45
Everything posted by brus brother
http://www.ultimatesubaru.org/forum/showthread.php?t=22394&highlight=leaking+windshield+washer+fluid Found the above with the Search function. Mentions part# from Nissan but the last post also links to http://www.ultimatesubaru.org/forum/showthread.php?t=20595&page=1&pp=10&highlight=rear+washer and Ferret references a check valve in the rear pillar.
Use the SEARCH function on the site as this has been covered. As I recall, sitting in the driver's seat, turn ignition key to the ON position but do not start the car. Then buckle and unbuckle the driver's seat belt rapidly for 10-15 times and then while the belt is buckled, turn the key off and remove the key from the ignition, unbuckle and then exit the car. The next time you put the key in, it will chime a few times and then stop. This worked fine on my 05 OB and the above is the procedure as best as I can remember but as I said, check the site's SEARCH function for "seat belt chime". I found the link: http://www.ultimatesubaru.org/forum/showthread.php?t=57945&highlight=seat+belt+chime
God awful weather and conditions up there in T'rntoe, Mr. Badorties. Really, can I call you H, as experienced a man as you in the workings of a fan should know that lubrication can't hurt. I think gbhrps covered the nitty gritty for you if you decide on a full assault. Still might be time to search the detritus piles of civilization as your avatar's namesake Horse might do and see if a used replacement is on hand. Thanks for reminding me of a good book I read... 30+ years ago! BTW, what is life like in the Waterloo/Kichener area? Just checking out travel there from NYC with a possible change of venue.
