Everything posted by brus brother
Subaru Navigation disc warranty
brus brother replied to ParkerQ's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou "just" bought the 2010? I'd have a chat with the salesman and see if the most recent disc should have been delivered with your new car? Worth a try.
FIXED!! Trany delayed forward engagement
brus brother replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 2000 Legacy GT (now sold) had the tranny replaced at 35k for delayed engagement under warranty. I'm not sure that even with a used tranny you may just be buying another problem waiting to happen... again. The replacement which came from Subaru may have had a redesign as it never recurred. Glad you saved some $.
Tornado got my rear window 08 OB
Yeah as long as it doesn't rattle or more important get in the way of the latch assembly I guess I'm OK. A freak occurrence here in CT, but you guys who get these tornado visits on a regular basis should... MOVE! Is there an easy way to open the access panel to the rear tailgate without doing too much damage?
I am having a shop repair the rear gate window on my 08 OB wagon after a limb struck the glass in a freak tornado here in CT last week. Is there an easy way to insure they get all the glass out of the tailgate and around the wiper assembly in the event they aren't that savvy?
rear washer nozzle not working/leaking
brus brother replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like the hose has become separated/broken. Time for some exploratory surgery.
Stripped top brake caliper bolt (NOT!)
OK So a few days rest and Advil I had another go at it and as it turned out I just hadn't snugged it up completely after all and was overthinking it, not overtightening it! Changed the pads, all is well, happy holidays to all, thanks for the noodling (and needling hank ;-))
What time can you be here?
With a bad back at the end of the day, once I felt the bolt spin twice, I just snugged it up, didn't take anything apart to verify "stripped", shavings etc. Now seeing the schematics, it looks like the whole sleeve/nut may be spinning against the shoulder of the caliper. The sleeve has two flat sides and for whatever reason may not be snugged up against the body of the caliper. So either I rounded over the sleeve's "flats" or I cut a groove in the shoulder of the cast caliper. Hmmm which is harder? Could I have really done so much damage with a small ratchet wrench?
I think you miss my point. I'm not sure there is anything wrong with the bracket... The threads are inside the sleeve (see the link I provided above). How do these sleeves fit into the bracket to keep them from spinning??
Dealer said there was one in all of NE area so I can have it early next week with holiday closings! What am I missing here? Something isn't adding up... Oh and I agree, I was using a small ratsheet wrench and wasn't trying to beat the stuffing out of it when it stripped out.:-\ All I was doing was inspecting the pads. Loosened the top bolt, removed the bottom bolt, spun caliper up, reverse order tighten and then... wish I had left well enough alone... So let's slow this train down now... see the link below: http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?itemIdentifier=125288_0_4222_&skuDescription=Brakeware+/+Brake+Caliper+Bolt/Pin&brandName=Brakeware&displayName=Brake+Caliper+Bolt/Pin&categoryNValue=&sortType=&store=5156&isSearchByPartNumber=&fromWhere=&fromString=&counter=0&itemId=555-0&navValue=14400555&filterByKeyWord=&productId=125288&searchText=&categoryDisplayName=Brakes+%26+Traction+Control&parentId=44-0 It appears that in my oh &^%$# moment and asking for assistance, I didn't do any of my own exploration. Seems that the top bolt is threaded into a sleeve that is "inserted" into the elusive and expensive bracket?? Sooo, before we take out the antigravity machines that we've been dying to use, is there anyone here who has actually had this apart who can fix this with earth tools? I have a reman caliper on hand (initially planning for the worst) and the kit has two different sleeves. One has an additional collar at the end opposite the threaded end. Which sleeve is on top? How do these sleeves fit into the bracket? This is my only ride and I don't want to take it apart until I know where I'm going with it.
ah the wisdom of the ages... thanks
I did some noodling around and I can get the bracket (bridge?) that the caliper mates up to and the bolt threads into for $40 from SubaruPartsForYou.com. Seems like less labor and a little more predictable since this is a frequently used location when changing pads or are helicoils rock solid, better than new? Waddayathink? Interesting to note the ages of (and types of) the answers from those that responded. I'm closer to the geezer end of the spectrum.
Got a little too aggressive (overtightened) and stripped the top bolt on the drivers side brake caliper. What do I need to make things right? 2008 Subaru OB
Replacment seatbelts FREE???
brus brother replied to mr.radon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do recall seeing a lifetime seatbelt warranty in one of my subie manuals (a Subaru tech first told me about this) and a google search shows many people getting warranty replacements. Some dealers had to be convinced SO why not call Subaru of America and get it in writing to bring to the dealer and then you get to laugh at them and then ask why they wasted your time when you first brought this to their attention. I can't recall what year this became effective and you didn't mention what year your car was (pre 1968?) so why not just verify with Subaru and post back with your results.
Flood damaged Legacy
brus brother replied to Phizinza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo were you parked at the old Westport train station?
2002 legacy GT knocking sound please help!
brus brother replied to angusburger's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJump up and down and demand your money back and assure them that unless you get your money back, you intend to park yourself and your car in front of their sales office as long as it takes to convince them (and any future customers) that your advertisement will be bad for their business model.
brus brother replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis really wasn't about the Subaru anyway. Life is not solely about the journey. It's mostly about the people you meet along the way. Good luck with your adventures. ps damn shame the trans x didn't work:-\
Rattle when shifting from 2nd to 3rd gear???
brus brother replied to profanesam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere? We have a lift on the website?
brus brother replied to profanesam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRattling noise could possibly just be the heat shields on the exhaust. Get under the car and bang around on those buggers. They can decide to rattle at peculiar times. Not sure about the "shake" part of the equation though.
High Beams 05 2.5 GT Wagon
brus brother replied to Sydfloyd44's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you actually turn your lights on?? High beams will flash w/o lights being on... oh yeah and then there is that pesky parking light switch on top of the steering column (use to be called the virgin switch because all of us Subaru "virgins" would unwittingly hit it during a "quick wipe down of the interior" and the exterior parking lights wouldn't go off) (also called the battery kill switch by Subaru technicians for the same reason as above... lights staying on and killing the friggin' battery) Just reread your post... seems pretty likely it's the Virgin Switch and I hope you read this before you kill your battery tonight.
03 Outback H6...whining from front diff area?
brus brother replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's OK I've seen pictures of guys swearing before...
why dont we have cop cars like this
brus brother replied to AWD TURBO!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah, BIG bad guys
Lifetime Subaru Warranty!
http://www.danperkinssubaru.com/MiscPage_6 Got this as an email today. Certainly not for the shade tree mechanics that lurk here but for those who would normally do all service at shops and keep records, seems like a decent deal. This is the same dealer as subarupartsforyou.com where I get my parts for cheap here on the east coast.
Smelly HVAC
++ on the cheap fix. SOA wants a pretty penny for their "stink-no-more" processes. I haven't yet reassembled the dash after installing the cabin air filter. I see where the blower motor is and assume that the evaporator is below that. Too cold to play with it today but if I can actually visualize and clean the evaporator I guess beyond that I would need an exorcist.
Smelly HVAC
I bought a used 08 OB and there has always been an odd smell from the HVAC unit. Kinda like smoked meat:eek: mostly when I first turn it on. I changed the cabin air filter and sprayed Lysol down into the vents as well as directly in when the cabin filter was out. Water is draining out normally when running the AC and defroster. I guess the only thing left is cleaning the evaporator. Has anyone done the drill the hole/squirt in the cleaner treatment to clean the evaporator box? I'm not even sure how to access the area. Any pictures or diagrams/instructions/material-parts list appreciated. Hell, I'll drop the car off and pick it up in a few hours if that works for you.
