43
Everything posted by brus brother
To repeat: Common things happen commonly. In problem solving 101, I was taught that if you hear something clipping and clopping down the road, chances are that it is a horse and not a zebra! (unless you live in Africa) Try premium gas and disconnect belts as instructed. Save the freaking out for special occasions.
Quote: Originally Posted by Spiffy why would you want to free Hat McCullough from prison? he murdered twenty-three babies & toddlers! --Spiffy Phew... I am getting old. I didn't get the reference and was beginning to think that I should edit the title to protect the innocent! This is a nice hat not a bad Hat.
Just got back from Dan Perkins Subaru. Their on-line parts division is SubaruPartsForYou.com. I ordered replacement parts for a rebuild of a Subaru 1968 360 engine and they threw in a FREE Subaru World Rally Team hat! It's the one on their website under hats blue with gold lettering for $14. I have used them for years and they are very competitve with online dealers plus I can walk in right here in Ct. and get what I need. Parts manager Anthony had ten hats left and said he would throw one in for any order over $100. Just specify free hat in the special box in the order or call him and mention USMB site.
2008 Outback automatic. Occasionally, in the AM after the car has sat overnight, I turn the key and nothing happens. Instrument panel is lit but car doesn't start. The car is in park in a level garage. All I have to do is push the automatic shifter the slightest bit forward and the car will then start. I brought it to the dealer checked the shifter and said that the "hole" was lined up and they were at a loss. It was suggested I leave the car overnight. Aside from inconveniencing me, I'm not sure what this will prove. Once they try to start the car and IF it happens to occur and verify my solution of pushing the selector forward, what will this prove? Any thoughts?
Anyone have a problem with surface peeling on the interior door handle area of their Outback? The 05s and up have a matt black finish on the handle that started to degrade as a slight bubbling and then could be rubbed right off. Now the same thing is happening at certain areas on the silverish trim in the same area. No cleansers have been used on the area and since it is the face surface of the handle, it's not even where your hand would rest when closing the door.
Subaru 360 Starts, Runs then Dies
brus brother replied to brus brother's topic in Historic Subaru Forum: 50's thru 70's
I don't suppose that comes in a spray can... -
I guess fear of toasting this 2 stroke engine is my greatest concern. Since there is no way to drain the engine and get rid of conaminants, any bits and pieces that come loose can cause some damage. Hate to admit but it might be time to pull the heads and have a real good look. -
Zefy. Even spraying fuel right in, bypassing the carb, it "seizes" until it cools for a minute then can start again. Starter is stronger than I and even that won't crank the engine. -
Car sat for 35 years and was seized up when I got it. I was able to free it up using Marvel Mystery Oil lubrication. It starts right up but the engine seems to seize after about a minute. Starter won't crank engine but after allowing it to cool for 30 seconds or so, it starts right up again. Without possibly misdirecting you, my thoughts are that the rings are not floating on the piston or in some other way binding so that the heat of expansion once the car starts causes the pistons and rings to seize against the piston walls. Any thoughts? -
Suabru 360 (I think it's a 1968) starts, runs for minute or so then dies. After waiting a few minutes, it will again start, run for a minute or so then stops again. Any suggestions (other than use the car for only VERY short trips)? PS Car has been off the road for 30+ years and is trying to get back in the race... 60 mpg!
