Everything posted by brus brother
Electrics Issue
brus brother replied to hawksoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXalt
Brake trouble
brus brother replied to sparkydave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI run the tubing into a small bottle with brake fluid in it so there is no chance of sucking back any air.
How hard to change a front axle?
brus brother replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am confused. My driver's side cv inner boot is torn and have never done a boot or half-shaft change. Is it really possible to remove the half-shaft from the transmission without separating the shaft from the wheel and replacing the cv boot without removing the half-shaft from the car?
Slight overheating on 97 Legacy
brus brother replied to lhrocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXClogged radiator? If you replace the thermostat, genuine Subaru is recommended on this site.
2.2 Oil/Coolant Puddle
brus brother replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEmily, I just noticed that your bio is "Subaru Whisperer";) Quite right.
missing oil
Thanks for all the replies. I can now stop the running in circles and screaming bit. BTW I'll take the rag out first thing in the am.
missing oil
Missing oil cap noted today on a friends car... not a Subaru! Until she gets a replacement, is there anything I should do? Rag in hole, wired tight? Run in circles scream and shout?
Go for the $495 fluid maintenance package?
I agree with Nipper have the Er um and the timing belt done at the same time but if you are at all handy, check around here for discussions on DIY fluid changes. Under a similar situation, I walked into the Parts Dept. bought the t-belt, asked for their on-line price and left it on the front seat for the SOA mechanic to replace when he did the job. Cost me about $57. I'm not sure about the price on the Er um.
A day spent with the Legacy (new exhaust and car wash)
Get your money back... what a scam!
2000 Legacy GT cv boot/axle seals
OK I know you'll all tell me I'm going to CV hell but my buddy with the lift said he always wanted to try a split boot so he bought one for me and wants to see how it works. He's convinced that it will be easy on the lift and worth a shot. Waddayasay?
you betcha
Called another local Subie dealer. He said $230 to do inner boot. If outer is shot as well then just put reman shaft in for $390 and drive away. He too didn't consider the axle seal as a must do. I can't see how the first dealer could have determined axle seal was bad considering the grease slopped all over the area. When I questioned the first dealer, he said he could do the 2 boots and axle seal for combined $500! What a deal... er steal. As always, thanks for the direction.
Had my 2000 LegacyGT in for free oil change (lifetime ) and was told when I picked it up that I need to replace torn driver side inner and outer CV boots AND axle seals. Had it up on a friend's lift and sure enough there was enough grease slung around the inner boot to confirm that aspect. Didn't notice any problem with the outer boot. There is no clicking sound yet on turns. Car has 102,000 miles on it. I didn't notice any leaks on the passenger side. Prices quoted: 2 boots x $40 + 2.0 labor = $270 axle seal(s?) $28 + 3.0 labor = $315 Questions: 1. Should I change the boots or replace axle at 102,000 miles? What is the life expectancy of axles? 2. What should the upcharge be for changing the axle seal(s) at the same time as the cv work or is it unrelated? Am I being hammered?
Coolant Leaking from bleeder screw?!
brus brother replied to Bmm001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh, young grasshopper, after all the advice that came too late, I too was in haste when I was 23! Age will temper you but the bleed screw, well that's something else.
Mysterious Coolant Leak--'06 Outback
brus brother replied to riggyrow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I remember correctly, there is a fluorescent dye that SOA can add to the coolant. After a couple of days, they can inspect the engine and surrounds with a UV light that will show if and where the leak is located. Of course this is not helpful with internal leaks but if it is an external leak that is evaporating on contact with a hot engine or exhaust.
4eat lifespan
brus brother replied to nixon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIsn't Emily at CCR doing used/rebuild transmissions or was I only having a good dream?
radio/cassette problem in 93 wgn
brus brother replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm trying to locate an in dash 45 rpm record player:lol: That's where it's at... cool.
brus brother replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheers for Gnu! There is also a device for transferring analog audio to digital audio so you can save all the music on the cassettes to a digital format (MP3/CD/DVD, whatever) and upgrade the player. I know it's hard to enter new technology. I still have 8 track tapes that I need to catalogue;).
brus brother replied to starkiller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy experience with cassette decks is that generally what goes south is nothing more than a dried out drive belt. See if you can open and get a replacement belt.
Blown fuse replaced but still problems.
brus brother replied to eseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdid that same fuse blow again after replacement?
Clear timing belt covers for Subaru?
brus brother replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJC Whitney carries these!
Noisy exhaust system...no, not from tailpipe
brus brother replied to mtnpat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope, tell them to FIX it... or ask a regional representative to meet you and show you another similar year and model that acts the same.
Auto transmission fluid level
Makes sense to me as well but I'm not much for waiting... I don't even buy green fruit!
AT was replaced about 35K ago and figured I'd do a drain and fill. I didn't think to check the level before the drain and simply replaced the 4 1/2 quarts that I got out. Drove it around and now the fluid level is about an inch above the hot high indicator. Is this crucial? Is it possible that it was overfilled all this time without causing problems? Is the 4 1/2 quarts about right for the drain from the pan?
Legacy wagon 2000 something Squeak
brus brother replied to faithless88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the sound go away when you step on the brake? If so could be a wear indicator ("tweeter") on the brake pad.
