43
Everything posted by brus brother
http://www.carstereoremoval.com/htm/stereoremovalSubaruOutback05_08P.htm the above link has instructions for $5 I used the following instructions (with pics) when I was retrofitting the cabin air filter (which was not factory installed due to poor space design). There are a number of screws beneath the center console and snap on trim pieces that need to be removed to get to the innards. http://legacygt.com/forums/showthread.php/installation-cabin-air-filter-56k-warning-1626p9.html?t=1626&page=9 Hope this helps.
I have the same model/year and I recall reading that there may be a Subaru dealer split front plate that replaced the original but I'm not sure if that provides any relief. Model year 05 is stuck with HVAC and radio/cd as ONE unit. What stupidity! You may end up having to scour junk yards for questionable reliability in a used part...
Just tried to wrench out the plugs on 05 OB with 105,000 miles. The very fist one made a very disconcerting creaking and didn't feel right. I stopped and tightened it back up and all seems fine for now. Is there any trick to getting this out safely or has irreparable damage been done by leaving the ORIGINAL plugs in so long! Do these plugs become one with the head after such a long time?
Well, I was going to have TB, water pump and cam seals done now at 105,000 miles. I think the dealer tech I request is able and trustworthy so I would also consider his recommendations regarding the tensioner(s), and other gears, pulleys widgets and whats-its that I wouldn't have a clue as to whether they were still good to go or already gone. My OB is an 05 and the dealer has a $299 TB special right now. Obviously, there will be additional "costs". I can change a belt on a vacuum but my vacuum is non-interference so I am not as concerned dealing with sucked up Cheerios and dust bunnies as trashing an interference engine. Oh, did I mention... this OB is my wife's car?!
I've been using dealer where needed but am considering alternatives for timing belt. I know it ain't rocket science but I prefer an experienced Subaru mechanic for work on the "innards". I like the idea of replacing as much while inside but the dealer's rate for parts will make this an annoyance. I'm in Fairfield County, CT.
Yeah I'm back at square one. Removed all cheater anti-foulers and cleared codes. Waiting for drive cycles to set all sensors to ready which will then likely throw the p0420 code. I am having the dealer do the timing belts this week and will ask the tech to go for a drive with a laptop setup with datalogger to see what's up. I keep seeing the OBDII to USB cables and software on eBay for $20 but I don't have the know how to read the output anyway. There seems to be some complications with MY 05 Found the following quote: "Post catalyst fuel trim system too lean (Bank 1)" apparently "it looks like its only happening on 05MY models... as i read somewhere the rear o2 sensor actually has pulsating ohm resistance, and not a steady one.." http://forums.nasioc.com/forums/show....php?t=1699259
@Fairtax Post #12 in this thread lists the various combinations of threaded and non-threaded anti-foulers that I have tried. I think I covered all the bases as far as the first downstream sensor in bank 1. The car seems to run well which is why I started monkeying around at the downstream sensor which only appears to be related to emissions. I also thought the culprit to be the first downstream sensor behind passenger (bank 1) cat and not the sensor atop the rear (3rd) cat after the two pipes join because it did specify bank 1 in the code P0420. I can eliminate code P0420 by modifying the first downstream bank 1 sensor with two antifoulers (either with two drilled or one drilled and one undrilled) but that is when the P2096 appears. One drilled antifouler didn't work at all. I suppose I could swap the pair of up- and down-stream sensors side to side and see if the codes changed from bank 1 to 2...? It's just so darn cold here now with 10 degrees and the remnants of a 24" snowfall. Mine is a simple code reader and not a data-logger. I may have to bite the bullet and ask the dealer to do a diagnostic run to see what's going on before I start replacing cats. Do you see any holes in my reasoning?
Found the following quote: "Post catalyst fuel trim system too lean (Bank 1)" apparently "it looks like its only happening on 05MY models... as i read somewhere the rear o2 sensor actually has pulsating ohm resistance, and not a steady one.." http://forums.nasioc.com/forums/showthread.php?t=1699259 Would this explain why the cheater anti-fouler throws a P2096 code on the 05MY but is working fine for other years?
P2096 back. "Post catalyst fuel trim system too lean (Bank 1)" History: Trying to solve P0420, I first tried one antifouler drilled out and piggybacked to one not drilled out and that gave me P2096. Then I eliminated the piggybacked one but that returned the P0420 even though the sensor was "out of the stream" so I next tried two drilled out antifoulers thinking it would be "out of the stream" but still getting enough input to show it as working. Help me noodle this. There are 2 upstream sensors (one on either downpipe), 2 downstream sensors (one behind either cat) and one additional downstream sensor atop the rear cat after the two pipes join. Is it relevant that I am only modding the bank one sensor behind the first cat? Is the code simply relevant to the difference in readings between the front (on the engine downpipe) and that first rear sensor (behind the passenger cat) or is that rear sensor thrown into the mix and warranting attention?
Wish I was in West (by God) Virginia. I'd be over in a heartbeat. I'm in Weston, CT. We had a ridiculous 2' of snow last week and an ice storm predicted for tonight. Makes working outside problematic. Right now I have two reamed out anti-foulers in place but I show one pending 0240 code and egr not ready. I may remove all of the anti-foulers and let Subaru run a real time diagnosis to see what's kicking in and when. The suggestion of 11/2 length antifouler could also be accomplished by only opening the piggyback second antifouler only half diameter. Left as stock with only spark hole it gave the failed sensor code and opened up entirely gives the old 0240. Trial and error is in order as long as I don't need inspection until summer. Seafoam, different gas, wear aluminum foil hat while driving...
So what is complicating this is that my P0420 code returned. I initially tried piggybacking two anti-foulers (one drilled out) but that got me P2096 code for sensor not working. I removed the piggyback and was back to P0420. I then tried two drilled out but I'm now still getting P0420. At 6 years and 105K miles, the 8yr/80K warranty period on cats is past and Subaru only warranties their replacement cat for 12mos/12K miles. At $625 plus 1 hour for the passenger side cat, with small warranty, I am looking at Eastern Converter for $400 with a 5 year/50,000 mile warranty. Does anyone have any experience with this manufacturer or can you suggest another aftermarket? The dealer said there has been mention of bad gas in the northeast and if that is the case then I wonder how long it will be until the driver's side fails. The driver's side is in the $1300 range as it contains two cats. This car seems like it was designed to support the parts department! I am wondering if I should trade up to a newer model... With these kind of ongoing repairs for a 6 y/o car, leasing starts to seem pretty smart.
