43
Everything posted by brus brother
OP's first picture sure looks like it is a (rusty) spring+bolt connector on one side so ... flex joint? The further aft junctions don't use springs as posted by Imdew. That being said, the collars are pretty shabby and might still leak around the donut. BTW, I have an issue with my 08 where the rear pipe Vs off to the rear mufflers and have bought time using furnace grade high temp caulk from Home Depot.
dave Welcome to the board. You identify Boyds as your city. If it is Boyds, Martyland, (Go Terps) take your photo into Autozone in Germantown and with year and model, they will sell you the exact donut gasket which as the name implies is shaped like a donut (not flat) and the spring bolt setup like this LINK that you will need. Looks like the donut and spring bolts will set you back around $25 total. The picture posted above by Imdew is the joint in your picture (minus the rust). Called a "flex joint" the springs and the thickness of the donut allow for... "flex" as the exhaust flexes and vibrates, preventing exhaust leaks. Don't overthink this. You might be able to cut through where the donut sits as described above by Heartless. A shop would probably torch the bolts off and be done. You might get lucky but trying to unbolt it the way it is rusted will probably torture you by rounding off the bolts and nuts.
Wasted 1.5 hours today at dealership only to find out that I have the latest software already installed. Apparently, the system isn't even smart enough to report that, but only that it is "unable to download, do you want to retry". Too much technology not ready for prime time. And we'd trust self-driving cars?
Just tried updating the head unit software over wifi and it fails. I have good wifi signal in garage. SOA said it must be brought to dealer. Tech friend suggests that if you miss an update or 2, the wifi download/update will fail. I had auto download and auto update turned off. Some suggest that it's best so as to avoid interrupted install. I will chat service tomorrow and report back as it would seem best under the circumstances to leave auto download set to ON but only install when assured of no interruption. Anyone else have this experience?
I asked Uncle Google about "subaru vibration cv axle when stopped" and the search returns a bunch of discussions. I picked one for a quick look and the above link has discussions about CV rebuild and other tolerances and types of engines more prone to vibrations. While it may seem counter-intuitive, I did experience the above mentioned phenomena after axle replacement on my 05 OB.
Probably not worth the trip but I am in Weston, CT and have a passenger side front cat from my 05 OB non turbo that I replaced with a cheapo aftermarket thinking it would solve the P0420. It didn't solve my problem, eventually traded in the car so you can have it if you want and thanks for cleaning out my garage! Free is good. Unsure what shipping would cost. If you are Handy Andy with a welder, could you just cut the pipe at the front of the cat and clean out any honeycomb that's broken/fuel burnt and clogging? A frtiend was able to shake loose bits out of his cat on a Ford van
Can do. Turn the key in the ignition to "on", the spot just before starting the engine. Buckle and unbuckle the seatbelt 20 times within 30 seconds. Immediately take the key out of the ignition. Enjoy your chime-less Subaru Edit: you only have to do this once and the chime is off for good. Unless your battery dies. Also, you can toggle the chime on/off by following the same instructions.
- 1 reply
- 2
Thanks Numbchux. I left Lake Placid behind and am back in the garage. Last month I replaced the o-ring and the leaking I had presumed would require a new pump was fixed for $1.70. Those hoses are stiff with age so not unlikely that a clamp should be tighter but... Will see how it behaves out of the cold but I was almost certain that listening pointed to the alternator. The guys at Advanced Auto suggested the belts were just plain cold and the noise would stop once warm but your PS hose/clamp leak will bear some listening next time around.
Take a deep breath. Once the CEL is on, the cruise control becomes disabled. Oftentimes, the CEL will clear after a number of drive miles/cycles where the car isn't experiencing "unusual" circumstances. Once the CEL is off, the cruise should return. Clearing codes is easy BUT get the code reader and determine what the fault is first. BTW, if you clear the code yourself, unlike letting the code reset naturally, there will be a learning period for the engine so don't set the mental alarm anew if there is rough running. Let us know if you need the procedure to facilitate the learning. Now, as far as your Evel Knievel impersonation goes...
Best news yet. Suspecting what I read as a common problem, fiddling around with the top mounted plastic elbow atop the pump caused air to enter the system (groaning noise). Cleaned the entire area with brake cleaner and traced the substantial rivulet of brake fluid back to a defective O-ring sitting where the return line enters the top of the pump. Aside from the O-ring being hardened, it is a poor design in that the fitting is only held on by a bolt on one side, allowing for torquing of the fitting leading to air being sucked in and fluid escaping when pump not sucking the fluid through the system. $1.70 for the O-ring and the area is nice and dry. Competent diagnosis comes before treatment. Watchful neglect paid off. One of my professors advised to follow the 6 Ps: Prior Preparation Prevents Piss Poor Performance
Here's an excellent tutorial on rebuilding an 07 OB PS pump. Not that difficult... BUT in searching, there is no rebuild kit for the 2008 DOH! as others have reported the same on the SubaruOutback site a few years ago linked HERE.. Too bad cuz the PS is working properly. No noise. So, if I could just locate the external approximate O-rings, I wouldn't even be concerned with the internal seals or bearing, less chance of scoring or misplaced vanes. This is our only car so I don't have the luxury of removing the pump and spec searching O-rings. Might go cheap through Carparts. $140 Comes with the pulley so I don't have to rassle that thing loose. One year warranty. Used of that vintage would be suffering the same hardening of the seals so not a long term solution. Unfortunate that an 07 wouldn't cross-fit or would it? Subaru dealers list the same part number 34430AG03B for 07 as 08... I'll have to check with vin tomorrow but that might just be the workaround to source the reseal kit AVAILABLE FOR 07 BUT NOT FOR 08 my?? Puzzled...
