Everything posted by brus brother
Outbacks with dual sunroofs
brus brother replied to eagleb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow about black spray paint:rolleyes: Didn't this post start in regards to " The main reason I ask is due to the transmission I'll be pulling this weekend". The digression of the discussion may relate to the nature of a subie driver to go "off road."
09 Forester
brus brother replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot bad in the pics. I always thought the Forrester was too boxy and big in the butt. This new design seems to be more of a front proud car.
Gotta love craigslist
brus brother replied to Bigbusa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice tophat.
replacing front halfshafts 97 outback
brus brother replied to Collins's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJeepers, I just caught up with this post. You used everything but a Tomahawk missile!
48hr old 2008 OB in the shop
brus brother replied to Max Power's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso known as the "battery kill switch". Not sure on the 08 but there was a parking light ON/OFF on the top of the steering column switch that if inadvertently activated would kill batteries. You didn't seem to have a dead battery though so no virgin for you. PS Outrage is a reasonable response with perhaps some perks begged even if they figure it out. "My confidence in the car is shaken" etc...
brus brother replied to Max Power's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhmmm... washing a car shouldn't have this effect. If they have another one on the lot, I'd ask for that one PERMANENTLY and not for the kitty litter loaner. Nuf said.
Check out what we wasted our tax refund on!
brus brother replied to subaru360's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not a 360 but SCORE!
How about a "frequently asked questions" thread?
or braking it yourself...
severe head gaskets
...ah FleaBay:banana:
severe head gaskets
Could be something as simple as the rocker switch on top of the steering column.
2005 Forester Key Remote Died. Help!
brus brother replied to Subarob007's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 2000 remotes are still going strong but I too would try a new battery before I convicted the remote. Did the car come with 2 remotes? Is the other one still working or is there the possibility that the receiver unit is not functioning.
'05 Outback - opinions?
brus brother replied to Bserk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou're in love! If we try to talk you out of it (her/him), we won't be invited to the wedding! My wife drives an 05. Are the door handles color match painted to the car. It wouldn't matter in youir case since they are a standard black in the lower trim model (my car is tan (titanium pearl)... doesn't show dirt like those darker colors). The lower trim model also didn't have side airbags. The ride is softer than my 2000 Legacy GT and it seems to roll more in the corners. Transmission died at 15K?? but was replaced under warranty and fine now at 40K. It's a more lux ride to be sure. Good luck with the in-laws.
Are you kidding again! Please help me!
Probably not the safest suggestion to ride in the trunk... but how to resolve?? I can't recall all of the details from your prior post. If you haven't already done so, remove EvERYTHING from the trunk compartment including spare tire, jack, removable liner... EVERYTHING! Now if you remove the rear seat back, can you access the trunk/lid area? This might make diagnosis easier AND safer. Perhaps there is something (wire harness etc.) that was moved in the lid/spoiler placement/replacement/replacement that created and then momentarily "solved" your problem (in any event likely related to some harmonic resonance)... If all else fails, temporarily REMOVE the spoler and seal the mounting holes to see if it eliminates the problem. If that is the solution, then your choice is to have a spiffy spoiler that will keep you "grounded" or a quiet car that will keep you sane.
Check this guy out...
brus brother replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, I've been lurking in the shadows and watching this thread's goings ons. Sir from Oklahoma, your final bow contained some startling information. That many defective reman axles seems problematic to this casual observer. Having to sort through 4 defective axles to find one that you found acceptable is a very failing grade of 20/100. The less obvious defects (maybe even the one you finally installed) will take time to evidence themselves and hopefully the naive customer will have forgotten who did the last work. When my inner boot tore, I started shopping various suppliers and learned that some rebuilders use new parts and others just regrind. The price was reflective of the caliber of the rebuild. Having been forewarned of the vagueries of the aftermarket axles, for this very reason and with the help of this board, I opened, cleaned and rebooted my Subie original axle shortly after I became aware that it was torn. Thanks again to the board for sharing observations and hopefully Sir Okie will continue to drop in and lend some wisdom.
Seatbelt warning
brus brother replied to new92loyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry a search with "seatbelt chime" and it works like a "charm".
Seatbelt warning
brus brother replied to new92loyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPay no attention to Nipper. The man is daft and will say anything to get his 10,230th post!
Help needed: Window problems
brus brother replied to eagleb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLast time I had my windshield re-replaced, the tech commented about the earlier job where they used silicone and that this was not the proper material and could lead to rusting? Anyway, Permatex makes one specific compound. Google auto glass sealant. Hell, you might as well break the glass yourself for that money.
What would you pay for this car?
brus brother replied to Bigbusa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell from a read of the Craig's list ad, this "li'l lady" seems to know her way around the yard... talkin' up the 2.2 and that you could "part it out"...
Windshield Wiper Mechanical Queation
brus brother replied to Suzam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you checked to see if the nut was loosened? Step 1. unloosen nut if that fails, Step 2. apply teflon tape then unloosen nut:dead:
brus brother replied to Suzam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWife created same condition by operating wipers w/o clearing snow. Tightened nut, kissed wife. All is good.
'95 Legacy: Brake squeal w/new OEM pads!
brus brother replied to 95LEGOBW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGeepers, you folks out there in "hither, yon" are very patient. You first posted this problem over a year ago:eek:
brus brother replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTolerance little grasshopper. Discussion is good.
rear washer squirts during acceleration... ('98 Imp)
brus brother replied to Spiffy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWoohoo... Agent 00Skip
brus brother replied to Spiffy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ultimatesubaru.org/forum/showthread.php?t=22394&highlight=leaking+windshield+washer+fluid Found the above with the Search function. Mentions part# from Nissan but the last post also links to http://www.ultimatesubaru.org/forum/showthread.php?t=20595&page=1&pp=10&highlight=rear+washer and Ferret references a check valve in the rear pillar.
brus brother replied to dhewitt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the board.
