 sensors. Since my 05 Outback has one precat and one postcat sensor and then another on the rear cat after the passenger and drivers pipes meet, do I need to change all three at 130,000 miles and while I'm at it throw in the drivers side precat and postcat sensor just because?? 2.) Are any of these critical OEM? Dealer told me I needed a new cat (maybe 2). YIKES x 2!
GD, Don't mean to hijack post but I've had the 0420 code for a while on my 05 OB. This vehicle has two front (pre-cat) and two rear (post-cat) sensors and one more on the rear cat. I tried the antifouler on the passenger (post-cat) rear sensor without success as it caused a different code to be thrown (2096). I removed the antifouler and installed black tape over dash warning lights. ;-) I haven't gotten around to trying the antifouler on the driver's and passenger post-cat sensor. With 130,000 miles on the car, is it advisable to change out the front sensors as a routine maintenance item or would they have thrown a different code than 420. Hate to waste the $ if they aren't at fault. Also hate to kill the cat.
Got it from their website but will be calling a rep today. UPDATE: Thank you for contacting Castrol North America. Castrol always recommends following the guidelines of the original engine manufacturer for the recommended fluid for use in your specific application. This information can be found in the vehicles owner’s manual or by contacting the manufacturer directly. According to Castrol’s ATF guide recommended for the 2008 Subaru Outback is the Castrol Import Multi-Veh ATF or the Castrol Dex/Merc Domestic Multi-Veh ATF. Both Castrol Import Multi-Veh ATF and the Castrol Dex/Merc Domestic Multi-Veh ATF meet the Subaru specifications and may be used in your application. Please find the product data sheets for the two mentioned products for your personal reference. Thank you again for contacting Castrol. Castrol Consumer Relations
OK to update, the airbag light on the dash board has been coming on (and going off) more frequently now. The horn and cruise control work when the light is on which from my reading seemed to eliminate clockspring. Yesterday when the light was on, I had the dealer read the code: 26 Passenger Airbag Indicator Failure. Tech told me to keep an eye out for when the light stayed on if the overhead console (by the center map lights) was still functioning as he has had to replace a number of these. Today, the lights were still functioning so the next possibility I'm told is something amiss in the seat belt tensioning mechanism/circuit for the passenger side. My understanding is that when the airbags deploy, an explosive charge in the seat belt mechanism is released to keep the passenger from kissing the airbag. Anyone have any idea where the connectors are located and how/if I should try and reseat the connectors? I would hate to have my monkeying around deploy the airbags. Apparently the dealer can test the mechanism by inserting a resistor in line?? I just thought I'd check the connector before going back to see if that solved the problem.
Check out ebay "headlight cleaner". There are kits for about $6 w/ free shipping or WalMart "headlight restoration" for about $15-20. They all work about the same. Mild abrasive/elbow grease and a sealant. You could try toothpaste/clear spray paint but kit would be cheaper. Be sure to mask off adjacent areas.
P0420
brus brother replied to Faith's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
For the record, please describe. Did you just add Seafoam to the gas tank or did you feed it through one of the intake lines? -
Dealer said airbag light had to be ON and then they could read the code. Since it is intermittent, and usually goes off after I restart the car, this is going to be a matter of timing it just right since the dealer isn't close to my home and it only happens once in a while. Found this: Airbag codes can only be read and system cleared with an Asian Airbag specific scanner. The only non-dealer scan tool we have found available for these vehicles is the Launch Scanner line.
